xthuijs
Introduction
In this article we'll explain how dhcp relay is working and how broadcasts are forwarded within IOS-XR, because the DHCP relay functionality is configured and handled differently within XR vs regular IOS.
Generally broadcasts are not forwarded by routers as they typically only live on the local subnet. However sometimes it is required to forward these broadcasts and this article will detail out how that configuration works and what the limitations are.
Core Issue
Considering that broadcasts are handled locally on the subnet, a router will not forward these broadcasts out and locally consume them. This presents a problem when a particular interface is servicing a subnet with clients that want to use DHCP to obtain their address information. IOS-XR at the time of writing does not have a dhcp server which means that clients cannot obtain their address from an XR router.
Even if the OS would support DHCP server, like IOS, you may want to centralize your DHCP servers in a designated area of your network which would require you to forward the client's DHCP requests to that server.
IOS employs the concept of an ip-helper-address to take the broadcasts and send out a directed broadcast or unicast to one or multiple servers.
Note that by default broadcasts are NOT forwarded by a router.
Also only UDP broadcasts can be forwarded, dhcp (which is udp based) can benefit from this only.
Resolution
Broadcast forwarding
In order to forward udp broadcasts, IOS uses the ip helper-address configuration underneath the interface that is expected to receive broadcasts that are to be forwarded. This pertains then to ALL udp broadcasts that are received.
fp7200-6(config-if)#ip helper-address ?
  A.B.C.D  IP destination address
In IOS-XR, DHCP broadcasts are handled and configured differently then other udp based broadcasts.
For IOS-XR to forward broadcasts (non DHCP) the following configuration is required:
RP/0/RSP1/CPU0:A9K-BOTTOM(config)#forward-protocol udp ?
  <1-65535>    Port number
Some well known port numbers are converted into their names, such as DNS and NBNS
The interface configuration for IOS-XR looks like this:
RP/0/RSP1/CPU0:A9K-BOTTOM(config)#int g0/1/0/14
RP/0/RSP1/CPU0:A9K-BOTTOM(config-if)#ipv4 helper-address ?
  A.B.C.D  IPv4 destination address
Note again that this configuration will not forward DHCP packets.
DHCP
There are 2 key ways to handle DHCP, one is via DHCP RELAY and one is via DHCP PROXY.
Relay has been supported for a long time. XR421 adds the full capability of proxy (in combination with IP subscribers)
Configuration: in its simplist form
dhcp ipv4
profile MYGROUP relay
  helper-address vrf default 40.1.1.1
  helper-address vrf default 55.1.1.2
interface GigabitEthernet0/1/0/14 relay profile MYGROUP
There is no further interface specific configuration required as what you're used to from IOS-XR that all protocol specific configuration is done under the protocol definition and not split across different sections.
Relay
Is more dumb in the handling of dhcp broadcasts, we are effectively taking the dhcp broadcast messages and convert them into a unicast destination which are defined by the helper addresses and we send the messages back and forth, or in fact we are relaying them between the client and the helper addresses. We maintain no state pertaining to DHCP as we are simply sending them across. The return packets from the helpers are returned as broadcasts back to the subnet we are serving.
In dhcp relay mode (or broadcast forwarding for that matter) packets are sent to all helper addresses.
In XR dhcp relay, prior to XR 4.1 and as described by CSCto39520, we only forward one offer back to the client if we receive multiple offers from the various helper addresses. While this provides still redundancy, it is in certain cases not desirable to have only offer handed to the client.
The rationale in XR was that we'd be maintaining a temporary state that links the request ID to the interface, once the first offer comes in, that state is removed. This prevents the forwarding of subsequent offers.
While normally this state and interface linkage is not needed, because we could look up the giaddr to the interface and use that, in the scenario where we are unnumbered to a loopback serving multiple interfaces, this state is useful so we send it out only on the interested interface.
Post XR 4.1 we'll leave that state in place for 1 minute so all offers received in that time period are forwarded.
Memory is not an issue, we could theoretically serve 1M requests per minute.
However things are bound by the LPTS punt policer and the process prioritization.
For some actual numbers, DHCPv4-Relay over BVI can accommodate 200K sessions and qualified CPS rate is 150 RSP440 and 250 on RSP880. DHCPv4-Relay is stateless and there are no sessions created.
The 200K limitation is enforced because of Adjacency creation as the adjacency is framed with ARP learning for end-user while resolving gateway ip-addresses.
Consider 250 CPS (Calls Per second), since ASR9K acting as Relay so access-side 4 message transactions (Discover, Offer, Request, Ack) and also server-side 4 message transactions.
So, overall 8 messages transactions per session.
That means, overall 250*8*60 = 120K message transactions per second.
Currently dhcp replies being sent as broadcast to the client so after enabling the CLI "[no]broadcast-flag policy check" it will send unicast reply to the client.
Proxy
In dhcp PROXY mode we do maintain state as we are handling the dhcp request on behalf of the requesting client. It looks like as we are the originator of the request to the dhcp servers. Proxy for that matter is stateful.
Proxy also stores the binding on the proxy agent locally, which relay does not.
Setup configuration, sample operation and debug verification
Setup used:
Note: One common forgotten thing is that both dhcp servers need to have a route back to the 39.1.1.1 address in this example.
So make sure there is a static route or when running an IGP that this interface/address is included (passively)
ASR9000 related configuration provided above.
IOS dhcp server configuration is as follows:
SERVER 1
ip dhcp excluded-address 39.1.1.1 39.1.1.100
ip dhcp pool SERVER1
   network 39.1.1.0 255.255.255.0
   default-router 39.1.1.1
   dns-server 1.2.3.4
SERVER 2
ip dhcp excluded-address 39.1.1.1 39.1.1.200
ip dhcp pool SERVER2
   dns-server 6.7.8.9
No specific interface configuration required on the interfaces other then ip addresses and proper routing.
DEBUGS
dhcpd relay all flag is ON
dhcpd relay errors flag is ON
dhcpd relay events flag is ON
dhcpd relay internals flag is ON
dhcpd errors flag is ON
dhcpd events flag is ON
dhcpd packet flag is ON
RP/0/RSP1/CPU0:A9K-BOTTOM(config-if)#RP/0/RSP1/CPU0:Mar 29 13:23:27.980 : dhcpd[1064]: DHCPD PACKET: TP564: L3 Packet RX from addr = 0.0.0.0, port = 68, application len 576, vrf 0x60000000 (1610612736), tbl 0xe0000000 (3758096384)
RP/0/RSP1/CPU0:Mar 29 13:23:27.980 : dhcpd[1064]: DHCPD PACKET:  >dhcpd_iox_l3_conn_hlr: recv, src 0.0.0.0 dst 255.255.255.255, L3I GigabitEthernet0_1_0_14, Null output,
RP/0/RSP1/CPU0:Mar 29 13:23:27.981 : dhcpd[1064]: DHCPD PACKET: TP608: BOOTREQUEST Rx, chaddr 0003.a0fd.28a8, interface GigabitEthernet0_1_0_14
RP/0/RSP1/CPU0:Mar 29 13:23:27.981 : dhcpd[1064]: DHCPD PACKET: TP982: DISCOVER Rx, base mode, interface GigabitEthernet0_1_0_14, chaddr 0003.a0fd.28a8
received dhcp request on interface
RP/0/RSP1/CPU0:Mar 29 13:23:27.981 : dhcpd[1064]: DHCPD PACKET: TP615: DISCOVER Rx, Relay chaddr 0003.a0fd.28a8
RP/0/RSP1/CPU0:Mar 29 13:23:27.981 : dhcpd[1064]: DHCPD PACKET: TP790: Client request opt 82 not untrust, chaddr 0003.a0fd.28a8
RP/0/RSP1/CPU0:Mar 29 13:23:27.982 : dhcpd[1064]: DHCPD PACKET: TP791: Giaddr not present, Set giaddr 39.1.1.2, chaddr 0003.a0fd.28a8
Setting GIADDR to the interface receiving the packet, this GIADDR is used to locate the right pool on the servers. So the server sneed to have a pool for the 39.1.1.0/24 subnet.
RP/0/RSP1/CPU0:Mar 29 13:23:27.982 : dhcpd[1064]: DHCPD PACKET: TP792: Client request opt 82 nothing to add, chaddr 0003.a0fd.28a8
RP/0/RSP1/CPU0:Mar 29 13:23:27.982 : dhcpd[1064]: DHCPD PACKET: TP571: L3 packet TX unicast to dest 40.1.1.1, port 67, source 39.1.1.2, vrf 0x60000000 (1610612736), tbl 0xe0000000 (3758096384)
Unicast packet forwarded to the first helper
RP/0/RSP1/CPU0:Mar 29 13:23:27.982 : dhcpd[1064]: DHCPD PACKET:  >dhcpd_iox_l3_unicast_packet: xmit, src 0.0.0.0 dst 255.255.255.255, L3I GigabitEthernet0_1_0_14, Null output, FROM L3
RP/0/RSP1/CPU0:Mar 29 13:23:27.982 : dhcpd[1064]: DHCPD PACKET: TP571: L3 packet TX unicast to dest 55.1.1.2, port 67, source 39.1.1.2, vrf 0x60000000 (1610612736), tbl 0xe0000000 (3758096384)
Unicast packet forwarded to the second helper
they are sent in the order of configuration and the configuration is maintained in order from low to high ip address.
RP/0/RSP1/CPU0:Mar 29 13:23:27.983 : dhcpd[1064]: DHCPD PACKET:  >dhcpd_iox_l3_unicast_packet: xmit, src 0.0.0.0 dst 255.255.255.255, L3I GigabitEthernet0_1_0_14, Null output, FROM L3
RP/0/RSP1/CPU0:Mar 29 13:23:27.983 : dhcpd[1064]: DHCPD PACKET: TP835: DISCOVER Tx, chaddr 0003.a0fd.28a8
RP/0/RSP1/CPU0:Mar 29 13:23:27.984 : dhcpd[1064]: DHCPD PACKET: TP564: L3 Packet RX from addr = 40.1.1.1, port = 67, application len 300, vrf 0x60000000 (1610612736), tbl 0xe0000000 (3758096384)
RP/0/RSP1/CPU0:Mar 29 13:23:27.984 : dhcpd[1064]: DHCPD PACKET:  >dhcpd_iox_l3_conn_hlr: recv, src 40.1.1.1 dst 39.1.1.2, L3I GigabitEthernet0_1_0_1, Null output,
RP/0/RSP1/CPU0:Mar 29 13:23:27.984 : dhcpd[1064]: DHCPD PACKET: TP609: BOOTREPLY Rx, chaddr 0003.a0fd.28a8, interface GigabitEthernet0_1_0_1
RP/0/RSP1/CPU0:Mar 29 13:23:27.985 : dhcpd[1064]: DHCPD PACKET: TP616: OFFER Rx, Relay chaddr 0003.a0fd.28a8, yiaddr 39.1.1.216
Offer received and IP address offered to us
RP/0/RSP1/CPU0:Mar 29 13:23:27.985 : dhcpd[1064]: DHCPD PACKET: TP799: Server reply opt 82 not present, chaddr 0003.a0fd.28a8
RP/0/RSP1/CPU0:Mar 29 13:23:27.985 : dhcpd[1064]: DHCPD PACKET: TP892: Broadcast-flag policy Ignore, chaddr 0003.a0fd.28a8
RP/0/RSP1/CPU0:Mar 29 13:23:27.985 : dhcpd[1064]: DHCPD PACKET: TP572: L3 packet TX bcast on intf GigabitEthernet0/1/0/14 to port 68, source 39.1.1.2, vrf 0x60000000 (1610612736), tbl 0xe0000000 (3758096384)
RP/0/RSP1/CPU0:Mar 29 13:23:27.985 : dhcpd[1064]: DHCPD PACKET:  >dhcpd_iox_l3_b
roadcast_packet: xmit, src 40.1.1.1 dst 39.1.1.2, L3I GigabitEthernet0_1_0_1, Null output, FROM L3
RP/0/RSP1/CPU0:Mar 29 13:23:27.985 : dhcpd[1064]: DHCPD PACKET: TP838: OFFER Tx, chaddr 0003.a0fd.28a8, yiaddr 39.1.1.216
RP/0/RSP1/CPU0:Mar 29 13:23:27.991 : dhcpd[1064]: DHCPD PACKET: TP564: L3 Packet RX from addr = 0.0.0.0, port = 68, application len 576, vrf 0x60000000 (1610612736), tbl 0xe0000000 (3758096384)
RP/0/RSP1/CPU0:Mar 29 13:23:27.991 : dhcpd[1064]: DHCPD PACKET:  >dhcpd_iox_l3_conn_hlr: recv, src 0.0.0.0 dst 255.255.255.255, L3I GigabitEthernet0_1_0_14, Null output,
RP/0/RSP1/CPU0:Mar 29 13:23:27.991 : dhcpd[1064]: DHCPD PACKET: TP608: BOOTREQUEST Rx, chaddr 0003.a0fd.28a8, interface GigabitEthernet0_1_0_14
RP/0/RSP1/CPU0:Mar 29 13:23:27.991 : dhcpd[1064]: DHCPD PACKET: TP617: REQUEST Rx, Relay chaddr 0003.a0fd.28a8
RP/0/RSP1/CPU0:Mar 29 13:23:27.991 : dhcpd[1064]: DHCPD PACKET: TP790: Client request opt 82 not untrust, chaddr 0003.a0fd.28a8
RP/0/RSP1/CPU0:Mar 29 13:23:27.992 : dhcpd[1064]: DHCPD PACKET: TP791: Giaddr not present, Set giaddr 39.1.1.2, chaddr 0003.a0fd.28a8
RP/0/RSP1/CPU0:Mar 29 13:23:27.992 : dhcpd[1064]: DHCPD PACKET: TP792: Client request opt 82 nothing to add, chaddr 0003.a0fd.28a8
Request packet received from client.
RP/0/RSP1/CPU0:Mar 29 13:23:27.992 : dhcpd[1064]: DHCPD PACKET: TP571: L3 packet TX unicast to dest 40.1.1.1, port 67, source 39.1.1.2, vrf 0x60000000 (1610612736), tbl 0xe0000000 (3758096384)
RP/0/RSP1/CPU0:Mar 29 13:23:27.992 : dhcpd[1064]: DHCPD PACKET:  >dhcpd_iox_l3_unicast_packet: xmit, src 0.0.0.0 dst 255.255.255.255, L3I GigabitEthernet0_1_0_14, Null output, FROM L3
Forwarded to helper 1
RP/0/RSP1/CPU0:Mar 29 13:23:27.992 : dhcpd[1064]: DHCPD PACKET: TP571: L3 packet TX unicast to dest 55.1.1.2, port 67, source 39.1.1.2, vrf 0x60000000 (1610612736), tbl 0xe0000000 (3758096384)
RP/0/RSP1/CPU0:Mar 29 13:23:27.993 : dhcpd[1064]: DHCPD PACKET:  >dhcpd_iox_l3_unicast_packet: xmit, src 0.0.0.0 dst 255.255.255.255, L3I GigabitEthernet0_1_0_14, Null output, FROM L3
Forwarded to helper 2, our reply is sent to both servers
RP/0/RSP1/CPU0:Mar 29 13:23:27.993 : dhcpd[1064]: DHCPD PACKET: TP841: REQUEST Tx, chaddr 0003.a0fd.28a8
RP/0/RSP1/CPU0:Mar 29 13:23:27.994 : dhcpd[1064]: DHCPD PACKET: TP564: L3 Packet
RP/0/RSP1/CPU0:Mar 29 13:23:27.994 : dhcpd[1064]: DHCPD PACKET:  >dhcpd_iox_l3_conn_hlr: recv, src 40.1.1.1 dst 39.1.1.2, L3I GigabitEthernet0_1_0_1, Null output,
RP/0/RSP1/CPU0:Mar 29 13:23:27.994 : dhcpd[1064]: DHCPD PACKET: TP609: BOOTREPLY Rx, chaddr 0003.a0fd.28a8, interface GigabitEthernet0_1_0_1
RP/0/RSP1/CPU0:Mar 29 13:23:27.994 : dhcpd[1064]: DHCPD PACKET: TP619: ACK Rx, Relay chaddr 0003.a0fd.28a8, yiaddr 39.1.1.216
RP/0/RSP1/CPU0:Mar 29 13:23:27.994 : dhcpd[1064]: DHCPD PACKET: TP799: Server reply opt 82 not present, chaddr 0003.a0fd.28a8
RP/0/RSP1/CPU0:Mar 29 13:23:27.994 : dhcpd[1064]: DHCPD PACKET: TP892: Broadcast-flag policy Ignore, chaddr 0003.a0fd.28a8
ACK received from our server
RP/0/RSP1/CPU0:Mar 29 13:23:27.995 : dhcpd[1064]: DHCPD PACKET: TP572: L3 packet TX bcast on intf GigabitEthernet0/1/0/14 to port 68, source 39.1.1.2, vrf 0x60000000 (1610612736), tbl 0xe0000000 (3758096384)
RP/0/RSP1/CPU0:Mar 29 13:23:27.995 : dhcpd[1064]: DHCPD PACKET:  >dhcpd_iox_l3_broadcast_packet: xmit, src 40.1.1.1 dst 39.1.1.2, L3I GigabitEthernet0_1_0_1, Null output, FROM L3
RP/0/RSP1/CPU0:Mar 29 13:23:27.995 : dhcpd[1064]: DHCPD PACKET: TP847: ACK Tx, chaddr 0003.a0fd.28a8, yiaddr 39.1.1.216
RP/0/RSP1/CPU0:Mar 29 13:23:29.985 : dhcpd[1064]: DHCPD PACKET: TP564: L3 Packet RX from addr = 55.1.1.2, port = 67, application len 300, vrf 0x60000000 (1610612736), tbl 0xe0000000 (3758096384)
RP/0/RSP1/CPU0:Mar 29 13:23:29.985 : dhcpd[1064]: DHCPD PACKET:  >dhcpd_iox_l3_conn_hlr: recv, src 55.1.1.2 dst 39.1.1.2, L3I GigabitEthernet0_1_0_0, Null output,
RP/0/RSP1/CPU0:Mar 29 13:23:29.986 : dhcpd[1064]: DHCPD PACKET: TP609: BOOTREPLY Rx, chaddr 0003.a0fd.28a8, interface GigabitEthernet0_1_0_0
RP/0/RSP1/CPU0:Mar 29 13:23:29.986 : dhcpd[1064]: DHCPD PACKET: TP259: BOOTREPLY Drop, Client not found, interface GigabitEthernet0_1_0_0, chaddr 0003.a0fd.28a8
This is the symptom described, the 2nd offer pre XR 4.1 is dropped by the dhcp relay agent in ios-xr. Post 4.1 we will forward all offers to the client.
This picture illustrates that behavior whereby the 2nd offer is not forwarded. In this case the red line is dashed meaning it made it through. The solid green line is not forwarded and is dropped by the ASR9000 dhcp relay agent.
How RELAY, SNOOPING and PROXY scale, come together and its relation to BNG
Relay
if you have relay then we punt the dhcp packets from the client send them over to the dhcp process, convert them in a directed broadcast or unicast
towards the helper and really relay only the messages back and forth. Other then CPU there is no operational overhead. No state is maintained,
except for a few second “hole” between server and client for when the offer comes back.
Relay scale
There is no scale associated with this per-se other then cpu (ran off the LC CPU for phy/subinterfaces and RP for bundle/bvi).
Proxy
if you have proxy, the transaction is controlled by the dhcp process. so client talks to a9k. a9k talks to the dhcp server and it will maintain
a binding that expires on lease and absence of a renew.
Proxy Scale
The scale associated here is cpu for the message transaction. ARP interaction since dhcp proxy will install a arp forwarding adj also
and memory for the binding table itself.
the other scale factor is here how far the TX ADJ table can grow from ARP, we tested up to 128k, but if you have enough shared mem, this can go
further than that, depending on the LC CPU mem (phy sub/if) or RP (bvi/bundle) can increase its shmem window (this is really like a ram disk and can
dynamically grow as needed). the other part is the tx adj table of the npu, there is a defined limit of about 128k I thought it was (mem size in resolve)
Snooping
Then there is snooping; this is really the same as proxy, but in an L2 environment AND with the notion that the binding table built is installed in the hw
forwarding. this is capped at 32k per npu. Advantage of snooping is that with the binding in hw, we can do extra verification checks on ingress to make
sure the mac/ip/port matches what is in the table. for egress outbound the tx adj is used installed.
Bng and Proxy
Now when you do BNG with proxy, it combines the operation of proxy and snooping:
a binding created by proxy is now installed in hw also, with those checks mention in effect. this caps bng/proxy to 32k per npu.
Summary
For proxy, snoop, bng/proxy
the 128k limit is really a testing limit defined by:
- (lc/rp) cpu capabity
- (lc/rp) cpu memory
- tx adj table
for snoop and bng/proxy since it is hw installed it caps it at
32k per npu, which is a hw limit.
for those sessions not needing bng, but requiring dhcp services, to allow for better mem/cpu control and scale, it might make more sense to do relay
here, but there is nothing against use of proxy per-se.
Related Information
All broadcasts are handled on the RP, in the ASR9000 or any XR platform for that matter, we use LPTS (local packet transport services) similar as what IOS calls COPP (control plane policing)
The policing is on a per NPU basis. Look at Packet trace and troubleshooting in the ASR9000
for more information on packet troubleshooting in the ASR9000.
Ok,
I'll do that.
Jean
smailmilak
Level 4
Level 4
Xander is right. I see that we talked about it 4 months ago.
Use seperate VLAN for IPTV and terminate it on regular L3 interface.
This will work for sure.
wojciechlubas
Hi Alexander,
I had recently a migration from c7600 on asr9k. I see one difference how dhcp relay behaves.
Since there is 3 vlans on ONT and everyone have to ask about its IP, on c7600 everything went at the same time. Now, as you wrote, ASR waits a minute and drops all discovers before timer expire. It makes ONT ready for work after 2 minutes (only first transaction is served immediatly). ASR don't care about different vlans, or relay profiles, just one mac is freezed and have to wait.
Could I somehow adjust this timer to make him a little bit smaller? Or is there any workaround? Because even if theese vlans are in different vrfs, ASR drops DISCOVERY before 60 seconds timer expire anyway.
wojciechlubas
OK, I found what I was looking for.
dhcp ipv4
 duplicate-mac-allowed
It makes possible using the same MAC address in several vlans without any impact on each other.
xthuijs
hi woj! what dhcp relay in XR does is that when we receive a discover, a temp "state" is added. that state will exist for a period of time, so that we can forward multiple offers back to the client.
if we get multiple discovers in, we should be able to forward them just fine.
however if the discovers have all the same smac, it looks like as if it is the same station requesting. Is that what you are observing? That is, is the ont acting as a proxy to regenerate the client discovers with its own mac?
if that is the case, we could leverage proxy in XR and use the allow dupe mac knob to key on something else then mac only.
for relay this will be tricky.
xander
xthuijs
xander
xthuijs
yup, if you have the same mac in different vlans, this command does the trick!
if same mac in same vlan, that is tricky stuff of course, but doesnt sound like you are having that.
xander
wkrapf
Community Member
Hello!
At first, thanks for the very useful document :-)
We are using DHCP relay feature (in combination with VPLS and VRRP), which basically works fine.
But if I apply an ingress ACL on the BVI where the DHCP packets enter the ASR and should get relayed, behaviour gets totally weird - lost OFFER-packets, need 4-5 DISCOVER messages from client until an offer gets back to the client, ... We are currently running XR5.1.3SP5.
Any ideas? Maybe SW upgrade?
kind regards
philipp
xthuijs
thank you! :) and that behavior doesnt sound right philipp.
try this: instead of the acl on the bvi, apply it to the EFPs and see if that mitigates the issue.
or apply an explicit permit for the dhcp packets on top of the acl definition (this also to see the matches).
Can you see also are the paks dropped by ACL or at the punt or dhcp?
show controller np counters
show dhcp ipv4 relay stat [raw]
debug dhcp ipv4 packet
would help here possibly.
regards
xander
wkrapf
Community Member
hello xander!
thanks very much for the reply. i think i figured it out, obviously not an asr problem but an ACL-Problem with ECMP and VRRP (replies from DHCP-Server *can* come via router1 to router2 and vice versa with a source address of one of the DHCP-servers, packets get dropped by ingress ACL). edited ACL (also allow DHCP servers as source addresses), relaying seems to work pretty fine now :-)
but another (asr-related) question came up when locking at the packet debug: there are messages like these:
RP/0/RSP0/CPU0:May 31 10:17:19.740 CEST: dhcpd[1077]: DHCPD PACKET: TP564: L3 Packet RX from addr = 129.27.XX.152, port = 68, application len 300, vrf 0x60000006 (1610612742), tbl 0xe0000015 (3758096405)
RP/0/RSP0/CPU0:May 31 10:17:19.740 CEST: dhcpd[1077]: DHCPD_PACKET: pktRx id 54: ---------- IPv4 DHCPD --- dhcpd_iox_l3_conn_hlr -------
RP/0/RSP0/CPU0:May 31 10:17:19.740 CEST: dhcpd[1077]: DHCPD_PACKET: pktRx id 54: VRF name (id): vrfservice (0x60000006)
RP/0/RSP0/CPU0:May 31 10:17:19.740 CEST: dhcpd[1077]: DHCPD_PACKET: pktRx id 54: L3 src: 129.27.XX.152
RP/0/RSP0/CPU0:May 31 10:17:19.741 CEST: dhcpd[1077]: DHCPD PACKET: TP628: DISCOVER Rx, Snoop Init state, interface BVI125, chaddr cdef.9441.abcd
RP/0/RSP0/CPU0:May 31 10:17:19.741 CEST: dhcpd[1077]: DHCPD PACKET: TP380: DISCOVER error Drop, Snoop Init state, chaddr cdef.9441.abcd
RP/0/RSP0/CPU0:May 31 10:17:19.741 CEST: dhcpd[1077]: DHCPD PACKET: TP200: *** Packet Could not be PROCESSED ***
from interfaces - in this case bvi125 -  where no dhcp relay profile (nor anything else interface-related in the dhcp ipv4 section) is configured. does the ASR snoop anyway on these interfaces, so normal behaviour?
regards
philipp
xthuijs
nice going philipp, yeah that acl edit would help :) so for this other question yeah if you dont have a relay profile configured, BUT you do have dhcp services and you get a dhcp discover in, it is processed and dropped. precisely as you see here.
cheers
xander
wkrapf
Community Member
so, normal behaviour. thanks a lot!
regards,
philipp
Hello Xander,
I have some services that you use my IOS Router as a DHCP Relay Agent. I have several sub-interfaces configured with IP Unnumbered like the example below:
interface GigabitEthernet0/1.130
 description XXXX
 encapsulation dot1Q 130
 ip dhcp relay information trusted
 ip unnumbered Loopback8
 ip helper-address x.x.x.x
 no cdp enable
end
This unnumbered configuration works because of this: "The Cisco DHCP relay agent supports unnumbered interfaces. The DHCP relay agent automatically adds a static host route specifying the unnumbered interface as the outbound interface."
I tried this scenario in IOS-XR and notice that the router do not add a static host route specifying the unnumbered interface.
Do you know why? and how could make this work?
xthuijs
hi michael, yeah the forwarding infra and dhcp relay for xr can't handle that situation today.
an alternative is using dhcp proxy that maintains bindings, or putting the subinterfaces in a bridge domain and using dhcp snooping or a bvi with a helper in dhcp relay config.
cheers!
xander
Thank you for quick response. I 'll give it a try to the Bridge domain and BVI option.
