xthuijs
Introduction
This white paper is intended to help the readers obtain a quick  understanding on 1/10/40/100GE Ethernet port on a Line Card in general  and how it has been implemented in ASR9000 including the configuration  detail. It also includes a ‘frequently asked questions’ (FAQ) section,  which cover some of the potential field questions that might pop up  while deploying this feature using ASR9k. Overall, this white paper can  be a quick reference guide for anyone working on these Line Cards.
Disclaimer
This white paper is based on ASR9k Release 4.3.1.
General
The Cisco ASR 9000 Series Aggregation Services Routers is the baseline for next-‐generation Carrier Ethernet networks, providing up to 96 terabits (Tbps) per system. Its architecture design enables capabilities for next generation Internet that includes mobile aggregation & virtualization and also reduces operational cost & complexity.
Ethernet Line Cards
Ethernet Line Cards in ASR9000 can be called as First and Second generation based on the Network processor (NP) used. The Second generation Line Card is also referred to as Enhanced Ethernet Line Card.
Table 1 Supported Transport Modes and Optics Types for Line Cards
Line Card/Modular Port Adapter (MPA) Generation Supported Transport modes Supported Optics Type
A9K‐40G First Generation 1GE LAN SFP
A9K‐4T First Generation 10GE LAN XFP
A9K‐8T/4 First Generation 10GE LAN XFP
A9K‐2T20G First Generation 1GE LAN
10GE LAN/WAN PHY/OTN
SFP for 1GE Ports; XFP for 10GE Ports
A9K‐8T First Generation 10GE LAN/WAN PHY/OTN XFP
A9K‐16T/8 First Generation 10GE LAN/WAN PHY/OTN SFP+
A9K‐24-10GE Second Generation 10GE LAN/WAN PHY/OTN SFP+
A9K‐36-10GE Second Generation 10GE LAN/WAN PHY/OTN SFP+
A9K‐MPA‐20x1GE Second Generation 10GE LAN/WAN PHY/OTN SFP
A9K‐MPA‐2x10GE Second Generation 10GE LAN/WAN PHY/OTN XFP
A9K‐MPA‐4x10GE Second Generation 10GE LAN/WAN PHY/OTN XFP
A9K‐MPA‐8x10GE Second Generation 10GE LAN/WAN PHY/OTN SFP+
A9K‐MPA‐1x40GE Second Generation 10GE LAN/OTN QSFP+
A9K‐MPA‐2x40GE Second Generation 10GE LAN/OTN QSFP+
A9K‐2x100GE Second Generation 100GE LAN, LAN PP* CFP
A9K‐1x100GE Second Generation 100GE LAN, LAN PP* CFP
* LAN PP – LAN Proactive Protection – “Cisco Proprietary”
Optics OIR
After removing Optics, it is recommended to wait for 10 seconds for Software cleanup to complete before inserting another Optics. Also, after Optics insertion, it is recommended to wait for 10 seconds before removing it. After Optics insertion, software waits for power to stabilize before applying configuration. If the above recommendation is not followed, then it may affect the functionality of Optics.
Third Party Optics
ASR9000 supports only Cisco Optics listed in the following data-sheet.
https://tmgmatrix.cisco.com/?npf=83
Third Party Optics support policy is discussed here:
https://community.cisco.com/t5/service-providers-blogs/asr9000-policy-3rd-party-optics/ba-p/3106940
Product Warranty:
http://www.cisco.com/en/US/prod/prod_warranty09186a00800b5594.html
Transceiver permit pid all
ASR 9000 supported Optics has undergone extensive thermal, electrical and optical testing during qualification. Cisco policy is to support only optics mentioned in the datasheet. When a new Optics is inserted, Software reads Optics EEPROM and performs Security, Type and Product ID (PID) verification. If the inserted Optics is not a supported one, then Optics Transmit Laser will be turned off. This will cause Loss‐;of‐;signal (LOS) and Local Fault (LF) at far‐;end port. As an override for PID check for a given port, the following CLI can be used. But, it is to be noted that there is no guarantee that an unsupported Optics will work even after configuring ‘transceiver permit pid all’ CLI. An unsupported optics may also damage the Hardware since it may violate thermal and electrical specification of the Line Card. Cisco recommends only to use ASR 9000 supported Optics.
PID Override Command
PID Override command:
RP/0/RSP0/CPU0:ios#conf t
RP/0/RSP0/CPU0:ios(config)#int gigabitEthernet 0/5/0/0
RP/0/RSP0/CPU0:ios(config-‐if)#transceiver permit pid all
RP/0/RSP0/CPU0:ios(config-‐if)#commit
To verify if you are running into this scenario use the command
RP/0/RSP0/CPU0:A9K-BNG#show controller g 0/0/0/0 internal
Port Number : 0
Board Type : 0x00000235
Port Type : 1GE
Transport mode : LAN
BIA MAC addr : 6666.4444.2222
Oper. MAC addr : 6666.4444.2222
Egress MAC addr : 6666.4444.2222
Port Available : true
Status polling is : enabled
Status events are : enabled
I/F Handle : 0x040000c0
Cfg Link Enabled : tx/rx enabled
H/W Tx Enable : yes
MTU : 1526
H/W Speed : 1 Gbps
H/W Duplex : Full
H/W Loopback Type : None
H/W FlowCtrl Type : None
H/W AutoNeg Enable : Off
Link Faults : (0x00000000) none
Raw Link Faults : (0x00200000) XCVR_PID_UNSUP
Link Up : yes
Link Led Status : Link up -- Green/Amber
UDLF enabled : no
UDLF force event : no
UDLF uni_dir enabled: no
Pluggable Present : yes
Pluggable Type : 1000BASE-SX
Pluggable PID :
Pluggable Compl. : (Service Un) - Compliant
Pluggable Type Supp.: (Service Un) - Supported
Pluggable PID Supp. : (Permit All) - Not supported
In this example we still do have an unsupported optic, but we override the check and the optic is brought up.
The PFM (platform Fault Manager) will still report the error however:
RP/0/RSP0/CPU0:A9K-BNG#show pfm location 0/0/cPU0
CURRENT TIME: Jun 13 10:37:30 2013
PFM TOTAL: 6   EMERGENCY/ALERT(E/A): 0   CRITICAL(CR): 6   ERROR(ER): 0
Raised Time         |S#|Fault Name       |Sev|Proc_ID|Dev/Path Name |Handle
Jun 13 02:08:47 2013|2 |DEV_SFP_PID_NOT_S|CR |180304 |SFP           |0x1029000
Statistics
RP/0/RSP0/CPU0:ios#sh controllers gigabitEthernet 0/5/0/0 stats
Statistics for interface GigabitEthernet0/5/0/0 (cached values):
<output omitted>
Notes
  1. Packet input and output count doesn’t include counts for Preamble (7 bytes),SFD (1 byte), FCS (4 bytes).
  2. Input error giant: The total number of well-formed and valid packets that are dropped because they are larger than the configured MRU. This counter is similar to the RFC2819 definition of etherStatsOversizedPkts, but is based on MRU rather than a fixed size of 1518 octets.
  3. Runt: Any frame received lesser than 64 bytes is counted as ‘runt’ and dropped.
  4. Input MIB giant: The total number of well-formed and valid packets that are larger than 1518 bytes. (Regardless of whether the packets are dropped due to MRU consideration). This counter strictly matches the RFC2819 definition of etherStatsOversizePkts.
  5. Input error symbol: A Symbol error means the interface detects an undefined (invalid) Symbol received. Small amounts of symbol errors can be ignored. Large amounts of symbol errors can indicate a bad fiber or Optics.
  6. Input error jabbers: A jabber is a frame longer than 1518 octets (which exclude framing bits, but include FCS octets), which does not end with an even number of octets (alignment error) or has a bad FCS error.
MTU
In ASR 9000, the maximum allowed receive Ethernet frame size can’t exceed 9220 bytes which includes 4 bytes of CRC. If ‘mtu’ CLI is not configured, then default MTU of 1514 bytes is selected by software and internally 12 extra bytes are added to take care of QinQ header and CRC bytes. So, with default MTU configuration, any frame above 1526 (including CRC), will be dropped as ‘giants’.  Maximum allowed user configurable MTU is 9216 bytes but in MAC hardware the maximum allowed is 9220 bytes.  So, with ‘mtu 9216’ configuration, the maximum allowed receive frame size can’t exceed 9220 bytes (including 4 bytes of CRC).
NOTE
Starting in XR release 5.1.1 the ethernet interface driver configuration for MTU and MRU is determined by the XR config.
Prior to these changes MTU/MRU calculation was simply based on the configured MTU + 12 bytes for the addition of 2 Ethernet Tags and the CRC field as mentioned above. However from 511 onwards, the config determines the actual MTU/MRU.
  • If no VLAN tags are configured:
    MTU/MRU = configured MTU on interface + 4 CRC bytes, i.e. 1514+4=1518
  • If one VLAN is configured:
    MTU/MRU = configured MTU + 8 bytes (1 tag + CRC)
  • If two VLAN tags are configured:
    MTU/RMU = configured MTU + 12 bytes (2 tags + CRC)
MTU configuration command:
RP/0/RSP0/CPU0:ios(config-if)#mtu 9216
RP/0/RSP0/CPU0:ios(config-if)#commit
Link Defects
A Port link can go down for several reasons. The following CLI may be used to find out the reason for it.
RP/0/RSP0/CPU0:ios#sh controllers gigabitEthernet 0/5/0/0 internal
Port Number         : 0
Port Type           : 1GE
BIA MAC addr        : 0022.bde2.b178
Oper. MAC addr      : 0022.bde2.b178
Egress MAC addr     : 0022.bde2.b178
I/F Handle          : 0x0e000240
H/W Tx Enable       : no
MTU                 : 1526
H/W Speed           : 1 Gbps
H/W Duplex          : Full
H/W Link Defects    : (0x0000026a)  RX_LOS HW_LINK LASI NO_OPTICS TX_FAULT
Table 2 Various Link Defects
Defect Cause/Meaning Defect Source Effect Recovery
NO_OPTICS Optics is not present Optics Port is receiving LOS. Link Down. Insert an Optics
TX_FAULT Optics is reporting TX Fault. Optics TX Laser is not healthy. Optics Port Link is down. Far-‐end may be down due to LOS. Try port ‘shut’ followed by ‘no shut’. Try Optics OIR. If it doesn’t solve the issue, replace the Optics.
MOD_NOT_RDY Optics is reporting Module Not Ready. Optics TX laser or PHY clocking issue. Optics Port Link is down. Far‐end may go down due to RFI. Try port ‘shut’ followed by ‘no shut’. Try Optics OIR. If it doesn’t solve the issue, replace the Optics.
RX_LOS Optics is receiving Loss-‐of-‐ Signal. This will cause MAC Local Fault (LF) and PHY LASI. Optics Port Link is down. Far-end may go down due to RFI. Check the fiber; check whether far-end port is ‘no shut’.
XCVR_SECURITY Not a Cisco supported Optics. Security check failed. Optics Port Link is down. Optics Transmit Laser is disabled. Far-end will see LOS. Try Optics OIR. Use ASR9k supported Optics. If it is 3rd party Optics, you may try ‘service unsupported’.
SFP_HW_LINK Copper/100FX Transceiver PHY is reporting Link Down Optics Port Link is down. Far-end may be down too. Try Optics OIR. Check cable/fiber. Ensure both ends has matching autoneg, speed, flowcontrol commands. For 100FX, configure ‘no autoneg’ and ‘speed 100’ on both sides.
XCVR_PID_UNSUP Optics Product ID is not supported for ASR9k. Optics Port Link is down. Optics TX laser is disabled. Far‐end will see LOS. Try Optics OIR. If it is a 3rd party Optics, try port ‘transceiver permit pid all’ command.
XCVR_TYPE_UNSUP Not a correct Optics type for this port. Instead of SFP+, a SFP is inserted in a 10GE port. Optics Port Link is down. Optics TX laser may be disabled. Far‐end may see LOS. Check and replace the Optics. If it is a 3rd party Optics, try ‘service unsupported’
UNSUP_CFG User has configured an unsupported command. For example, ‘autoneg’ is configured for 100FX or ‘speed’ is configured for 1GE Optical SFP Optics Port Link is down. Optics TX laser is disabled Remove the unsupported port command.
LASI
PHY TX/RX link is DOWN (because of RX_LOS/PCS/PMA layers DOWN). If it is a 10GE/40GE port, then 'sh controllers tenGigE <> xgxs' provides additional information
PHY Port Link is disabled. If MAC is seeing HW_LINK defect, then far-end may get RFI. Try Optics OIR, shut/no shut. Check health of fiber and Optics. If the Optics is DOM supported, ‘sh controller <> phy’ will provide TX/RX Power information. Also, check port configuration at both ends.
HW_LINK MAC is seeing local fault. MAC RX link is DOWN (because of RX_LOS/PCS/PMA layers DOWN) MAC Port Link is down. Far-end may be get Remote Fault. Try Optics OIR and shut/no shut. Check health of fiber and Optics. If the Optics is DOM supported, ‘sh controller <> phy’ will provide TX/RX Power information. Also, check port configuration at both ends.
RFI MAC is seeing Remote fault. Far-‐end is seeing Local Fault. MAC Port Link is down. Far-end may be getting Local Fault. Try shut/no shut and Optics OIR. Problem may be with Optics Transmit or TX fiber. Check whether near-‐ end has enabled TX laser. Use ‘sh controller <> {internal | phy}.
AUTO_NEG Specific to 1GE port. Auto- negotiation is not complete MAC/PHY Port Link is down. Try shut/no shut and Optics OIR. Check the health of Optics, Fiber. Check port configuration both sides.
FIA_INIT Fabric is not ready to receive (some initialization issue). Fabric All ports are down. Line Card reload may recover.
FIA_SHUTDOWN Fabric is shutdown Fabric All ports are down. Line Card reload may recover
G709_LICENSE No G.709 license is available G.709 Software License Warning message License has expired or not available. Buy, new license.
ADV_OPT_PIE Advanced Optics Pie is not installed. G.709 Software License Port transmit is disabled. Port Link is down. Install Advanced Optic Pie
DWDM_LASER_SHUT Port is in OTN mode but TX laser is disabled by Software OTN Port transmit is disabled. Port Link is down. Configure ‘admin-‐state in-‐service’ under ‘controller dwdm <>’.
WANPHY_SD_SF_BER Link is down because of Signal Fail (SF) alarm from WAN PHY. If the rate of B2 BIP error is above the SF configured threshold, the above defect is raised WAN PHY Port transmit is disabled. Port Link is down. Use ‘sh controller wanphy <>’ to check B2 BIP error counts. If it is increasing, then check whether far-end is configured for WAN PHY mode. Check the health of Optics and Fiber.
MODE_CHANGE Port transmit is disabled momentarily during mode change. (lan/wanphy/otn changed using 'transport-mode <>'under 'interface tengig<>') PHY Port Link is down. Far-end may flap due to clock configuration change. Internal software change and reconfig of PHY and clocking logic. Will clear after few minutes.
packet-gap non-standard
By default, Ethernet port operates at default Inter-frame-gap (IFG) of 12 bytes.
If the Far-end system needs a non-standard IFG, then the following CLI can be used to change IFG to 16 bytes. This CLI is supported only for10GE port.
RP/0/RSP0/CPU0:ios(config)#int tenGigE 0/6/0/0
RP/0/RSP0/CPU0:ios(config-if)#packet-gap non-standard
small-frame-padding
The following CLI allows ASR 9000 to pad Transmit/Egress Frames smaller than 68-bytes to 68 bytes (including CRC). This CLI is supported only for Second Generation Line Cards starting from 4.3.1 IOS XR Release.
RP/0/RSP0/CPU0:ios(config-if)#small-frame-padding
loopback
ASR 9000 supports the following loopback types for debugging purpose.
For 1GE/100GE, the loopback takes place at MAC whereas for 10GE/40GE, it is done at PHY.
RP/0/RSP0/CPU0:ios(config-if)#loopback ?
  external  Enable external loopback (requires loopback connector)
  internal  Enable internal loopback
  line      Enable line loopback
Loopback external (Applicable only to RJ45 SFP)
Configure ‘loopback external’, when a port is operating at 1000 Mbps Speed using an external loopback plug. With speed 10 Mbps or 100 Mbps, external loopback plug will work fine without the below configuration.
RP/0/RSP0/CPU0:ios(config-if)#loopback external
carrier-delay
The interface configuration command ‘carrier-delay’ is used to delay the processing of hardware link down/up notifications. By default, without any  ‘carrier-delay’ configuration, the hardware allows faster link-down notification for signal failure condition such as LOS. To allow soaking time against noise causing link flap, ‘carrier-delay {up | down) <msec>’ may be used. For some Line Cards, the Link UP may take several seconds since clock stabilization occurs when the receive signal state changes from LOS to normal.
RP/0/RSP0/CPU0:ios(config-if)#carrier-delay ?
  down  Set the carrier delay down value
  up    Set the carrier delay up value
RP/0/RSP0/CPU0:ios(config-if)#carrier-delay down ?
  <0-2147483647>  Delay in milliseconds
Optic Pie
To use the following features, ‘asr9k-optic-px.pie’ needs to be installed. Without Optic Pie, the link is brought down and also Transmit Laser is disabled.
  • OTN mode in 10G port
  • OTN mode in 40G port
  • LAN Proactive Protection in 100G port
Optics DOM
DOM feature is supported only on Optics that provides this functionality (Ref. 5).  Software periodically collects the following sensor data from supported Optics.
  • Transceiver Temperature
  • Transceiver power supply voltage
  • Transceiver Bias Current
  • Transceiver Transmit Power
  • Transceiver Receive Power
The alarms and warnings available for each of the above sensors are read from Optics EEPROM.
  • High Alarm
  • Low Alarm
  • High Warnin
  • Low Warning
Line Card sends a message to RSP which in turn will raise a CISCO-ENTITY-SENSOR-MIB SNMP trap for the corresponding alarm or warning. Alarms are of major severity while warnings are of minor severity for MIB. The following CLI can be used to show DOM data.
RP/0/RSP0/CPU0:ios#sh controllers gigabitEthernet 0/5/0/1 phy
< snip>
        Temperature: 40.055
        Voltage: 3.265 Volt
        Tx Bias: 9.464 mAmps
        Tx Power:  0.344 mW (-4.64 dBm)
        Rx Power:  0.260 mW (-5.85 dBm)
        Oper. Status/Control: Rx Rate Select,
1GE Interface
LAN Mode
This is the default mode for a 1GE port. The following CLIs can be used to check the status of a given port.
RP/0/RSP0/CPU0:ios#sh int gigabitEthernet 0/5/0/39
GigabitEthernet0/5/0/39 is up, line protocol is up
RP/0/RSP0/CPU0:ios#sh controllers gigabitEthernet 0/5/0/39 internal
Port Number       : 39
Port Type         : GE
BIA MAC addr      : 001d.e5eb.8d17
Oper. MAC addr    : 001d.e5eb.8d17
Egress MAC addr   : 001d.e5eb.8d17
I/F Handle        : 0x0e000a80
H/W Tx Enable     : yes                        <<<< Optics Laser is Enabled
UDLF enabled      : no
SFP PWR DN Reason : 0x00000000
SFP Capability    : 0x000000e7
MTU               : 1526
H/W Speed         : 100 Mbps
H/W Duplex        : Full
H/W FlowCtrl type : None
H/W AutoNeg Enable: Off
H/W Link Defects  : (0x00000000) None          <<<< No Defects
Link Up           : yes                        <<<< Port Link is Up
Input good underflow          : 0
Input ucast underflow         : 0
Output ucast underflow        : 0
Input unknown opcode underflow: 0
Pluggable Type      : 1000BASE-T               <<<< RJ45 SFP is present
Pluggable Compl.    : Compliant                <<<< Passed Security Check
Pluggable Type Supp.: Supported                <<<< Passed Optics Type Check
Pluggable PID Supp. : Supported                <<<< Passed PID check
Pluggable Scan Flg: false
Uni-directional link Fault
Uni-directional Link Fault detection (UDLF) is a feature of 802.3 OAM that allows a host that detects a fault on the RX channel of a link to notify the peer via an 802.3 OAM message, so that the peer can disable the interface. In 10/40/100GE, when a Near-end port receives LOS, MAC sends Remote Fault (RF) to Far-end so that port is brought down.  But, in case of 1GE, RF is not defined as a standard. So, this will cause Far-end port to stay UP even when a Near-end port is DOWN. By enabling UDLF feature at both ends, the Near-end notifies Far-end with OAM message whenever the port link is down due to LOS.
Configuration to Enable UDLR:
interface GigabitEthernet0/6/0/2
ethernet oam
  uni-directional link-fault detection
  action
   uni-directional link-fault efd
Optics
Only ‘Full-duplex’ operation is supported since ‘Half-duplex’ capability is not available in MAC. It is to be noted that the default configuration is ‘no negotiation’ which means Auto-negotiation is turned off. Please enable ‘negotiation auto’ in 1GE port if auto-negotiation is enabled at Link Partner  (Far-end) port.
Enable Auto-negotiation:
RP/0/RSP0/CPU0:ios(config-if)#negotiation auto
Disable Auto-negotiation:
RP/0/RSP0/CPU0:ios(config-if)#no negotiation auto
1GE Optical SFP
With 1GE fixed Speed Optical SFP, ‘negotiation auto’ and ‘no negotiation auto’ are supported, it’s mandatory that both Near and Far-ends have matching configuration.
But, it is recommended to use Auto-negotiation (AN) at both ends to ensure Speed, Flow-control (FC) and Master/Slave are negotiated and resolved.
Near-end Resolved Speed for Optical SFP
Auto‐negotiation Near‐end (Config) Far‐end (Config) Near‐end (Result)
ON None (Advertise Speed 1000, Full‐duplex) None 1000 Mbps (Resolved)
OFF Speed 1000 Speed 1000 1000 Mbps
Near-end Resolved Flow-control for Optical SFP
ON Ingress None None
ON Bidirectional None None
ON Bidirectional Ingress Bidirectional
ON Ingress Ingress None
ON Ingress Bidirectional Ingress
Resolved Speed and Flow-control with Autoneg:
RP/0/RSP0/CPU0:ios#sh controllers gigabitEthernet 0/5/0/8 internal
Port Number       : 8
Port Type         : GE
Transport mode    : LAN                      <<<<  LAN Mode
BIA MAC addr      : 001d.e5eb.8cf8
Oper. MAC addr    : 001d.e5eb.8cf8
Egress MAC addr   : 001d.e5eb.8cf8
I/F Handle        : 0x0e0002c0
H/W Tx Enable     : yes                      <<<< Optics TX Laser Enabled
UDLF enabled      : no
SFP Capability    : 0x00000024
MTU               : 1526
H/W Speed         : 1 Gbps
H/W Duplex        : Full
H/W AutoNeg Enable: On                       <<<< Autoneg Enabled
H/W AutoNeg Mask  : None (0x0000)
H/W AutoNeg Speed : Unknown (0)
H/W AutoNeg Duplex: Invalid (0)
H/W AutoNeg FlowC : None (0)
Resolved AutoNeg Mask  : None (0x0000)       <<<< Autoneg Resolved State
Resolved AutoNeg Speed : 1 Gbps (3)
Resolved AutoNeg Duplex: Full (2)
Resolved AutoNeg FlowC : None (0)
Local Autoneg RFI : None                     <<<< Autoneg Local end configuration
Local Autoneg Pause : Asym (Ingress)
Local Autoneg Speed : 1Ge Full
Local Autoneg Speed Mask : 1Gb
Local Autoneg Duplex Mask : full
Link Partner Autoneg RFI : None              <<<< Autoneg Far-end configuration
Link Partner Autoneg Pause : None
Link Partner Autoneg Speed : 1Ge Full
Link Partner Autoneg Speed Mask : 1Gb
Link Partner Autoneg Duplex Mask : full
Link Up           : yes                      <<<< Link is UP
Link Led Status   : Link up   -- Green/Amber <<<< LED is Green
Pluggable Type      : 1000BX-10-D
RP/0/RSP0/CPU0:ios#sh int gigabitEthernet 0/5/0/8
GigabitEthernet0/5/0/8 is up, line protocol is up
  Interface state transitions: 15
  Hardware is GigabitEthernet, address is 001d.e5eb.8cf8 (bia 001d.e5eb.8cf8)
  Internet address is Unknown
  MTU 1514 bytes, BW 1000000 Kbit (Max: 1000000 Kbit)
     reliability 255/255, txload 0/255, rxload 0/255
  Encapsulation ARPA,
  Full-duplex, 1000Mb/s, link type is autonegotiation         <<<< Autoneg ON, Speed 1000 Mbps
  output flow control is off, input flow control is off       <<<< Flow-control OFF
  loopback not set,
  Last input 1d07h, output never
     6 packets input, 360 bytes, 2 total input drops
     0 drops for unrecognized upper-level protocol
     Received 6 broadcast packets, 0 multicast packets
              0 runts, 0 giants, 0 throttles, 0 parity
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 total output drops
     Output 0 broadcast packets, 0 multicast packets
     0 output errors, 0 underruns, 0 applique, 0 resets
     15 carrier transitions
Copper/RJ45 SFP
Copper SFP is a PHY based SFP that allows 10/100/1000 Mbps of Speed and Flow-control configuration whether Auto-negotiation is enabled are not. But, it is recommended to use Auto-negotiation (AN) at both ends to ensure Speed, Flow-control (FC) and Master/Slave are negotiated and resolved.
Near-end Resolved Speed for Copper SFP
Auto-negotiation (Both Sides) Near-end (Config) Far-end (Config) Near-end (Result)
ON None (Advertise Speed 1000/100/10, Full-duplex) None 1000
ON None (Advertise Speed 1000/100/10, Full-duplex) Speed 1000 1000
ON None (Advertise Speed 1000/100/10, Full-duplex) Speed 100 100
ON None (Advertise Speed 1000/100/10, Full-duplex) Speed 10 10
ON Speed 1000 None 1000
ON Speed 100 None 100
ON Speed 10 None 10
OFF Speed 100 Speed 100 100
OFF Speed 10 Speed 10 10
Resolved Speed and Flow-control with Autonegotiation:
RP/0/RSP0/CPU0:IOS#sh int gigabitEthernet 0/5/0/34
GigabitEthernet0/5/0/34 is up, line protocol is up
  Interface state transitions: 5
  Hardware is GigabitEthernet, address is 001d.e5eb.8d12 (bia 001d.e5eb.8d12)
  MTU 1514 bytes, BW 100000 Kbit (Max: 100000 Kbit)
  Encapsulation ARPA,
  Full-duplex, 100Mb/s, THD, link type is autonegotiation       <<<< Resolved Speed
  output flow control is off, input flow control is on          <<<< Resolved Flow-control
  loopback not set,
  Last input 00:00:00, output 00:00:00
     1875 packets input, 395625 bytes, 0 total input drops
     Received 0 broadcast packets, 1875 multicast packets
     1875 packets output, 395625 bytes, 0 total output drops
     Output 0 broadcast packets, 1875 multicast packets
100FX Optical SFP
GLC-GE-100FX is a PHY based Optical SFP. Auto-negotiation is not supported but ‘speed 100’ needs to be configured.
RP/0/RSP0/CPU0:ios(config-if)#speed 100
CWDM/DWDM SFP
1GE port supports several CWDM and DWDM Optics (Ref. 3).
GLC-BX10-U/D SFP
GLC-BX-D and GLC-BX-U Optics (Ref. 10) operate with single strand using Single Mode Fiber (SMF). GLC-BX-D transmits 1490-nm and receives 1310-nm wavelength, whereas GLC-BX-U receives 1490-nm and transmits 1310-nm wavelength signal. Bi-directional communication is achieved with integrated Wavelength-division multiplexing (WDM) splitter inside the optics. This optics also provides Digital optical monitoring (DOM) support. No special configuration is needed to operate this SFP.
RP/0/RSP0/CPU0:ios#sh running-config interface gigabitEthernet 0/5/0/8
interface GigabitEthernet0/5/0/8
negotiation auto
RP/0/RSP0/CPU0:ios#sh running-config interface gigabitEthernet 0/5/0/9
interface GigabitEthernet0/5/0/9
negotiation auto
<snip>
RP/0/RSP0/CPU0:ios#sh controllers gigabitEthernet 0/5/0/9 internal
<snip>
Pluggable Type      : 1000BX-10-U
RP/0/RSP0/CPU0:ios#sh controllers gigabitEthernet 0/5/0/8 phy
SFP EEPROM  port:8
        Xcvr Type: SFP
        Xcvr Code: 1000BX-10-D
        Encoding: 8B10B
        Bit Rate: 1300 Mbps
        Link Reach 9u fiber (Km): 10000 meter
        Link Reach 9u fiber (100m): 10000 meter
        Vendor Name: CISCO-FIBERXON
        Vendor OUI: 00.1f.22
        Vendor Part Number: 9912C-SL10G-CIC  (rev.: 10  )
        Laser wavelength: 1490 nm (fraction: 0.00 nm)
<snip>   ** DOM Data **
        Temperature: 37.719
        Voltage: 3.265 Volt
        Tx Bias: 17.104 mAmps
        Tx Power:  0.311 mW (-5.07 dBm)
        Rx Power:  0.352 mW (-4.54 dBm)
10GE Interface
LAN Mode
This is default mode of operation.
WAN PHY Mode
PHY device maps 10GE LAN streams to STS-192c SPE and this limits the data-rate to 9.584 Gbps. WAN PHY provides rich SONET OAM capabilities for link management. It is to be noted that WAN PHY line-rate is lower than 10GE LAN rate (10.3125 Gbps). When WAN PHY mode is configured, transmit Inter-frame-gap (IFG) is set to 16 bytes instead of default 12 bytes in MAC.
LAN to WAN PHY Configuration
RP/0/RSP0/CPU0:ios#sh running-config interface tenGigE 0/6/0/0
interface TenGigE0/6/0/0
transport-mode wan
RP/0/RSP0/CPU0:IOS#sh running-config controller wanphy 0/6/0/0
controller wanphy0/6/0/0
wanmode on
WAN PHY to LAN Mode
RP/0/RSP0/CPU0:ios(config-if)#no transport-mode
WAN PHY Alarm Status
RP/0/RSP0/CPU0:IOS#sh controllers wanphy 0/6/0/0 alarms
Interface: wanphy0/6/0/0
Configuration Mode: WAN Mode
SECTION
  LOF = 2, LOS = 2, BIP(B1) = 0
LINE
  AIS = 0, RDI = 0, FEBE = 0, BIP(B2) = 0
PATH
  AIS = 0, RDI = 0, FEBE = 0, BIP(B3) = 0
  LOP = 0, NEWPTR = 0, PSE = 0, NSE = 0
WIS ALARMS
  SER = 263414, FELCDP = 0, FEAISP = 0
  WLOS = 2, PLCD = 2
  LFEBIP = 0, PBEC = 0, PLMP = 0
Active Alarms[All defects]: los, lof, sef,
Active Alarms[Highest Alarms]: los
  Rx(K1/K2): N/A, Tx(K1/K2): N/A
  S1S0 = N/A, C2 = N/A
PATH TRACE BUFFER
Remote IP addr:
BER thresholds: SF = 10e-3 SD = 10e-6
TCA thresholds: N/A
Alarm reporting enabled for:los, lof, lop
Layered Alarm Status (Optics, PHY, MAC)
(Note: This CLI is applicable only for 10GE port in Second Generation Line Card)
RP/0/RSP0/CPU0:ios#sh controllers tenGigE 0/6/0/0 xgxs
  OPTICS:
   Rx LOS Fault       : Yes
   Tx Fault           : No
  PHY:
   Tx Align Fault     : No
   PMA/PMD:
    Rx LOS Fault      : Yes
    Rx PMA link Fault : Yes
   WANPHY Mode:
    SECTION:
     Los: Yes, Lof: Yes
    LINE:
     Ais: No, Rdi: No
    PATH:
     Ais: No, Lop: No
     Plm: No, Lcd: No
   PCS:
    Rx PCS link Fault : Yes
    Rx PCS lock Fault : Yes
  MAC:
   Rx Local Fault     : Yes
   Rx Remote Fault    : No
SD/SF BER
Software sets Signal Degrade (SD) and Signal Fail (SF) thresholds to 10e-3 and 10e-6 respectively.
RP/0/RSP0/CPU0:ios#sh controllers wanphy 0/6/0/0 alarms | inc SD
SD/SF BER threshold is configurable using ‘threshold’ command.
Software monitors B2 BIP errors and asserts SD/SF BER alarms whenever the error-rate exceeds the threshold. Port link will go down once BIP error-rate exceeds SF BER threshold.
Threshold configuration:
RP/0/RSP0/CPU0:ios(config)#controller wanphy 0/6/0/0
RP/0/RSP0/CPU0:ios(config-wanphy)#threshold ?
  sd-ber  Set Signal Degrade BER threshold
  sf-ber  Set Signal Fail BER threshold
Alarm reporting configuration
RP/0/RSP0/CPU0:ios(config-wanphy)#report ?
  line-ais     Set Line Alarm Indication Signal reporting status
  lof          Set Loss of Frame reporting status
  lop          Set Loss Of Pointer reporting status
  los          Set Loss of Signal reporting status
  path-ais     Set Path Alarm Indication Signal reporting status
  path-fe-ais  Set Path Far End Alarm Indication Signal reporting status
  path-fe-plm  Set Path Far End Label Mismatch reporting status
  path-lcd     Set Loss Of Code-Group Delineation reporting status
  path-plm     Set Path Payload Label Mismatch reporting status
  path-rdi     Set Path Remote Defect Indication Signal reporting status
  rdi          Set Remote Defect Indicator reporting status
  sd-ber       Set LBIP BER in excess of SD threshold reporting status
  sf-ber       Set LBIP BER in excess of SF threshold reporting status
Also, link will go down if any of the following alarm is asserted.
LOS, LOF, AIS-L, AIS-P, LOP-P, UNEQ-P.
OTN Mode
10GE LAN traffic is mapped to OPU2e or OPU1e containers. OTN provides Forward Error Correction (FEC) feature in addition to SONET like OAM capabilities.
asr9k-optic-px.pie is needed to operate in OTN mode.
Optics Transmit Laser will be disabled if Pie is not installed and activated.
LAN to OPU2e Configuration:
RP/0/RSP0/CPU0:ios(config-if)#transport-mode otn bit-transparent ?
  opu1e  10GBASE-R over OPU1e without fixed stuffing (11.0491Gb/s)
  opu2e  10GBASE-R over OPU2e with fixed stuffing (11.0957Gb/s)
 transport-mode otn bit-transparent opu2e
RP/0/RSP0/CPU0:ios#sh running-config controller dwdm 0/6/0/0
controller dwdm0/6/0/0
 admin-state in-service
OPU2e to LAN mode
OTN Alarm Status
RP/0/RSP0/CPU0:ios#sh controllers dwdm 0/6/0/0 g709
OTU
         LOS  = 1           LOF  = 0           LOM  = 0
         BDI  = 0           IAE  = 0           BIP  = 0
         BEI  = 0           TIM  = 0
ODU
         AIS  = 0           BDI  = 0           OCI  = 0
         LCK  = 0           BIP  = 0           BEI  = 0
         PTIM = 0           TIM  = 0
FEC Mode: Standard  (Default)
         EC(current second) = 0           EC   = 0           UC   = 0
         pre-FEC BER < 9.34E-11           Q > 6.45           Q Margin > 6.09
Remote FEC Mode: Unknown
         FECMISMATCH = 0
Detected Alarms: LOS
Asserted Alarms: LOS
Alarm Reporting Enabled for: LOS LOF LOM IAE OTU-BDI OTU-TIM OTU_SF_BER OTU_SD_BER ODU-AIS ODU-BDI OCI LCK PTIM ODU-TIM ODU_SF_BER ODU_SD_BER FECMISMATCH
BER Thresholds: OTU-SF = E-3  OTU-SD = E-6
                ODU-SF = E-3  ODU-SD = E-6
(Note: This CLI is applicable only to 10 port in Second Generation Line Card)
  OPTICS:
   Rx LOS Fault       : Yes
   Tx Fault           : No
  PHY:
   Tx Align Fault     : No
   PMA/PMD:
    Rx LOS Fault      : Yes
   OTU2 Mode:
    OTU:
     Los: Yes, Oof: Yes, Lof: Yes
     Lom: Yes, Oom: Yes
     Ais: No, Iae: Yes
     Bdi: Yes, Tim: No
    ODU:
     Bdi: Yes, Ais: No, Lck: No
     Oci: No, Tim: No, Ptim: Yes
   PCS:
  MAC:
Supported FEC Modes
RP/0/RSP0/CPU0:ios(config)#controller dwdm 0/6/0/0
RP/0/RSP0/CPU0:ios(config-dwdm)#g709 fec ?
  disable    Disable FEC
  enhanced   Enhanced FEC mode
  high-gain  High Gain FEC mode
  long-haul  Long Haul FEC mode
  standard   Standard FEC mode
RP/0/RSP0/CPU0:ios(config-dwdm)#g709 fec enhanced ?
  i.4  efec i.4
  i.7  efec i.7
Table 6 Supported FEC modes on 10G
Configuration FEC Modes (Second Generation Line Card) FEC Mode (First Generation Line Card)
g709 fec standard ITU G.975 (GFEC) default ITU G.975 (GFEC) default
g709 fec enhanced i.4 ITU G.975, I.4 (EFEC) ITU G.975, I.4 (EFEC)
g709 fec enhanced i.7 ITU G.975, I.7 (UFEC) Not Supported
g709 disable No FEC No FEC
g709 fec high-‐gain Not Supported Not Supported
g709 fec long-‐haul Not Supported Not Supported
Loopback
When a port is in OTN mode, loopback is configured under ‘controller dwdm’.
RP/0/RSP0/CPU0:ios(config-‐dwdm)#loopback ?
  internal Select internal loopback mode line Select line loopback mode
Performance Monitoring (PM) configuration
RP/0/RSP0/CPU0:ios(config-‐dwdm)#pm ?
  15-‐min   Configure pm parameters of 15 minute interval
  24-‐hour  Configure pm parameters of 24 hour interval
RP/0/RSP0/CPU0:ios(config-‐dwdm)#pm 15‐min ?
fec Configure fec g709 performance monitoring optics Configure optics performance monitoring otn Configure otn g709 performance monitoring RP/0/RSP0/CPU0:ios (config-‐dwdm)#pm 15‐min fec ? report set fec TCA reporting status
threshold Configure fec threshold
Show Performance Monitoring Information
RP/0/RSP0/CPU0:ios#sh controllers dwdm 0/6/0/0 pm interval ?
  15-min   Show pm data in 15 minute interval
  24-hour  show pm data in 24 hour interval
RP/0/RSP0/CPU0:ios#sh controllers dwdm 0/6/0/0 pm history ?
  15-min   show all pm data in 15 minute interval
  24-hour  show all pm data in 24 hour interval
  fec      show all fec data in 15 minute and 24 hour interval
  optics   show all optics data in 15 minute and 24 hour interval
  otn      show all otn data in 15 minute and 24 hour interval
  |        Output Modifiers
  <cr>
With ‘Proactive Protection’ feature enabled, software monitors FEC errors for the configured threshold and notifies upper-layer protocols once the error-rate crosses the threshold.
RP/0/RSP0/CPU0:ios(config-dwdm)#admin-state out-of-service
RP/0/RSP0/CPU0:ios(config-dwdm)#commit
RP/0/RSP0/CPU0:ios(config-dwdm)#proactive
RP/0/RSP0/CPU0:ios(config-dwdm)#admin-state in-service
BER threshold
RP/0/RSP0/CPU0:ios(config-dwdm)#proactive ?
  revert   Configure Revert thresholds
  trigger  Configure trigger thresholds
  <cr>
RP/0/RSP0/CPU0:ios#sh controllers dwdm 0/6/0/0 proactive
Proactive Protection Status: ON
Proactive Protection State: Normal -Interface is Up
Inputs affecting proactive protection state:
        Transport admin state         : In Service
        Trigger threshold             : 6E-5    (Default 6E-5)
        Revert threshold              : 1E-5    (Default 1E-5)
        Trigger integration window    : 30 ms
        Revert integration window     : 20000 ms
        Received APS                  : 0x0f (No Request)
        Transmitted APS               : 0x0f (No Request)
SD/SF BER
Signal Degrade (SD) and Signal Failure (SF) threshold can be configured in OTU and ODU layers. Software monitors BIP errors from OTU and ODU layers for raising Alarms. Port link will go down for if BIP error rate exceeds SF threshold.
The default BER thresholds are given below.
SD/SF BER threshold configuration
RP/0/RSP0/CPU0:ios(config-dwdm)#g709 otu ?
  overhead   Configure OTU overhead
  report     Configure OTU alarm reporting
  threshold  Configure OTU threshold value
RP/0/RSP0/CPU0:ios(config-dwdm)#g709 otu threshold ?
  sf-ber  Set Signal Failure BER threshold
RP/0/RSP0/CPU0:ios(config-dwdm)#g709 odu ?
  overhead   Configure ODU overhead
  report     Configure ODU alarm reporting
  threshold  Configure ODU threshold value
RP/0/RSP0/CPU0:ios(config-dwdm)#g709 odu threshold ?
Unidirectional Link Routing
The Unidirectional Link Routing (UDLR) feature is currently supported only in 10GE LAN mode only. It allows a physical port to receive or transmit data with a single fiber.‘transport-mode {rx-only | tx-only}’ CLI is used for this purpose.
RP/0/RSP0/CPU0:ios(config-if)#transport-mode ?
  rx-only  10GE UDLR Mode, Receive Only
  tx-only  10GE UDLR Mode, Transmit Only
Optics
SR/LR/ER/ZR/DWDM Optics
Ref. 3 for all ASR 9000 supported XFP and SFP+ Optics.
Tunable Optics
Ref. 9 provides the specification for Tunable DWDM XFP.  This Optics allows 80 DWDM ITU-50GHz channels for tuning.
ASR 9000 follows CRS-1 for ‘wavelength’ to Channel mapping. Please use ‘sh controller dwdm <> wavelength-map’ CLI to see the correct channel to wavelength mapping.
RP/0/RSP0/CPU0:ios#show controllers dwdm 0/6/0/7 wavelength-map
Wavelength band: C-Band
MSA ITU channel range supported: 3~84
Wavelength map table
ITU Ch   G.694.1   Frequency     Wavelength
Num     Ch Num       (THz)            (nm)
     3    58              196.00          1529.553
     4    57              195.95          1529.944
     5    56              195.90          1530.334
     6    55              195.85          1530.725
     7    54              195.80          1531.116
<snip>
    80   -19              192.15          1560.200
    81   -20              192.10          1560.606
    82   -21              192.05          1561.013
    83   -22              192.00          1561.419
    84   -23              191.95          1561.826
To get 1531.116 nm, ‘Wavelength 7’ will be configured.
RP/0/RSP0/CPU0:IOS(config)#controller dwdm 0/6/0/7
RP/0/RSP0/CPU0:IOS(config-dwdm)#wavelength 7
RP/0/RSP0/CPU0:IOS(config-dwdm)#commit
Instead of Channel Number, desired frequency can be configured using ‘wavelength frequency <>’ command.
RP/0/RSP0/CPU0:IOS(config-dwdm)#wavelength frequency ?
  <19115-19610>  Enter 5-digit Frequency data; e.g. 19580 for 195.8 THz
40GE Interface
40GE Modular Port Adapter (MPA) implements 40GE LAN and 40GE mapped onto OTU3 (43.0184 Gbps) modes. It also supports G.709 OTN OTU3 framing with triple FEC (GFEC (Reed-Solomon), EFEC (G.975.1, I.4) and UFEC (G.975.1, 1.7)).
LAN Mode
This is the default mode for the MPA.
RP/0/RSP0/CPU0:IOS#sh int fortyGigE 0/0/0/0
FortyGigE0/0/0/0 is up, line protocol is up
  Hardware is FortyGigE, address is 0022.bde5.aaec (bia 0022.bde5.aaec)
  Layer 1 Transport Mode is LAN
OTN Mode
To change Transport mode from LAN to OTU3 (43.0184 Gbps), use ‘g709 enable’ CLI.
To revert back to LAN mode, ‘no g709 enable’ needs to be configured.
Optics Transmit Laser will be disabled if PIE is not installed and activated.
If a port is in OTU3 mode, then ‘admin-state out-of-service’ configuration is needed before moving to any other command. G.709 Optics pie and License are needed to support OTU3 mode.
Change from LAN to OTU3
RP/0/RSP0/CPU0:IOS(config)#controller dwdm 0/0/0/0
RP/0/RSP0/CPU0:IOS(config-dwdm)#g709 enable
RP/0/RSP0/CPU0:IOS(config-dwdm)#admin-state in-service
Change from OTU3 to LAN
RP/0/RSP0/CPU0:IOS(config-dwdm)#admin-state out-of-service
RP/0/RSP0/CPU0:IOS(config-dwdm)#no g709 enable
RP/0/RSP0/CPU0:IOS#sh controllers fortyGigE 0/0/0/0 internal
Tue Apr 30 00:09:44.419 UTC
Port Number         : 0
Board Type          : 0x0000023a
Port Type           : 40GE
Transport mode      : OTN(opu3)
BIA MAC addr        : 0022.bde5.aaec
Oper. MAC addr      : 0022.bde5.aaec
Egress MAC addr     : 0022.bde5.aaec
I/F Handle          : 0x000001c0
H/W Tx Enable       : no
MTU                 : 1526
H/W Speed           : 40 Gbps
H/W Duplex          : Full
H/W Link Defects    : (0x0000202a)  RX_LOS HW_LINK LASI G709_LICENSE
H/W Raw Link Defects : (0x0000202a)  RX_LOS HW_LINK LASI G709_LICENSE
<snip>
Alarm Status
RP/0/RSP0/CPU0:IOS#sh controllers dwdm 0/0/0/0
Tue Apr 30 09:29:16.745 UTC
Port dwdm0/0/0/0
Controller State: Up
Transport Admin State: In Service
Loopback: None
G709 Status
OTU
         BEI  = 0           TIM  = 0
ODU
         PTIM = 0           TIM  = 0
         pre-FEC BER < 2.32E-11           Q > 6.66           Q Margin > 6.37
Remote FEC Mode: Standard
         FECMISMATCH = 0
Detected Alarms: None
Asserted Alarms: None
Connectivity Info
                Network Port ID:  Not Configured
                Network Connection ID:  Not Configured
OTU TTI Sent     String ASCII  : Tx TTI Not Configured
OTU TTI Received String ASCII  : Rx TTI Not Received
OTU TTI Expected String ASCII  : Exp TTI Not Configured
ODU TTI Sent     String ASCII  : Tx TTI Not Configured
RP/0/RSP0/CPU0:ios#sh controllers fortyGigE 0/0/0/0 xgxs
  OPTICS:
   Rx LOS Fault       : No
   Tx Fault           : No
  PHY:
   Tx Align Fault     : No
   PMA/PMD:
    Rx LOS Fault      : No
    Rx PMA link Fault : No
   OTU3 Mode:
    OTL:
     Otl_lol: No, Otl_ola: No, Otl_ola_d: No
     Otl_skew_oor: No, Otl_skew_oor_d: No
    OTU:
     Los: No, Oof: No, Lof: No
     Lom: No, Oom: No
     Ais: No, Iae: No
     Bdi: No, Tim: No
    ODU:
     Bdi: No, Ais: No, Lck: No
     Oci: No, Tim: No, Ptim: No
    GMP:
     Oof_1027b: No, Oof_1027_d: No
     Dec_513b_e: No, Sync_fail: No
   PCS:
    Rx PCS link Fault : No
    Rx PCS lock Fault : No
  MAC:
   Rx Local Fault     : No
Supported FEC Modes
RP/0/RSP0/CPU0:ios(config)#controller dwdm 0/0/0/0
  disable    Disable FEC
  i.4  efec i.4
  i.7  efec i.7
Table 7 Supported FEC modes on 40G
g709 fec standard G.975.1 (GFEC) default
g709 fec enhanced i.4 G.975.1, I.4 (EFEC)
g709 fec enhanced i.7 G.975.1, I.7 (UFEC)
g709 fec disable No FEC
g709 fec high-gain Not Supported
g709 fec long‐haul Not Supported
Loopback
When a port is in OTN mode, loopback is configured under ‘controller dwdm’. as in 10GE ports
Same as in 10GE ports
BER threshold
SD/SF BER
Optics
40GE MPA supports the following Cisco QSFPs.
  • QSFP-40G-SR4 - LAN mode only
  • QSFP-40GE-LR4 - LAN mode only
  • QSFP-40G-LR4 - LAN/OTU3 modes
100GE Interface
LAN Mode
LAN is the default mode for a 100GE port.
LAN PP Mode
In LAN Proactive Protection (PP) mode, ONS M6 terminates OTU4 signal and monitors Forward-error-correction (FEC) errors. Whenever the error-rate exceeds the user-configured threshold, M6 notifies ASR 9000 through a Cisco proprietary signal. This allows fast reroute (FRR) in case of signal deterioration in OTU4 link. asr9k-optic-px.pie is needed to support this feature. Optics Transmit Laser will be disabled if Pie is not installed and activated.
Proactive protection configuration
RP/0/RSP0/CPU0:ios#show run controller dwdm 0/3/0/0
controller dwdm0/3/0/0
proactive
Proactive Status:
RP/0/RSP0/CPU0:ios#show controllers dwdm 0/3/0/0 proactive
Proactive Protection State: Normal -Interface is Up         <<<< proactive intf is up.
G.709 Optics Pie is needed for PP:
RP/0/RSP0/CPU0:RR02#show controllers hundredGigE 0/3/0/0 internal
Port Number         : 0
Board Type          : 0x003b0262
Port Type           : 100GE
Transport mode      : LAN_PP
BIA MAC addr        : 0022.bde5.aaa0
Oper. MAC addr      : 0022.bde5.aaa0
Egress MAC addr     : 0022.bde5.aaa0
I/F Handle          : 0x060000c0
H/W Tx Enable       : no
MTU                 : 1526
H/W Speed           : 100 Gbps
H/W Duplex          : Full
Link Faults         : (0x00008000) G709_LICENSE    <<<< Active alarm when optic pie is absent
Raw Link Faults     : (0x00008000) G709_LICENSE
Link Up             : no
Link Led Status     : Link down -- Red
Pluggable Type      :
Pluggable PID       : CFP-100G-SR10
NP->Mac Lane Sync   : 0x001fffff
PHY->Mac Lane Sync  : 0x000fffff
Mac Version         : 0x00000022
Optics
100GE ports support the following Cisco Supported Optics (Ref. 3).
  • CFP-100G-LR4
  • CFP-100G-SR10
FAQ
Q: 1GE port: Link is not coming up. How do I debug?
  1. Check configuration on both sides (autoneg, speed, flow control) using ‘sh running interface giga <>’
  2. If the Optics are DOM supported, check Optics Power levels using ‘sh controller giga <> phy’
  3. Check the reason for the link failure using ‘sh controller giga <> internal’. Meaning of Link defect is discussed in Table 2.
  4. Also, ensure FPGA images are up-to-date using ‘sh hw-mod location all <>’
Q: 10/100 Mbps with Copper SFP: ARP and ping packets are not received by ASR9k port
SFP-GE-T PHY doesn’t handle odd number of preamble and this will cause silent drop of Ethernet Frames. The issue is not seen with 1000 Mbps. This may happen if the far-end switch is not following IEEE standard for transmission of Preamble.
Q: 10/40/100GE port: Link is not coming up. What do I check?
  1. Check configuration on both sides using ‘sh running interface … <>’
  2. If the Optics are DOM supported, check Optics Power levels using ‘sh controller … <> phy’
  3. Check the reason for the link failure using ‘sh controller … <> internal’
Q: 10/40G OTN mode: Link is not coming up. How do I debug?
  1. Check ‘admin-state in-service’ is configured under ‘controller dwdm’
  2. Check both ends use correct OTN modes
  3. Check both ends use same FEC modes
  4. Check the reason for the link failure using ‘sh controller <> internal’
  5. Check the reason for the defect in Table 2
  6. Ensure Optics pie is installed
  7. Check Optics type used
Q: After LOS cleared, the port link takes several seconds to come up. Is it normal?
Yes, this is normal. When Receive Loss-of-Signal (LOS) state changes to Normal, PHY and clock Logic is reconfigured. Software waits for Clock lock before bringing link Up.
Q: During Line Card reload, link flap occurs. Is it normal?
Yes, this is normal. During Line Card reload, various hardware logics including MAC, PHY and Clocking undergo device configuration. This will cause link flap at Near and Far-ends.
Q: Link Flap occurred during traffic condition. How do I debug?
  1. Check Optics power status using ‘sh controller <> internal’
  2. Check ‘sh interface’ for input errors
  3. Check ‘sh controller <> stat’ for various input errors
  4. If the optical receive power is low, clean or replace the optics and fiber at both ends
  5. Monitor ‘symbol’ and ‘crc’ error count using ‘sh controller <> stat’
  6. If ‘OTN’ mode is used, check ‘sh controller dwdm <>’ for various BIP and other error counts
  7. If ‘WAN’ mode is used, check ‘sh controller wanphy all’ for various BIP and other error counts
  8. Get ‘sh log location <>’ output
If it is a first generation Line Card, then get the trace log
sh ether-ctrl <interface> trace location <location>
If it is a second generation Line Card, then get the following trace log
sh controllers vic ltrace all location <location>
sh controller <interface> reg (need few snap-shots of this command with 3 minute interval)
Q: OTN mode: when a link can be considered “good enough”?
  • UC (uncorrectable cells) is zero on ‘show controller dwdm’ or steady to a value
  • Reported BIP errors are 0
  • reported preFEC-BER smaller than the preFEC-SD (signal degradation) threshold
  • H/W Link Defectsreport “none” in ‘show controller internal’
Q: Tunable Optics: How do I check what ‘wavelength’ is configured in Optics?
RP/0/RSP0/CPU0:ios#sh controllers tenGigE 0/6/0/7 phy | inc Wavelength Control
Wavelength Control: setpoint=1556.50 nm, error=0.00 nm
Also, Configured Optics ‘Channel ID’(Ref. 9) can be obtained from Optics.
RP/0/RSP0/CPU0:SH6#sh controllers tenGigE 0/6/0/7 phy | inc Wavelength Chann
Wavelength Channel: 14
Glossary
CLI
Command Line Interface
EFD
Ethernet Fault Detection
FRR
Fast-reroute to back-up link in case the main data-link fails
OTN
Optical Transport Network
MAC
Media Access Control
PHY
Physical Layer device connects MAC to Optics
Optics
SFP, SFP+, XFP, QSFP+, CFP
SPE
Synchronous Payload Envelope
Related Information
Provided by our Ethernet development Tech Lead Ramki Ramachandran
Atahar Khan
I am looking for customer scenario and gold configuration where ASR9K is connected to DWDM in WAN PHY mode. WAN mode knobs are needed to avoid ASR9k interface flap during DWDM optical link switchover.
Problem Description:
Currently the customer is using 8*10G ports on ASR9K in LAN PHY mode. PCS errors and local faults are seen on ASR9K. ASR9K upon receiving these errors goes for a protocol down status on the interface on which the error is received and debugs shows that there are no knobs available to set the threshold of PCS errors in LAN PHY mode.
Topology:
ASR9K (LAN or WAN Mode) ---------DWDM -------------(3 parallel links)--------------------DWDM--------- (LAN or WAN mode) ASR9K
Information needed:
The LAN PHY mode doesn’t offer any kind of tweaking mechanism based on errors being received and shuts down the interface. It was suggested that customer should tries to use the ASR9K in WAN PhY or OTN mode where knobs can be applied to set threshold for errors on an interface, beyond which the interface will show a protocol down status.
If there any way to set the threshold or count local fault on interface instead of flapping the interface. Alcatel & Huwaie does support this feature to count the error while optical link switch over.
rgarmas89cisco
Hello Alexander,
Do you know that means "AUTO_CMPLT" at the Link defects section for a Gig link which is receiving a RX LOS?
Port Number         : 8
Port Type           : 1GE
BIA MAC addr        : d46d.5050.f6d2
Oper. MAC addr      : d46d.5050.f6d2
Egress MAC addr     : d46d.5050.f6d2
I/F Handle          : 0x040002c0
H/W Tx Enable       : yes
MTU                 : 1526
H/W Speed           : 1 Gbps
H/W Duplex          : Full
H/W AutoNeg Enable  : On
Local Autoneg Pause              : None
Local Autoneg Speed/Duplex       : 1000F
Link Partner Autoneg Speed/Duplex: 1000F
H/W Link Defects    : (0x000000aa)  RX_LOS HW_LINK LASI Port Number         : 8
Port Type           : 1GE
H/W Tx Enable       : yes
MTU                 : 1526
H/W Speed           : 1 Gbps
H/W Duplex          : Full
H/W Link Defects    : (0x000000aa)  RX_LOS HW_LINK LASI AUTO_CMPLT
H/W Raw Link Defects : (0x000000aa)  RX_LOS HW_LINK LASI AUTO_CMPLT
Link Up             : no
UDLF enabled        : no
Pluggable Type      : 1000BASE-LX
Pluggable PID       : SFP-GE-L
Pluggable PID Supp. : (Permit All) - Supported
Roberto
xthuijs
hi roberto,
I had to double check this with the ether driver folks and they told me that the auto_cmplt is for the autonegotiation status.
If it is in the link defects it could mean that autoneg couldnt complete (doesnt state which piece of the nego failed though).
cheers!
xander
Adam Haleen
Hello Xander,
Excellent Document,Very informative.
Quick question, which mode(s) of FEC I.7 can the ASR9k Support?
It looks like the ITU G975.1 I.7 Spec outlines a 7% 11% and a 25% Overhead Modes, Which one does the ASR9K use?
ITU-T Rec. G.975.1 (02/2004)
xthuijs
hi adam,
I had to check in with our hardware development team and ethernet driver guys to find out the specific answer to that. Brent and Scott came back to me mentioning that:
we only support 7% overhead for the enhanced FEC modes at 10G and 40G, so that the physical line rate is the same as GFEC.
xander
Hello Alexander,
Many Thanks for your the quality of your documents as usual, I have an issue with TenGi which displays a huge number of Input error:
Statistics for interface TenGigE0/1/0/0 (cached values):
Ingress:
    Input total bytes           = 16905045734
    Input good bytes            = 16905045734
    Input total packets         = 46476310
    Input 802.1Q frames         = 0
    Input pause frames          = 0
    Input pkts 64 bytes         = 25102838
    Input pkts 65-127 bytes     = 8302698
    Input pkts 128-255 bytes    = 2632730
    Input pkts 256-511 bytes    = 253687
    Input pkts 512-1023 bytes   = 514819
    Input pkts 1024-1518 bytes  = 9669480
    Input pkts 1519-Max bytes   = 43
    Input good pkts             = 46416251
    Input unicast pkts          = 45992847
    Input multicast pkts        = 483440
    Input broadcast pkts        = 23
    Input drop overrun          = 0
    Input drop abort            = 0
    Input drop invalid VLAN     = 0
    Input drop invalid DMAC     = 0
    Input drop invalid encap    = 0
    Input drop other            = 0
    Input error giant           = 0
    Input error runt            = 0
    Input error jabbers         = 14
    Input error fragments       = 1
    Input error CRC             = 54617
    Input error collisions      = 0
    Input error symbol          = 32763976
    Input error other           = 5427
    Input MIB giant             = 43
    Input MIB jabber            = 14
    Input MIB CRC               = 54617
Egress:
    Output total bytes          = 5154374878
    Output good bytes           = 5154374878
    Output total packets        = 46012983
    Output 802.1Q frames        = 0
    Output pause frames         = 0
    Output pkts 64 bytes        = 25078058
    Output pkts 65-127 bytes    = 10488533
    Output pkts 128-255 bytes   = 9265382
    Output pkts 256-511 bytes   = 362123
    Output pkts 512-1023 bytes  = 97775
    Output pkts 1024-1518 bytes = 721095
    Output pkts 1519-Max bytes  = 17
    Output good pkts            = 46012983
    Output unicast pkts         = 45533767
    Output multicast pkts       = 479160
    Output broadcast pkts       = 39
    Output drop underrun        = 0
    Output drop abort           = 0
    Output drop other           = 0
    Output error other          = 0
But The quality of Signal still good, so can't suspect Optic because of below output which displays acceptable values:
        Thresholds:                    Alarm High         Warning High          Warning Low            Alarm Low
              Temperature:            +75.000 C             +70.000 C              +0.000 C              -5.000 C
                  Voltage:           3.630 Volt            3.465 Volt            3.135 Volt            2.970 Volt
                     Bias:         80.000 mAmps          75.000 mAmps          14.000 mAmps          12.000 mAmps
           Transmit Power:  2.239 mW (3.50 dBm)   1.122 mW (0.50 dBm)   0.151 mW (-8.20 dBm)   0.060 mW (-12.20 dBm)
            Receive Power:  2.239 mW (3.50 dBm)   1.122 mW (0.50 dBm)   0.036 mW (-14.40 dBm)   0.015 mW (-18.39 dBm)
        Temperature: 39.754
        Voltage: 3.276 Volt
        Tx Bias: 33.508 mAmps
        Tx Power:  0.537 mW (-2.70 dBm)
        Rx Power:  0.165 mW (-7.82 dBm)
Do I suspect the Fiber (Input error symbol          = 32763976)?
Many Thanks
Could the license causes such issue?:
LC/0/1/CPU0:Dec 14 15:45:32.138 : rsi_agent[311]: %LICENSE-ASR9K_LICENSE-2-INFRA_VRF_NEEDED : 5 VRF(s) are configured without a valid license / license configuration for A9K-iVRF-LIC in violation of the Software Right To Use Agreement. This feature may be disabled by the system without the appropriate license. Contact Cisco to purchase the license immediately to avoid potential service interruption.
LC/0/1/CPU0:Dec 14 21:58:47.062 : ifmgr[200]: %PKT_INFRA-LINK-3-UPDOWN : Interface TenGigE0/1/0/0, changed state to Down
LC/0/1/CPU0:Dec 14 21:58:47.063 : ifmgr[200]: %PKT_INFRA-LINEPROTO-5-UPDOWN : Line protocol on Interface TenGigE0/1/0/0, changed state to Down
Many Thanks
Best Regards
xthuijs
hi abdel, thanks! :) ah I see, you are suffering from symbol and crc errors.
these usually indicate specific layer 1 issues. things you could think about are connecting
a single mode to a multimode optic, having an optic that is a high powered one (for distance) and too short of a cable blinding the other side at times.
the crc errors seem to suggest some impairment happening on the line.
I would replace fiber, optics, and make sure they are matching and if there is an optical network in the middle investigate at that end too.
the vrf license requirement is not causing this problem, the vrf lic is not impairing the optics or anything else crazy other then these syslog messages.
cheers!
xander
bn.thiyagarajan
Hi Xander,
Can ALS(auto laser shutdown) be enabled in any way in asr 9k?.
Warm Regards.
