xthuijs
Introduction
As you know troubleshooting the ASR9000 and XR is close to my heart. In this document we are going to expand on the fabric troubleshooting and operation.
Previous articles have expanded on the NP counters and NP troubleshooting. In this document we'll focus on the fabric specific.
Note this is just the first version of the document. I realize that some commands need to be explained better or what the output really means, but hopefully this gives a good impression to get started on the fabric.
Before we start
For this purpose it is important to know which type of linecard we have, a Trident or Typhoon.
the following cards are Trident based:
40G linecards: A9K-40GE, A9K-2T20G, A9K-4T, A9K-8T/4
80G linecards: A9K-8T, A9K-16T/8
Typhoon cards:
A9K-24x10, A9K-36x10, A9K-MOD80/160, A9K-2x100
This document does not pertain directly to the SIP700 linecard. Although the sip700 interfaces with its own FIA to the RSP fabrics like any other linecard would. Most of the commands for fabric verification can be used due to the fact that the SIP700 has the same FIA as the Trident linecard, but in this reference we are not specifically zooming in on the SIP700.
High level forwarding overview
The following picture gives an overview as to how packets are going from ingress to egress interface/linecard with the different forwarding asics in place.
The article https://supportforums.cisco.com/docs/DOC-15552 deepdived into the NP and its operation and verification.
In this article we're going to get a closer look at the FIA (Fabric interface Asic) and the Fabric itself.
One key thing to notice is here that:
  • Trident does not have a fabric stage on the linecard whereas typhoon does.
  • Typhoon does not have bridge asics.
For forwarding this doesn't really matter in terms of troubleshooting difference.
the reason why Trident has a bridge is because of the memory interfae on the NPU is XAUI whereas the FIA speaks DDR2, the bridge converts in between. It is a non blocking asic, but it can assist with backpressure when it receives it from the fabric.
The reason why Typhoon has a linecard fabric stage is to reduce the number of fabric links. As you can see, all FIA's connect with the fabric chips. High density linecards such as the 24x10 have 4 FIA's and the 36x10 has 6 of them. If all of these FIA's would directly connect to the RSP fabric chips, we'd run out of fabric links in the higher slot chassis such as the 9010.
The linecard fabric stage reduces the number of fabric links.
the 9922 and the 9911 have separate fabric cards. What is drawn here in the picture is the RSP440 (serving 55G per link for typhoon).
Using the 9922/11 with separate fabric cards is not a story changer either, we just have pulled the fab chips off the RSP and called them FC (fabric cards) and RP's (route processors). this gives a higher redundancy due to the ability to serve more fabric cards and higher fabric capacity per slot.
Troubleshooting fabric issues
Steps to debug packet drops
Please follow the below steps for fabric related issues:
Step 1) Look for active PFM alarms on LC as well as RSPs.
     CLI: show pfm location all
Step 2) Check if your hardware FPGA versions are up-to-date
(see also Fabric hardware sanity section)
     CLI: show controllers np summary all
     CLI: admin show hw-module fpd all location all
Step 3) Follow the steps mentioned in packet drop debugging sections
(see Debugging Traffic Issues section).
Step 4) Exclude all "known" related fabric issues
%PLATFORM-PFM_NP-0-TMA_CLUSTER_PARITY
     signifies a hardware error
%PLATFORM-DIAGS-3-PUNT_FABRIC_DATA_PATH_FAILED
     signifies that diag packets from the RP have not been returned properly by the NP hardware. This can either be a software problem or a hardware problem. Check this article and reference for the latest detail to verify and troubleshoot this issue:
%PLATFORM-BRIDGE-3-NPU_0_SCH_MEMP_ERR_0
     was seen on older bridge versions on Trident linecard, make sure the revision of the bridge FPGA is > 0.41 for 40G Trident linecards
     and > 0.5 on the 80G Trident linecards
Visualization of the show commands and what they are checking
Legend:
  • Octopus is the Trident Fabric Interface Asic
  • NPU is Network Processing Unit, the Trident processor
  • Chico is the name of the link between FIA and Fabric (on the RSP), using SERDES.
Legend:
  • SCZ is Santa Cruz, the actual Fabric chip (there are 2 on the RSP4 and RSP440).
  • Octopus is Fabric Interface ASIC. The RSP has one too for the punt path (remember that the RP/CPU is just another linecard to the fabric.
  • BE is Bellagio, that is the Fabric Arbiter.
Data path packet drop debugging
The path a data packet travels is:
Incoming interface on LC--> NPU mapped to incoming interface on LC  --> Bridge3 on LC --> FIA on LC --> Crossbar switch on RSP  --> FIA on LC ---> Bridge3 on LC ---> NPU mapped to outgoing  interface ---> Outgoing Interface
Clear all the counters:
Before beginning to debug traffic issues, please clear all counters and start afresh.
1) Clear Interface counters
RP/0/RSP0/CPU0:ROSH06_jetfire#clear counters all
Thu Jan 1 04:17:32.676 UTC
Clear "show interface" counters on all interfaces [confirm]
2) Clear NP counters
RP/0/RSP0/CPU0:ROSH06_jetfire#clear controller np counters all
3) Clear Fabric counters
To clear FIA counters on LC and RSP:
RP/0/RSP0/CPU0:ROSH06_jetfire#clear controller fabric fia location
To clear all fabric crossbar counters:
RP/0/RSP0/CPU0:ROSH06_jetfire#clear controller fabric crossbar-counters location
To clear bridge counters on LC
Check all the relevant traffic counters
After clearing counters, start traffic pattern that caused the drop.
1) Check the counters at input interface
RP/0/RSP0/CPU0:ROSH06_jetfire#show interfaces tenGigE 0/1/0/0
Thu Jan  1 01:10:01.908 UTC
TenGigE0/1/0/0 is up, line protocol is up
  Interface state transitions: 1
  Hardware is TenGigE, address is 001e.bdfd.1736 (bia 001e.bdfd.1736)
  Layer 2 Transport Mode
  MTU 1514 bytes, BW 10000000 Kbit
     reliability 255/255, txload 0/255, rxload 0/255
  Encapsulation ARPA,
  Full-duplex, 10000Mb/s, LR, link type is force-up
  output flow control is off, input flow control is off
  loopback not set,
  Maintenance is enabled,
  ARP type ARPA, ARP timeout 04:00:00
     0 packets input, 0 bytes, 0 total input drops
     0 drops for unrecognized upper-level protocol
     Received 0 broadcast packets, 0 multicast packets
              0 runts, 0 giants, 0 throttles, 0 parity
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 total output drops
     Output 0 broadcast packets, 0 multicast packets
     0 output errors, 0 underruns, 0 applique, 0 resets
     1 carrier transitions
2) Check NPU counters
RP/0/RSP0/CPU0:ROSH06_jetfire#show controllers NP counters all location
Fields of interest in NPU counters from data path standpoint:
800 PARSE_ENET_RECEIVE_CNT      -- Num of packets received from external interface
970 MODIFY_FABRIC_TRANSMIT_CNT  -- Num of packets sent to fabric
801 PARSE_FABRIC_RECEIVE_CNT    -- Num of packets received from fabric
971 MODIFY_ENET_TRANSMIT_CNT    -- Num of packets sent to external interface
Run the following command to figure out NPU to interface mapping:
RP/0/RSP0/CPU0:ROSH06_jetfire#show controllers np ports all
Thu Jan  1 02:18:48.264 UTC                Node: 0/0/CPU0:
NP Bridge Fia                       Ports
0  1      0   GigabitEthernet0/0/0/30 - GigabitEthernet0/0/0/39
1  1      0   GigabitEthernet0/0/0/20 - GigabitEthernet0/0/0/29
2  0      0   GigabitEthernet0/0/0/10 - GigabitEthernet0/0/0/19
3  0      0   GigabitEthernet0/0/0/0 - GigabitEthernet0/0/0/9
3) Check NPU - Bridge3 counters
RP/0/RSP0/CPU0:ROSH06_jetfire#show controllers np fabric-counters ?
  all  all counters
  rx   receive counters
  tx   transmit counters
RP/0/RSP0/CPU0:ROSH06_jetfire#show controllers np fabric-counters all ?
  all  All NP instances
  np0  NP0 instance
  np1  NP1 instance
  np2  NP2 instance
  np3  NP3 instance
  np4  NP4 instance
  np5  NP5 instance
  np6  NP6 instance
  np7  NP7 instance
RP/0/RSP0/CPU0:ROSH06_jetfire#show controllers np fabric-counters all np0 location <>
Using above CLI you can check the NPU-bridge rx/tx counters for each NPU on a given LC. The fields of interest here are:
xaui_a_t_transmited_packets_cnt -- Num pkt sent by NPU to bridge
xaui_a_r_received_packets_cnt   -- Num pkt sent by bridge to NPU
4) Check Bridge counters
RP/0/RSP0/CPU0:ROSH06_jetfire#show controllers fabric fia bridge stats location <>
Thu Jan 1 02:23:34.163 UTC
UC - Unicast , MC - Multicast
LP - LowPriority , HP - HighPriority
                                 FIA  0
Cast/   Packet            Packet              Error            Threshold
Prio    Direction         Count               Drops            Drops
Unicast Egress Stats
UC HP   Fabric to NP-0    0                   0                0
UC LP   Fabric to NP-0    0                   0                0
UC HP   Fabric to NP-1    0                   0                0
UC LP   Fabric to NP-1    0                   0                0
UC HP   Fabric to NP-2    0                   0                0
UC LP   Fabric to NP-2    0                   0                0
UC HP   Fabric to NP-3    0                   0                0
UC LP   Fabric to NP-3    0                   0                0
UC      Total Egress      0                   0                0
Multicast Egress Stats
MC HP   Fabric to NP-0    0                   0                0
MC LP   Fabric to NP-0    0                   0                0
MC HP   Fabric to NP-1    0                   0                0
MC LP   Fabric to NP-1    0                   0                0
MC HP   Fabric to NP-2    0                   0                0
MC LP   Fabric to NP-2    0                   0                0
MC HP   Fabric to NP-3    0                   0                0
MC LP   Fabric to NP-3    0                   0                0
MC      Total Egress      0                   0                0
Cast/   Packet            Packet
Unicast Ingress Stats
UC HP   NP-0 to Fabric    255
UC LP   NP-0 to Fabric    0
UC HP   NP-1 to Fabric    255
UC LP   NP-1 to Fabric    0
UC HP   NP-2 to Fabric    255
UC LP   NP-2 to Fabric    0
UC HP   NP-3 to Fabric    255
UC LP   NP-3 to Fabric    0
UC      Total Ingress     1020
Multicast Ingress Stats
MC HP   NP-0 to Fabric    0
MC LP   NP-0 to Fabric    0
MC HP   NP-1 to Fabric    0
MC LP   NP-1 to Fabric    0
MC HP   NP-2 to Fabric    0
MC LP   NP-2 to Fabric    0
MC HP   NP-3 to Fabric    0
MC LP   NP-3 to Fabric    0
MC      Total Ingress     0
Ingress Drop Stats (MC & UC combined)
PriorityPacket            Error            Threshold
        Direction         Drops            Drops
LP      NP-0 to Fabric    0                   0
HP      NP-0 to Fabric    0                   0
LP      NP-1 to Fabric    0                   0
HP      NP-1 to Fabric    0                   0
LP      NP-2 to Fabric    0                   0
HP      NP-2 to Fabric    0                   0
LP      NP-3 to Fabric    0                   0
HP      NP-3 to Fabric    0                   0
      Total IngressDrops  0                   0
5) Check FIA counters
RP/0/RSP0/CPU0:ROSH06_jetfire#show controllers fabric fia stats location
Thu Jan  1 01:51:37.097 UTC
FIA:0 DDR Packet counters:
From Bridge#[0]  510
To Bridge  #[0]  510
From Bridge#[1]  510
To Bridge  #[1]  510
FIA:0 SuperFrame counters:
To Unicast Xbar[0]     19
To Unicast Xbar[1]     20
To Unicast Xbar[2]     0
To Unicast Xbar[3]     0
To MultiCast Xbar[0]   0
To MultiCast Xbar[1]   0
To MultiCast Xbar[2]   0
To MultiCast Xbar[3]   0
From Unicast Xbar[0]   19
From Unicast Xbar[1]   20
From Unicast Xbar[2]   0
From Unicast Xbar[3]   0
From MultiCast Xbar[0] 0
From MultiCast Xbar[1] 0
From MultiCast Xbar[2] 0
From MultiCast Xbar[3] 0
FIA:0 Total Drop counters:
Ingress drop: 0
Egress drop: 0
Total drop: 0
RP/0/RSP0/CPU0:ROSH06_jetfire#show controllers fabric fia q-depth location 0/0$
Thu Jan  1 02:16:37.227 UTC
FIA  0
Total Pkt queue depth count = 0
6) Check Crossbar counters
RP/0/RSP0/CPU0:ROSH06_jetfire#show controllers fabric crossbar statistics instance 0 location
Thu Jan  1 01:54:07.721 UTC
  Asic Instance: 0
  Fabric info for node 0/RSP0/CPU0 (physical slot: 4)
  Dropped packets             :            mcast            unicast
  Input buf bp pkts           :                0                  0
  Output buf bp pkts          :                0                  0
  Xbar timeout buf bp pkts    :                0                  0
  HOL drop pkts               :                0                  0
  Null POE drop pkts          :                0                  0
Puntpath packet drop debugging
RSP puntpath
The punt path is: Incoming Interface --> NPU --> LC CPU --> NPU --> Bridge3 --> LC FIA --> RSP Crossbar
--> Punt FPGA on RSP --> RSP CPU Local interface Ping path is: RSP  CPU --> RSP FIA --> RSP Crossbar --> LC FIA --> LC CPU  --> NP0 ---> LC FIA ---> Crossbar ---> RSP FIA ---> RSP  CPU
To debug packet drop issues on any of the above paths:
1) Clear all packet counters as described earlier.
2) Start traffic.
3) Check traffic counters at each component
a)  Check NPU counters for NPU mapping to interface and NPU0 for inject  packet count. In case of NPU counters the following fields are of  interest:
820 PARSE_LC_INJECT_TO_FAB_CNT
872 RESOLVE_INGRESS_L2_PUNT_CNT
822 PARSE_FAB_INJECT_IPV4_CNT
b) Check Fabric related counters.
RP/0/RSP0/CPU0:UUT#show controllers fabric crossbar statistics instance 0 location 0/RSP0/CPU0
RP/0/RSP0/CPU0:UUT#show controllers fabric fia stats location 0/7/CPU0
c) Check Punt FPGA counters
d) Check Tsec counters
run tsec_info -t3 -c0
If pkts are lost inside fabric and not accounted in the fabric CLIs   listed in the above diagram then check the output of following cmds
  • sh contr fabric fia link-status location <lc>
  • sh contr fabric fia trace location <lc>
  • attach to lc#
  • fiashell -c nzerrorcnt -l 1000 -i <skt intance #>
  • fiashell -c intr -i <skt intance #>
Legend:
  • SKT is Skytrain, the Fabric Interface ASIC for typhoon linecards
  • XBAR is the Crossbar Fabric ASIC. Remember that Typhoon linecards have a fabric on the LC too.
Troubleshooting Back-pressure Issues
Although this is generally more QOS related, it is useful to understand backpressure and the verification of that within this fabric troubleshooting guide.
Every FIA has a set of VOQ's, this is a set of queues that represent a 10G entity in the system.
Every 10G entity (that means that 10x1G are represented with a single VOQ has different priority classes. Generally we see the default queue flowed off during backpressure scenario.
Only when the NPU is getting overloaded that is serving more BPS/BW or PPS then the circuits can handle, it will start to exert backpressure to the ingress Linecards. This is represented by a VOQ flow off on the FIA on that ingress linecard:
Zooming into the Fabric Interface Asic (FIA):
Identify the VOQ for an interface
RP/0/RSP1/CPU0:ios#show controllers pm interface tenGigE 0/5/0/0 loc 0/5/CPU0
Ifname(1): TenGigE0_5_0_0, ifh: 0xe000100 :
switch_fabric_port 0x17
VQI 23 is for interface ten0/5/0/0
NOTE: the SFP/Switch Fabric port is reported in HEX and represented in decimal (lovely ) in the show fabric commands.
Check if you are seeing FIA drops
RP/0/RSP1/CPU0:ios#show drops location 0/0/CPU0
=== snip ===
FIA 0 Drops:
Ingress Drops                                               287078960
Egress Drops                                                 1
Total Drops                                                 287078961
Ingress Generic Hard Drop-2                                 287078960
Egress Mcast RxFab Hdr-1                                     1
Check if any VQI is dropping packet
RP/0/RSP1/CPU0:ios#show controller fabric fia q-depth location 0/0/CPU0
FIA 0
VoQ   | ddr | pri | pkt_cnt
23   | 0   | 2   | 118
Total Pkt queue depth count = 118 Packets in the queue. Not good.
Useful commands to check for any hardware errors
1) Check for asic-errors for fia
Commands to check for asic errors for various fabric components.
show asic-errors arbiter 0 all location 0/RSP0/CPU0
show asic-errors crossbar 0 all location 0/RSP0/CPU0
show asic-errors fia 0 all location 0/1/CPU0
2) Check for pfm alarms
show pfm location <>
3) Checking link status
RP/0/RSP0/CPU0:ROSH06_jetfire#show controllers fabric fia bridge ddr-status loc <>
Thu Jan 1 02:23:07.757 UTC
FIA 0
FIA DDR# Status
0 SYNCED
1 SYNCED
RP/0/RSP0/CPU0:ROSH06_jetfire#show controllers fabric fia bridge sync-status loc <>
Thu Jan 1 02:23:09.314 UTC
FIA 0
Bridge# NP# Status
0 0 SYNCED
0 1 SYNCED
1 2 SYNCED
1 3 SYNCED
RP/0/RSP0/CPU0:ios#show controllers fabric fia link-status location 0/0/CPU0
Wed Jan 21 18:01:09.812 UTC
Fia 0 to Arbiter sync status
ARB   0              SYNCED
ARB   1              SYNCED
Fia 0 to Crossbar sync status
Fabric Link 0              SYNCED
Fabric Link 1              SYNCED
Fabric Link 2              SYNCED
Fabric Link 3              SYNCED
Fia 1 to Arbiter sync status
ARB   0              SYNCED
ARB   1              SYNCED
Fia 1 to Crossbar sync status
4) Check NP status and counters
NP issues can cause packet drops in and outside fabric. NP(s) could be locked up or
display error counters which may provide clues of the problem. Following is an example
of NP lockup symptom: NP0, NP1 and NP2 all shows no non-zero counters, a good indication
that they are locked up.
RP/0/RSP0/CPU0:cork#show controller np counters all loc 0/4/CPU0
Sat Jan  3 18:25:44.795 EST
               Node: 0/4/CPU0:
Show global stats counters for NP0, revision v3
 No non-zero data counters found
Show global stats counters for NP1, revision v3
Show global stats counters for NP2, revision v3
Show global stats counters for NP3, revision v3
Read 15 non-zero NP counters:
Offset Counter                                        FrameValue   Rate (pps)
  23 PARSE_FABRIC_RECEIVE_CNT                                586           0
  29 MODIFY_FABRIC_TRANSMIT_CNT                                2           0
  34  RESOLVE_EGRESS_DROP_CNT                                 578           0
  70 RESOLVE_INGRESS_L2_PUNT_CNT                              10           0
  74 RESOLVE_LEARN_FROM_NOTIFY_CNT                           544          0
  80 RESOLVE_VPLS_MAC_MOVE_CNT                                 2           0
 286 RESOLVE_MAC_NOTIFY_CTRL_DROP_CNT                        544           0
 287 RESOLVE_MAC_DELETE_CTRL_DROP_CNT                         34           0
 420 PARSE_FAB_MACN_RECEIVE_CNT                              546           0
 422 PARSE_FAB_MAC_DELETE_RECEIVE_CNT                         18           0
 423 PARSE_FAB_DEST_MAC_DELETE_RECEIVE_CNT                    16           0
 720 DIAGS                                                     4           0
 832  PUNT_STATISTICS                                         184           1
 834 PUNT_DIAGS_RSP_ACT                                        3           0
 836 PUNT_DIAGS_RSP_STBY                                       3           0
5) Check NP fabric counters
This can be used to verify if packets are really transmitted out of NPs or if there are
any errors between NP and FIA.
Example:
<span style="font-family: Courier New; color: #7a4707;">RP/0/RSP0/CPU0#sh controllers np fabric-counters all np0 loc 0/2/cpu0</span>
<span style="font-family: Courier New; color: #7a4707;">                Node: 0/2/CPU0:
Egress fabric-to-bridge interface 0 counters for NP 0
 INTERLAKEN_TX_PACKETS                         0x00000000 00000000
 INTERLAKEN_TX_BYTES                           0x00000000 00000000
 INTERLAKEN_TX_BAD_PACKETS                     0x00000000 00000000
Egress fabric-to-bridge interface 1 counters for NP 0
 INTERLAKEN_TX_PACKETS                         0x00000000 02ce40bd
 INTERLAKEN_TX_BYTES                           0x00000000 c20dff82
 -------------------------------------------------------------</span>
Ingress fabric-to-bridge interface 0 counters for NP 0
 INTERLAKEN_RX_PACKETS                         0x00000000 00000000
 INTERLAKEN_RX_BYTES                           0x00000000 00000000
 INTERLAKEN_RX_BAD_PACKETS                     0x00000000 00000000
 INTERLAKEN_RX_CRC_ERROR                       0x00000000 00000000
 INTERLAKEN_RX_ALIGNMENT_ERROR_0               0x00000000 00000000
 INTERLAKEN_RX_ALIGNMENT_ERROR_1               0x00000000 00000000
 INTERLAKEN_RX_ALIGNMENT_ERROR_2               0x00000000 00000000
 INTERLAKEN_RX_ALIGNMENT_ERROR_3               0x00000000 00000000
 INTERLAKEN_RX_ALIGNMENT_FAILURE               0x00000000 00000000
 INTERLAKEN_RX_ALIGNMENT_FAILURE_1             0x00000000 00000000
 INTERLAKEN_RX_ALIGNMENT_FAILURE_2             0x00000000 00000000
 INTERLAKEN_RX_ALIGNMENT_FAILURE_3             0x00000000 00000000
 INTERLAKEN_RX_BLK_TYPE_ERROR_AGGR             0x00000000 00000000
 INTERLAKEN_RX_DIAG_CRC_ERROR_AGGR             0x00000000 00000000
 INTERLAKEN_RX_WORD_SYNC_ERROR_AGGR            0x00000000 00000000
 INTERLAKEN_LAST_CNT                           0x00000000 00000000
                                               0x00000000 00000000
Ingress fabric-to-bridge interface 1 counters for NP 0
 INTERLAKEN_RX_PACKETS                         0x00000000 03e3a8a4
 INTERLAKEN_RX_BYTES                           0x00000000 dec9c1ce
                                               0x00000000 00000000
Related Information
The following documents are good references also:
Punt fabric datapath failures:
Quality of Service architecture for the ASR9000
Hi Xander,
Excellent information as usual.
Kindly to note that the pictures (.png) are not showing.
Michel.
pedroangeldiaz
Hi Alexander,
Recently I started to read your documentation about ASR9K, great all around, but the last document I was reading has been removed "asr9000xr-troubleshooting-packet-drops-and-understanding-np-drop-counters" could you upload it again?
Thanks beforehand.
xthuijs
Hi Pedro,
thank you!! It was brought to my attention that some of the articles on support forums have been hidden due to a security screening. This doc you mentioned was part of that exercise. It was inadvertently de-posted but I have been told that this will get back online shortly, by the end of this week.
The procedure to troubleshoot packet drops I also documented in Cisco Live 2013 Orlando and 2014 SanFran and the command show controller np counter description provides the explanations of the counters.
Hopefully that keeps you going until the doc is back online again.
cheers!
xander
Adam Vitkovsky
Level 3
Level 3
Hi Xander,
Thank you very much for these articles the more I read them the more it makes me think which is great.
I’d like to ask how does the central arbiter issue grants to ingress NPUs in order to allow them to send frames to a particular egress NPU please?
Is the arbiter autonomous in issuing the grants please?
That is, does it keep track of how many grants it issued for a particular egress NPU and for a e.g. 10GE NPU it won’t issue more than 10GE worth of grants?
Or does the arbiter consult egress NPU whether it can issue a grant please?
That is, does it wait for credit return from egress NPU to see that the egress NPU is ready to process additional data and only then it issues grants to ingress NPUs? (grants worth the credit returned)
Thank you very much
adam
xthuijs
hi adam! ah thank you! yeah it is tricky stuff hence the more visuals the hopefully easier it is to work with! Say for this particular fabric question, I would refer to the Cisco Live id 2904 from orlando 2013, it has a section specifically talking about how the fabric grants work.
The ingress LC decides that it wants to send a particular packet to a particular egress NPU.
The MDF stage on the ingress LC rewrites a packet header with a fabric destination.
When the FIA looks at that "address", it checks the VOQ for that particular NPU/destination/LC and sees if there is enough bW available. When it is ready to DQ it to that LC, the FIA requests a grant from the fabric for that destination LC.
Now the thing is, the FIA may group a few packets together going to that same LC, which is called super framing. So it is not packets that go over the fabric link, but super frames.
This is important because if you have a test going on with 100pps incoming, you may see fab counters only reporting 50. this is not packet loss, it would just mean that we have 2 packets in a superframe over the fabric.
Once the packet is received by the egress LC, the grant is returned.
Fabric arbitration is merely to assist in "hole piercing" on the fab to facilitate packet (replication) towards a single or multiple lc in one shot.
cheers!
xander
Adam Vitkovsky
Level 3
Level 3
Yes please I watched the presentation several times and also made notes on key facts :)
Just would like to clarify couple of things:
1)Ingress FIA is issuing the access requests
2)Fabric Arbiter relies requests/grants between ingress/egress FIAs
3)Egress FIA is issuing access grants
Is the above correct please?
But then how does the egress FIA know how much traffic can it grant towards a particular egress port/NPU(if NPU hosts multiple ports) please?
Thank you very much
adam
xthuijs
your logic is almost correct Adam!!
the only "correction" would be on step 3, the arbiter manages the grants, based on what it knows from the BW allocated/assigned between LC's.
The FIA's have the knowledge of the VOQ's (the virtual output queues) that represent 10G entities (in typhoon).
the backpressure piece you are interested in is when an egress NPU tells the egress FIA that it is getting overloaded, this signal ripples back to ingress LC FIA's so they know that that particular VOQ, representing an NPU 10G entity on egress is getting exhausted on its capabilities.
xander
Adam Vitkovsky
Level 3
Level 3
Thank you very much Xander
Yes please I’m utmost interested in the origins of backpressure
“an egress NPU tells the egress FIA that it is getting overloaded”
-does that mean either
1) please slow down, I’m getting 11Gbps worth of data from you,
or
2) please slow down, though I’m getting only 8Gbps worth of data, but there are all these egress features enabled on my ports and I can’t perform at line-rate anymore.
“this signal ripples back to ingress LC FIA”
-is that implicit backpressure please? - that is, by not granting access for super-frames in a particular VOQ please?
-but then how can the egress LC FIA tell arbiter to stop issuing grants for a particular VOQ please? –see that is why I thought it’s egress LC FIA issuing the grants and that arbiter merely relies them to ingress
adam
Aleksandar Vidakovic
hi Adam,
it can be both. The trigger for the back-pressure is the utilisation level of RFD buffers. RFD buffers are holding the packets while the NP microcode is processing them. If you search for the BRKARC-2003 from Cisco Live Berlin 2016 you will see a table that explains this mechanism. The more feature processing the packet goes through, the longer it stays in RFD buffers.
Arbiter has a number of tokens per VoQ. When the arbiter permits the ingress FIA to send a (super)frame to specific VoQ, that token is returned to the pool only when the egress FIA delivers the frames to egress NP. If the egress NP has raised the back-pressure, the token remains occupied. This is how the arbiter eventually runs out of tokens for that VoQ. When that happens, the ingress FIA will start dropping the packets.
hope this explains,
Aleksandar
Adam Vitkovsky
Level 3
Level 3
Excellent, excellent! This is exactly what I was looking for, thank you very much
Will go ahead and read the Berlin preso and amend my notes with the info and will most likely come back with more questions
Thank you so much
adam
Adam Vitkovsky
Level 3
Level 3
Hi Aleksandar,
First I’d like to say how much I treasure the possibility to talk to you folks, this truly is an unprecedented level of service/support in the networking industry.
In addition to BRKARC-2003 I end up reading also both BRKSPG-2904(168/199 pages) trying to fill in the gaps.
What do the ICU and RFD stands for please?
Did I get these correct please:
ICFDQ =Input congestion Fast Drop Queue
EFD = Early Fast Drop
SPri WRR = Strict-priority WRR
So does ICU and ICFDQ do a “pre-classification” and queue-management of the DRAM (the Inflight frame buffer) please?
And is that before the packet hits the NPU TM(Traffic Manager -that distributes the headers to PPEs please)?
64 groups x 4 CoS queues
-does that mean there are 64 PPEs at each stage of the pipeline please?
For traffic arriving over Fabric via Egress FIA –how do these map to the VOQs please?
I assume the ICFDQ part is not configurable, i.e. I can’t tell which (e.g. EXP) is which of the 4 (currently 3 classes) right?
-so I’d like to confirm what traffic is assigned to which queue please?
Network control (ToS/Exp/VlanCos/DSCP >= 6) –correct?
High priority (ToS/Exp/VlanCos/DSCP = 5) –correct? - BRKSPG-2904 says it’s (>=6) –but I guess that should have been NetControl or not?
Low priority (ToS/Exp/VlanCos/DSCP < 5) –correct?
Thank you very much
adam
xthuijs
hi adam,
thank you that is very nice to hear for us!! we'll keep on doing this!! :)
ICU is internal classification unit. the npu has different TOP's (task optimized processors) and the ICU is a dedicated piece that defines keys for fast lookups in search based memory (eg RLDRAM for route/mac lookups or tcam for matching class/acl or interfaces).
EFD is early fast discard, so yeah similarly to drop :). it is a mechanism whereby we look at the feeder queue before the packets enter the pipeline of the npu where we can do some minimalistic checking on prec/exp or cos to determine if we are dealing with alow or high prio packet and in case the pipeline is clogged we can toss some lower prio packets.
the EFD prio classification or what defines high prio can be configured under admin.
In cisco live id 2904 from sanfran 2014 we have some more details on the VOQ piece and how you can match a 10G entity to a particular VOQ number and how to monitor that from inside the FIA (fabric interface asic).
cheers!
xander
Adam Vitkovsky
Level 3
Level 3
Thank you so much Xander,
“feeder queue before the packets enter the pipeline of the npu”
-so is that is the ICFDQ please?
-so there’s basically “WRED” on each of the 64 groups/queues -based on the control/high/low priority -is that right please?
I’d like to learn more about the interface between FIA and NPU
So FIA has these egress queues facing NPU(I guess 10 queues facing Tomahawk NPU) and on ingress to NPU there are 64 groups each with 4 queues.
I’d like to understand how does FIA dequeue packets into one of the ingress queues on the NPU please?
Thank you very much
adam
hi Adam,
ICFDQ stands for "Input Classification Frame Descriptor Queues". EFD is not that complex to include WRED. Look up the BRKARC-2003 slide deck from Cisco Live Berlin 2016. There is a slide that explains the EFD logic.
Between the FIA and NP (in egress direction) there is are for VoQ per VQI. On Tomahawk a 100G interface is one VQI. If you apply the 10x10G breakout, each of the 10G interfaces will be represented by one VQI. This is also explained in the same BRKARC-2003 deck.
If you are investigating an issue that you have observed in a lab or in production, let us know what's the issue. We can help better if we know the intent behind the questions.
regards,
Aleksandar
Adam Vitkovsky
Level 3
Level 3
Hi Aleksandar,
Thank you so much for all your time
Do also Trident and Typhoon LCs have the ICFDQ with EFD for low priority queue (although SW based) please?
What are the functions of the TM0 and TM1 blocks please?
Is the TOPs bypass and the bypass depicted in TM block for network control traffic please?
Regarding FIA
I see so that’s why it says From FIA to Fabric:
4 VOQ per each “virtual port” in the entire system
-so if there’s a breakout then each “virtual”10GE will get its 4VOQs (up to 4K ports)
And from FIA to NPU:
4 Egress Queues per each virtual port
-so on FIA these 4 Egress Queues per each virtual port are then somehow mapped to 64 groups by 4 queues of the NPU
I’m not allowed to share any specifics publicly, but the intent is to make sure that the high priority traffic is not dropped in scenarios where there are multiple customers on the NPU/FIA and one of them is under DDOS attack and the FIA buffers or NPU pipeline gets clogged because there are a lot of services enabled on the NPU. My address is adamv0025 at gmail if you’d like to hear more details.
Thank you very much again
adam
