xthuijs
Introduction
In this document I'll discuss the operation, use and some examples on RPL, or the route policy language.
Route policies are mandatory for E-BGP peers, at least a "pass-all" like RPL is required in order to import and export routes.
Core Issue
In IOS we used to have route-maps to control the import, export and manipulation of routes. IOS-XR doesn't have route-maps but something more powerful called route policy language. It is a very programmatic approach in route-maps.
Where as IOS route-maps operate as a series of statements which are executed sequentially, Route-policies not only operate sequentially but provide the ability to invoke other route-policies much like a ‘C’-program is able to call separately defined functions. This enables to creation of hierarchical policies. In addition, and most importantly into respect the scope of this paper, route-policies are ‘compiled’ into a run-time executable portion of code.
Editing route policies
When you have configured a route policy that you want to edit afterwards, you need to restart from scratch or copy paste the existing RPL as entering the route-policy configuration would wipe the existing one out:
RP/0/RSP0/CPU0:A9K-BNG(config)#route-policy test
RP/0/RSP0/CPU0:A9K-BNG(config-rpl)#if med eq 100 then
RP/0/RSP0/CPU0:A9K-BNG(config-rpl-if)#set local-preference 100
RP/0/RSP0/CPU0:A9K-BNG(config-rpl-if)#endif
RP/0/RSP0/CPU0:A9K-BNG(config-rpl)#end-policy
RP/0/RSP0/CPU0:A9K-BNG(config)#commit
Fri Jan 20 14:58:39.900 EDT
% WARNING: Policy object route-policy test' exists! Reconfiguring it via CLI wil
l replace current definition. Use 'abort to cancel.
RP/0/RSP0/CPU0:A9K-BNG(config-rpl)#if local-preference eq 123 then
RP/0/RSP0/CPU0:A9K-BNG(config-rpl-if)#set origin incomplete
RP/0/RSP0/CPU0:A9K-BNG(config)#do sh run route-policy test
Fri Jan 20 14:59:53.705 EDT
route-policy test
  endif
  end-policy
As you can see the previous if statement is completely gone, copy pasting and offline editing are also not very easy to use! There is a solution!
RP/0/RSP0/CPU0:A9K-BNG#edit route-policy test ?
  emacs  to use Emacs editor
  nano   to use nano editor
  vim    to use Vim editor
  <cr>
I tend to prefer VI and then you can edit your RPL in a VI like manner:
Editting screen:
route-policy test
  else if med eq 100 then
    set weight 44
  endif
  end-policy
I am inserting the bold italic lines and press "ZZ" to exit and save the VI editor. (Note I made a config error in RED)
"/dev/shmem/rpl_edit.115790135" 8 lines, 149 characters written
Proceed with commit (yes/no/cancel)? [cancel]:
Now the config error here by splitting "else if" and look what happens when I try to commit:
Parsing.
149 bytes parsed in 1 sec (148)bytes/sec
% Syntax/Authorization errors in one or more commands.!! SYNTAX/AUTHORIZATION ER
RORS: This configuration failed due to
!! one or more of the following reasons:
!!  - the entered commands do not exist,
!!  - the entered commands have errors in their syntax,
!!  - the software packages containing the commands are not active,
!!  - the current user is not a member of a task-group that has
!!    permissions to use the commands.
    set weight 44
  endif
  end-policy
Continue editing? [no]:yes
"/dev/shmem/rpl_edit.115790135" 8 lines, 145 characters written
Proceed with commit (yes/no/cancel)? [cancel]: yes
Parsing.
145 bytes parsed in 1 sec (144)bytes/sec
Committing.
Prepared commit in 0 sec
1 items committed in 1 sec (0)items/sec
Updating.RP/0/RSP0/CPU0:Jan 20 15:04:20.101 : config[65848]: %MGBL-CONFIG-6-DB_COMMIT : Configuration committed by user 'root'. Use 'show configuration commit changes 1000000522' to view the changes.
Updated Commit database in 1 sec
So from now one when you want to edit RPL's, prefix sets or as-sets or community sets, use this editor
RP/0/RSP0/CPU0:A9K-BNG#edit ?
  as-path-set       edit an as-path-set
  community-set     edit a community-set
  extcommunity-set  edit an extended-community-set
  policy-global     edit policy-global definitions
  prefix-set        edit a prefix-set
  rd-set            edit a rd-set
  route-policy      edit a route-policy
RPL operation
RPL Actions
The route policy requires a "ticket" for the route to be accepted or dropped. These are the different operatators
Pass – prefix allowed if not later dropped
pass grants a ticket to defeat default drop
Execution continues after pass
Set – value changed, prefix allowed if not later dropped
Any set at any level grants a ticket
Execution continues after set
Values can be set more than once
Done – prefix allowed, stop execution
Drop – prefix is discarded
Explicit drop stops policy execution
Implicit drop (if policy runs to end without getting a ticket)
One thing important to add is here that if you have a policy that is "sequential" like
if med 10 then
 set med 20
endif
if med 20 then
 drop
endif
the execution will NOT drop prefixes with MED10. The reason for that is, although somewhat counter intuitive, that the sequence of operation uses the ORIGINAL value during processing, hence the second if statement will not match for the what was original med of 10...
If you like to get the behavior that both 10 and 20 are dropped, you could do something like this:
if med 10 then drop
else if med 20 then drop
else pass
endif
Don't forget the final pass, as there is an implicit deny.
Hierachical policies
The ability to reference one policy in another
route-policy one
     set weight 100
end-policy
route-policy two
     set med 200
end-policy
route-policy three
    apply two
    set community (2:666) additive
end-policy
route-policy four
    apply one
    apply three
    pass
end-policy
Parameter Passing
The ability to call one policy with a variable to be used in another policy:
route-policy one ($med)
  set med $med
end-policy
route-policy two
  apply one (10)
end-policy
Or with 2 variables:
route-policy three ($med,$origin)
  set med $med
  set origin $origin
end-policy
route-policy four
  apply three (10, incomplete)
end-policy
Inline vs. Named sets
In your RPL you can put the prefix set or as-path etc in the IF statement construction or you can reference a separate set with the AS-list.
They look like the following:
Inline:
route-policy use_inline
  if as-path in (ios-regex '_42$', ios-regex '_127$') then
    pass
  else
    drop
  endif
end-policy
Named-Set:
as-path-set named_set
  ios-regex '_42$',
  ios-regex '_127$'
end-set
route-policy use_named
if as-path in named_set then
    pass
  else
    drop
  endif
end-policy
There is a performance difference between teh two. the Named Set is obviously slightly slower, but is easier to manage especially when the list gets long. I would personally recommend for short lists to use inline and for longer lists to use the named-set.
Each individual set element results in a separate call to the expression engine:
as-path-set as_51
ios-regex ‘_2129$’,
ios-regex ‘_2147$’,
ios-regex ‘_2856$’,
ios-regex ‘_3486$’,
ios-regex ‘_6432$’,
ios-regex ‘_6468$’,
ios-regex ‘_7310$’,
ios-regex ‘_7768$’,
ios-regex ‘_7862$’,
ios-regex ‘_8296$’
end-set
The same set can be written as follows:
as-path-set as_51
ios-regex '_(2129|2147|2856|3486|6432|6468|7310|7768|7862|8296)$'
end-set
Example AS-Path-Set, Community-Set and Prefix-Set
AS-PATH
as-path-set aset1
    ios-regex ’_42$’,
    ios-regex ’_127$’
end-set
Prefix-Set
prefix-set galaga
171.68.118.0/24,
192.168.0.0/16 ge 16 le 30
end-set
Community-Set
community-set cset1
      12:34,
      12:78,
      internet
end-set
•Match by value, wildcard, or regular expression
•2 16 bit values separated by colons
•Support for common community keywords
internet
local-AS
no-advertise
no-export
private-as
Show commands
show bgp policy route-policy <name>
Only display prefixes matching policy – filter show command
RP/0/0/CPU0:XR#show rpl route-policy states
ACTIVE -- Referenced by at least one policy which is attached
INACTIVE -- Only referenced by policies which are not attached
UNUSED -- Not attached (directly or indirectly) and not referenced
Working with Prefix-Sets
Here some examples of using prefix-sets. The use of the variable masks is not easy to understand and I found the CCO documentation not very explanatory, so here a few extra words on that.
Prefix:                                        Explanation:
10.0.1.1,                match only one possible value, 10.0.1.1/32, mask omitted means 32.
10.0.2.0/24,             match only one possible value, 10.0.2.0/24
10.0.3.0/24 ge 28,       match a range of prefix values, from 10.0.3.0/28 to 10.0.3.255/32
10.0.4.0/24 le 28,       match a range of values, from 10.0.4.0 to 10.0.4.240 (eg we can’t “reach” the last 4 bits)
10.0.5.0/24 ge 26 le 30, matches prefixes in the range from 10.0.5.0/26 to 10.0.5.252/30
10.0.6.0/24 eq 28        match any prefix of length 28 in the range from 10.0.6.0/28 through 10.0.6.240/28
10.0.7.2/32 ge 16 le 24, matches any prefix of length 32 in the range 10.0.[0..255].2/32 (from 10.0.0.2/32 to    10.0.255.2). This is a little funky given the “7” in the 3rd octet which effectively    becomes don’t care.
10.0.8.0/26 ge 8 le 16   matches any prefix of length 26 in the range 10.[0..255].8.0/26 (from 10.0.8.0/26 to    10.255.8.0/26)
Let me visualize it with some real outputs.
I am using an RPL that sets the local pref to 1234 if it matches the prefix set, and that prefix set is as per the above sample list.
=> What is excluded here ?  Is 10.0.3.128 excluded from the prefix range ?
Whether the .128 is excluded or not, depends on the mask of the prefix being advertised.
Basically what this means is that if the mask of the route is larger or equal than 28 (so 29,30,31,32) then it matches:
   Network            Next Hop            Metric LocPrf Weight Path
*>i10.0.3.0/28        8.1.1.1                100   1234      0 2 3 {4} i
*>i10.0.3.16/28       8.1.1.1                100   1234      0 2 {3,4} i
*>i10.0.3.32/28       8.1.1.1                100   1234      0 2 3 {4,5} i
*>i10.0.3.48/28       8.1.1.1                100   1234      0 2 i
*>i10.0.3.0/26        8.1.1.1                100    300      0 2 3 {4} i
*>i10.0.3.64/26       8.1.1.1                100    300      0 2 {3,4} i
*>i10.0.3.2/31        8.1.1.1                100   1234      0 2 {3,4} i
*>i10.0.3.4/31        8.1.1.1                100   1234      0 2 3 {4,5} i
*>i10.0.3.6/31        8.1.1.1                100   1234      0 2 i
*>i10.0.3.0/24        8.1.1.1                100    300      0 2 3 {4} i
=> What is excluded here ?  10.0.4.1, .2, .3, .17, .18,.19,.20, etc?
Same as before, but now where the mask is less than 28, so routes in the 10.0.4.x range that have a mask that is shorter 28 will get “hit”.
The mask on the prefix itself sets the “base”. Eg 10.0.3 would not match here as it is not part of the 10.0.4.0/24. Seems obvious but just to be clear ...
*>i10.0.4.0/24        8.1.1.1                100   1234      0 2 3 {4} i
*>i10.0.4.0/26        8.1.1.1                100   1234      0 2 3 {4} i
*>i10.0.4.64/26       8.1.1.1                100   1234      0 2 {3,4} i
*>i10.0.4.128/26      8.1.1.1                100   1234      0 2 3 {4,5} i
*>i10.0.4.48/28       8.1.1.1                100   1234      0 2 i
*>i10.0.4.64/28       8.1.1.1                100   1234      0 2 3 {4,5} i
*>i10.0.4.24/30       8.1.1.1                100    300      0 2 3 i
*>i10.0.4.28/30       8.1.1.1                100    300      0 2 {3} i
Combining the previous two together on the .5.0 range:
*>i10.0.5.4/30        8.1.1.1                100   1234      0 2 {3,4} i
*>i10.0.5.8/30        8.1.1.1                100   1234      0 2 3 {4,5} i
*>i10.0.5.12/30       8.1.1.1                100   1234      0 2 i
*>i10.0.5.4/31        8.1.1.1                100    300      0 2 3 {4,5} i
*>i10.0.5.6/31        8.1.1.1                100    300      0 2 i
*>i10.0.5.5/32        8.1.1.1                100    300      0 2 3 {4,5,6} i
*>i10.0.5.6/32        8.1.1.1                100    300      0 2 3 i
*>i10.0.5.0/25        8.1.1.1                100    300      0 2 3 {4} i
*>i10.0.5.128/25      8.1.1.1                100    300      0 2 {3,4} i
*>i10.0.5.64/26       8.1.1.1                100   1234      0 2 {3,4} i
*>i10.0.5.128/26      8.1.1.1                100   1234      0 2 3 {4,5} i
*>i10.0.7.2/32        8.1.1.1                100   1234      0 2 3 {4} i
*>i10.0.7.3/32        8.1.1.1                100    300      0 2 {3,4} i
*>i10.0.0.2/32        8.1.1.1                100   1234      0 2 3 {4} i
*>i10.0.0.3/32        8.1.1.1                100    300      0 2 {3,4} i
*>i10.1.7.2/32        8.1.1.1                100    300      0 2 3 {4} I <<doesn’t match because of 2nd octet
If I slightly change the prefix statement to: 10.0.7.4/32 ge 16 le 24
*>i10.0.7.0/30        8.1.1.1                100    300      0 2 3 {4} i
*>i10.0.7.4/30        8.1.1.1                100    300      0 2 {3,4} i
*>i10.0.7.8/30        8.1.1.1                100    300      0 2 3 {4,5} i
Still no match as the base mask is not met on the prefixes received.
So the /<whatever> determines the MASK of the route I wanted to match. whereas the GE/LE provide me the variance in either that mask (if bigger) or from the other octects (if smaller then the /mask)
Verifying performance of your RPL
To determine what in your route-policy is consuming the majority of the time, you can use route profiling.
It allows some data collection in the background with minimal impact  on the execution of the rpl. After the collection has been running for  some time you can use show commands to find out which steps take a lot  of time in the execution and make some improvements.
Once we figure out which portion of the policy is performance drag, its much easier to try out an alternative. Something like regex match always failing means we need to evaluate route using prefix match prior to validating its as-paths.
Example usage:
debug pcl profile detail
then
Router# show pcl protocol bgp 10 neighbor-in-dflt default-IPv4-Uni-1.2.3.4 policy profile
Policy execution profile
Protocol : bgp 10
Attachpoint : neighbor-in-dflt
AP Instance : default-IPv4-Uni-1.2.3.4
Policy Name : rpl_profile(nexthop)
Pass : 10
Drop : 5
Total : 15
Avg execution time : 110usec
Router#sh rpl route-policy rpl_profile detail
route-policy test
  apply test2
  done
end-policy
route-policy test2
  delete extcommunity rt all
end-policy
route-policy rpl_profile($p_nexthop)
  if next-hop in $p_nexthop then
    set local-preference 155
    set med 155
  else
    set local-preference 77
    set med 77
  endif
  set community (0:0)
  apply test
  set extcommunity rt (1:1)
end-policy
Router# show pcl protocol bgp 10 neighbor-in-dflt default-IPv4-Uni-1.2.3.4 policy profile detail
Protocol : bgp 10
Policy : rpl_profile(nexthop)
Pass : 15
Drop :  0
Total : 15
Node Id   Num visited  Avg exec time  Policy operation
           15          0usec                    route-policy rpl_profile
PXL_0_5            15         99usec                        if next-hop pfxmatch ... then
PXL_0_3            10          0usec                              set local-preference 155
PXL_0_4            10          0usec                              set med 155
PXL_0_6            15          0usec                              community assign
                            15          0usec                           route-policy test
                            15          0usec                                       route-policy test2
PXL_0_1            15          0usec                                                rt delete-all
                            15          0usec
PXL_0_2            15          0usec
PXL_0_8             0          0usec                              rt assign
                             0          0usec
PXL_0_1             5          0usec                                          set local-preference 77
PXL_0_2             5          0usec                                          set med 77
GOTO :        PXL_0_6
                            0          0usec
Router#
Usable attachpoints for RPL
Changing or modifying Route policies (or prefix/community sets)
As you have noticed when editting RPL's you need to reconfigure the complete policy in the regular CLI. An easier method is using the "edit" option described above.
When you are changing your RPL or prefix-set or any other list that RPL is using, it will trigger a few things:
If the RPL is used for BGP and your peer is not REFRESH capable, it will restart your BGP session.
If the peer is REFRESH capable a full table refresh is executed.
The reason for that is, that the RPL change or say prefix set change could have excluded some routes before that now may need to be imported.
On the Receiving Side:
For BGP, routes that are filtered are completely discarded and are NOT kept in memory with some kind of mark that says bgp rpl filtered.
We will use route refresh to obtain the routes again from the neighbor whenever there is a change in inbound route policy.
For this the neighbor has to be refresh capable, else we have to do clear bgp.
When the BGP peer receives a route refresh request it sends the complete table again to the requesting peer. While asking for the table they ask for the relevant (AFI, SAFI) table. When the routes are received from the peer an inbound filter if any is applied and the routes are aggregated.
On the sending side:
if I apply an RPL basically removing some previously advertised route, would BGP send withdraws for these now filtered routes?
What would rpl/bgp do when the RPL is modified to:
           1) do advertise some previously filtered routes
To advertise previously filtered routes it is similar to regular advertising of routes
           2) stop advertising previously advertised routes
BGP will send withdraws when it stops advertising previously filtered routes.
Xander Thuijs, CCIE #6775
Sr. Tech Lead ASR9000
hengkycung
Hi Xander,
Thanks for answering.
If i'm not wrong. The length that i should define is 1? it means only allow 1 more AS?
Ex : if as-path length 1 then pass
Thanks.
xthuijs
hey hengky, you know honestly, I have never used it, but I know the functionality exists, so it is something you'd have to try what the right one is :)
I *think* that RPL is processed before the advertisement and the prepention of the my-as, so yeah "1" would be the right one, but it may be two also...!
cheers!
xander
bedgewor
Any conditional matches done by RPL will be done based on what the BGP-Loc table has in it.  So if you do a show bgp ipv4 unicast and the routes only has a AS-Path of 2000, then you will use a value of one.  Once the RPL passes, the local AS (1000)  is added to the AS_Path.
Now if AS2000 decides to prepend some routes, those will not pass through.  At that point, you may want to use unique-length 1. That way if they prepend (There AS) it will allow it to pass as well.
Be aware that with this policy any ASN is allowed to pass.   You may be better off with an orginates from 2000  which would be similar to a regex pattern of _2000$
-brad
hengkycung
hi bedgewor,
Thanks a lot bro. it really help. i used as-path length is 0 or as-path length 1 right now XD
Jakob Heitz
default originate is done by the scanner task. The scanner runs every 60 seconds by default. You can change it with the "bgp scan-time" command. The scanner does a lot of other things. For example, deleting stuff that's no longer needed. If it has a lot to do when it runs, it can use a lot of CPU. Be mindful of that if you change the scan-time.
SeymaNGET
Hi xander,
Thanks...Great article and I can get understand most the thing easily. However, I have tested then came up a scenario but could not get it worked yet. What I want to test is that, I want to send routes to a BGP neighbor from Cisco IOS XR based on community value it receive.
Example, When Cisco XR receive prefixes from its neighbor with community 12345:1, then Cisco XR send only default route. If it receives 12345:99, it will send full Internet routes.
So could you please advise and suggest policy configuration on Cisco IOS XR side to achieve this?
Thanks and looking forward for your advice.
Seyma
xthuijs
hi seyma,
hmm yeah you cant really use rpl in that way: using a community inbound as a trigger for an outbound update. the issue is that the community is a per prefix assignment and rpl works in one direction.
it sounds like you want a dynamic sort of configuration to either advertise a default only or a full table based on a parameter.
you could make an RPL with a variable passing and if the variable is "full" we send all routes outbound and if the variable is "default" we drop all routes outbound and send a default only.
this rpl is then applied to all neighbors like:
neighbor x.x.x.x route-policy MYPOL(full) for instance
xander
SeymaNGET
Hi Xander,
Thank you very much for your reply. Let me test that further and will provide back the update. :-)
Seyma
racarvalho
Hi Xander,
I need to aggregate several /32 into a /24. With the aggregate command i can do that.
aggregate x.x.x.x/24 as-set
my problem is that the aggregate route NH is null0, when i apply a route-policy to set NH i get:
!!% Could not find entry in list: Policy [GREEN] uses 'assign next-hop'. 'set' is not a valid operator for the 'next-hop' attribute at the bgp aggregation-dflt attach point.
On IOS this works. is there anyway to do this on XR?
RAC
bedgewor
Hi RAC,
I've never seen this done before in SP/Enterprise.  What is the use case for this, I cannot think of one?
I ask because BGP aggregated routes are considered a locally originated routes, which will put the route in to the BGP table with a next-hop of 0.0.0.0 and install the aggregate route in the routing table with a next-hop to Null0 as a loop prevention mechanism.  That specific action is not associated to the aggregation function because of this reason. You could change it with outbound route-policy as it is advertised to other peers.  I go back to what is the use-case?
-brad
xthuijs
if it helps, if you'd like to set the next hop for an advertised route whether that be an aggregate or regular route, we can do that by using the set next-hop in the outbound route-policy towards the peer.
xander
racarvalho
Brad this a very specific case for a test.
Yes, that what we'll do.
The question was more to understand why it wouldn't work on XR.
Thanks Xander and Brad
RAC,
hank
I want to announce all prefixes to a peer except those that have a community of 0:123.  So I do:
route-policy pass_except_tagged_123
if community matches-any 0:123 then
drop
else
pass
endif
end-policy
Yet when I run it thru IOS-XR as:
sh bgp route-policy pass_except_tagged_123
I get no routes shown - tagged with community or not tagged with community.
Yet when I do:
sho bgp comm 0:123
I see the prefix very nicely.  I am obviously missing something here.
Thanks!
Umpri
I think you miss something, to set community, look at this example and try yours
prefix-set pfx_NO-CUSTOMER
 10.0.0.0/8 le 32,
 0.0.0.0/0,
 192.168.0.0/16 le 32,
 172.16.0.0/12 le 32,
 190.224.0.0/21 le 32,
 190.224.8.0/22 le 32,
 190.138.242.0/23 le 32,
 190.138.244.0/23 le 32,
 190.138.246.0/23 le 32,
 200.3.32.0/19 le 32,
end-set
route-policy FORTESTING                                                            if (destination in pfx_NO-CUSTOMER) then
  drop
 else
  set community (0:100, 0:110, 0:800)
 endif
end-policy
Javier
Jakob Heitz
It should be
if community matches-any (0:123) then
instead of
without the parens, it references a community set named 0:123
