xthuijs
Introduction
This document provides details on how QOS is implemented in the ASR9000 and how to interpret and troubleshoot qos related issues.
Core Issue
QOS is always a complex topic and with this article I'll try to describe the QOS architecture and provide some tips for troubleshooting.
Based on feedback on this document I'll keep enhancing it to document more things bsaed on that feedback.
The ASR9000 employs an end to end qos architecture throughout the whole system, what that means is that priority is propagated throughout the systems forwarding asics. This is done via backpressure between the different fowarding asics.
One very key aspect of the A9K's qos implementation is the concept of using VOQ's (virtual output queues). Each network processor, or in fact every 10G entity in the system is represented in the Fabric Interfacing ASIC (FIA) by a VOQ on each linecard.
That means in a fully loaded system with say 24 x 10G cards, each linecard having 8 NPU's and 4 FIA's, a total of 192 (24 times 8 slots) VOQ's are represented at each FIA of each linecard.
The VOQ's have 4 different priority levels: Priority 1, Priority 2, Default priority and multicast.
The different priority levels used are assigned on the packets fabric headers (internal headers) and can be set via QOS policy-maps (MQC; modular qos configuration).
When you define a policy-map and apply it to a (sub)interface, and in that policy map certain traffic is marked as priority level 1 or 2 the fabric headers will represent that also, so that this traffic is put in the higher priority queues of the forwarding asics as it traverses the FIA and fabric components.
If you dont apply any QOS configuration, all traffic is considered to be "default" in the fabric queues. In order to leverage the strength of the asr9000's asic priority levels, you will need to configure (ingress) QOS at the ports to apply the priority level desired.
In this example T0 and T1 are receiving a total of 16G of traffic destined for T0 on the egress linecard. For a 10G port that is obviously too much.
T0 will flow off some of the traffic, depending on the queue, eventually signaling it back to the ingress linecard. While T0 on the ingress linecard also has some traffic for T1 on the egress LC (green), this traffic is not affected and continues to be sent to the destination port.
Resolution
The ASR9000 has the ability of 4 levels of qos, a sample configuration and implemenation detail presented in this picture:
Policer having exceeddrops, not reaching configured rate
When defining policers at high(er) rates, make sure the committed burst and excess burst are set correctly.
This is the formula to follow:
Set the Bc to CIR bps * (1 byte) / (8 bits) * 1.5 seconds
and
Be=2xBc
Default burst values are not optimal
Say you are allowing 1 pps, and then 1 second you don’t send anything, but the next second you want to send 2. in that second you’ll see an exceed, to visualize the problem.
Alternatively, Bc and Be can be configured in time units, e.g.:
     policy-map OUT
      class EF
       police rate percent 25 burst 250 ms peak-burst 500 ms
For viewing the Bc and Be applied in hardware, run the "show qos interface interface [input|output]".
Why do I see non-zero values for Queue(conform) and Queue(exceed) in show policy-map commands?
On the ASR9k, every HW queue has a configured CIR and PIR value. These correspond to the "guaranteed" bandwidth for the queue, and the "maximum" bandwidth (aka shape rate) for the queue.
In some cases the user-defined QoS policy does NOT explicitly use both of these.  However, depending on the exact QoS config the queueing hardware may require some nonzero value for these fields.  Here, the system will choose a default value for the queue CIR.  The "conform" counter in show policy-map is the number of packets/bytes that were transmitted within this CIR value, and the "exceed" value is the number of packets/bytes that were transmitted within the PIR value.
Note that "exceed" in this case does NOT equate to a packet drop, but rather a packet that is above the CIR rate on that queue.
You could change this behavior by explicitly configuring a bandwidth and/or a shape rate on each queue, but in general it's just easier to recognize that these counters don't apply to your specific situation and ignore them.
What is counted in QOS policers and shapers?
When we define a shaper in a qos pmap, the shaper takes the L2 header into consideration.
The shape rate defined of say 1Mbps would mean that if I have no dot1q or qinq, I can technically send more IP traffic then having a QIQ which has more L2 overhead. When I define a bandwidth statement in a class, same applies, also L2 is taken into consideration.
When defining a policer, it looks at L2 also.
In Ingress, for both policer & shaper, we use the incoming packet size (including the L2 header).
In order to account the L2 header in ingress shaper case, we have to use a TM overhead accounting feature, that will only let us add overhead in 4 byte granularity, which can cause a little inaccuracy.
In egress, for both policer & shaper we use the outgoing packet size (including the L2 header).
ASR9K Policer implementation supports 64Kbps granularity. When a rate specified is not a multiple of 64Kbps the rate would be rounded down to the next lower 64Kbps rate.
For policing, shaping, BW command for ingress/egress direction the following fields are included in the accounting.
MAC DA
MAC SA
EtherType
VLANs..
L3 headers/payload
CRC
Port level shaping
Shaping action requires a queue on which the shaping is applied. This queue must be created by a child level policy. Typically shaper is applied at parent or grandparent level, to allow for differentiation between traffic classes within the shaper. If there is a need to apply a flat port-level shaper, a child policy should be configured with 100% bandwidth explicitly allocated to class-default.
Understanding show policy-map counters
QOS counters and show interface drops:
Policer counts are directly against the (sub)interface and will get reported on the "show interface" drops count.
The drop counts you see are an aggregate of what the NP has dropped (in most cases) as well as policer drops.
Packets that get dropped before the policer is aware of them are not accounted for by the policy-map policer drops but may
show under the show interface drops and can be seen via the show controllers np count command.
Policy-map queue drops are not reported on the subinterface drop counts.
The reason for that is that subinterfaces may share queues with each other or the main interface and therefore we don’t
have subinterface granularity for queue related drops.
Counters come from the show policy-map interface command
Class name as per   configuration Class   precedence6
Statistics for this class   Classification statistics          (packets/bytes)     (rate - kbps)
Packets that were matched     Matched             :            31583572/2021348608           764652
packets that were sent to the wire     Transmitted         : Un-determined
packets that were dropped for any reason   in this class     Total Dropped       : Un-determined
Policing stats   Policing statistics                (packets/bytes)     (rate - kbps)
Packets that were below the CIR rate     Policed(conform)    :            31583572/2021348608           764652
Packets that fell into the 2nd bucket   above CIR but < PIR     Policed(exceed)     :                   0/0                    0
Packets that fell into the 3rd bucket   above PIR     Policed(violate)    :                   0/0                    0
Total packets that the policer dropped     Policed and dropped :                   0/0
Statistics for Q'ing   Queueing statistics  <<<----
Internal unique queue reference     Queue ID                             : 136
how many packets were q'd/held at max one   time
(value not supported by HW)
    High watermark  (Unknown)
number of 512-byte particles which are currently
waiting in the queue
    Inst-queue-len  (packets)            : 4096
how many packets on average we have to   buffer
    Avg-queue-len   (Unknown)
packets that could not be buffered   because we held
more then the max length
    Taildropped(packets/bytes)           : 31581615/2021223360
see description above (queue exceed section)     Queue(conform)      :            31581358/2021206912           764652
see description above (queue exceed section)     Queue(exceed)       :                   0/0                    0
Packets subject to Randon Early detection
and were dropped.
    RED random drops(packets/bytes)      : 0/0
Understanding the hardware qos output
RP/0/RSP0/CPU0:A9K-TOP#show qos interface g0/0/0/0 output
With this command the actual hardware programming can be verified of the qos policy on the interface
(not related to the output from the previous example above)
Tue Mar  8 16:46:21.167 UTC
Interface: GigabitEthernet0_0_0_0 output
Bandwidth configured: 1000000 kbps Bandwidth programed: 1000000
ANCP user configured: 0 kbps ANCP programed in HW: 0 kbps
Port Shaper programed in HW: 0 kbps
Policy: Egress102 Total number of classes: 2
Level: 0 Policy: Egress102 Class: Qos-Group7
QueueID: 2 (Port Default)
Policer Profile: 31 (Single)
Conform: 100000 kbps (10 percent) Burst: 1248460 bytes (0 Default)
Child Policer Conform: TX
Child Policer Exceed: DROP
Child Policer Violate: DROP
Level: 0 Policy: Egress102 Class: class-default
Default Marking behavior of the ASR9000
If you don't configure any service policies for QOS, the ASR9000 will set an internal cos value based on the IP Precedence, 802.1 Priority field or the mpls EXP bits.
Depending on the routing or switching scenario, this internal cos value will be used to do potential marking on newly imposed headers on egress.
Scenario 1
Scenario 2
Scenario 3
Scenario 4
Scenario 5
Scenario 6
Special consideration:
If the node is L3 forwarding, then there is no L2 CoS propagation or preservation as the L2 domain stops at the incoming interface and restarts at the outgoing interface.
Default marking PHB on L3 retains no L2 CoS information even if the incoming interface happened to be an 802.1q or 802.1ad/q-in-q sub interface.
CoS may appear to be propagated, if the corresponding L3 field (prec/dscp) used for default marking matches the incoming CoS value and so, is used as is for imposed L2 headers at egress.
If the node is L2 switching, then the incoming L2 header will be preserved unless the node has ingress or egress rewrites configured on the EFPs.
If an L2 rewrite results in new header imposition, then the default marking derived from the 3-bit PCP (as specified in 802.1p) on the incoming EFP is used to mark the new headers.
An exception to the above is that the DEI bit value from incoming 802.1ad / 802.1ah headers is propagated to imposed or topmost 802.1ad / 802.1ah headers for both L3 and L2 forwarding;
Related Information
ASR9000 Quality of Service configuration guide
Xander Thuijs, CCIE #6775
xthuijs
Hi Catalin, thanks! :) So I see why you think scenario 6, but in fact you are hitting scenario 5. So in that case the IPP is used for the internal cos and set on the new headers imposed exp or dot1q.
If you like to leverage the EXP instead in your case, you will need to make a policy-map to set a qos-group derived from the exp, and on egress use that qos-group to set the dot1p.
cheers
xander
hi Xander ,
Not sure why is scenario 5 tbh as the packet has a label. Also if on outbound interface i apply a policy to match cos ( internal i assume ) i got hits on that.
Worth mentioning the packet is a p2mp/mldp multicast.
edit :  an vpn unicast ping with IPP=0 marked to exp4 on ingress PE get sent to egree with dot1q 4 and IPP=0 , so looks like scenario 6 is the one for unicast , not sure why m-cast is not the same.
Thx,
Catalin
ingress:
RP/0/RSP1/CPU0:#sh policy-map interface Te0/0/1/1 | b Class EXP_4
Wed Nov 18 12:52:09.989 GMT
Class EXP_4_CE
Matched : 50326200/66430584000 52630
class-map match-any EXP_4_CE
match mpls experimental topmost 4
end-class-map
egress:
TenGigE0/0/0/2.401 output: PE-CE
Class IPP_4_CE1
Matched : 48021699/63388642680 44866
policy-map PE-CE
class IPP_4_CE1
priority level 1
police rate percent 10
class class-default
end-policy-map
class-map match-any IPP_4_CE1
match cos 4
end-class-map
Adam Vitkovsky
Level 3
Level 3
Hi Xander,
Thank you very much for these articles
1) Regarding Backpressure:
egress NP -> egress FIA -> fabric Arbiter -> ingress FIA -> VoQ
                   - the granularity of backpressure is per VoQ but BE packets are dropped first (WRED),
                   then P2, then P1 - is that right please?
Based on what are the access grants issued by the Fabric arbiter please?
                  - Is it based on the sum of egress port capacity of an Egress NP
                  - or based on actual Egress NP capability to process traffic.
E.G. if Egress NP has to process high PPS rate on input
and in addition a lot of features are enabled on the Egress NP
and as a result it is unable to process Egress traffic at full line rate
                   - Will it issue backpressure towards FIA, Fabric and ingress NPs?
                   - Also will it issue pause frames in attempt to slow down the high PPS WAN input?
If NP does not initiate backpressure or pause frames based on its ability to process traffic
                   - If in overload monde:
                                      - On Fabric input is it guaranteed that it will start dropping low priority traffic
                                         first, trying to protect the CP and P1 traffic or possibly P2 traffic.
                                      - On WAN input is it guaranteed that it will start dropping low priority traffic
                                         first, trying to protect the P1 or possibly P2 traffic
                                         (CP traffic has to be manually matched to P1 on input right?)
                   - Will it start dropping WAN input and Fabric input equally please?
                                      - Is WAN input and Fabric input serviced 1:1 by the NP
                                      - Is there a strict priority on NP
                                      or is it more like HP1:MP2:MP3:LP = 16:4:2:1 or something like that?
2) Regarding the Fabric arbitration
-what is “credit return” please?
3) Regarding the VOQ.
Just to confirm the nomenclature:
-VOQ consist of 4 VQIs i.e. P1, P2, BE, M-CAST please?
On Trident LCs:
VOQ per NP, basically 4 VQI per 10GE port?
On Typhoon LCs:
10GE port has 4 VQIs: P1, P2, BE, M-CAST
40GE port has 8 VQIs: 2xP1, 2xP2, 2xBE, 2xM-CAST
100GE port has 16 VQIs: 4xP1, 4xP2, 4xBE, 4xM-CAST
Is CP = HP1
Is P1 = MP2
Is P2 = MP3
Is LP = LP
How it translates to Typhoon Egress: P1,P2,P3,LP
thank you very much
adam
Xing Cheng Hou
Hi Alexander
When implementing QoS on ASR9010/ASR9006, I encountered the following issue:
interface TenGigE0/x/x/x
service-policy output Parent_FA_Egress-GRP
!!% 'qos-ea' detected the 'warning' condition 'Queue related actions on a class require parent class to have queue'
Parent_FA_Egress-GRP is a H-QoS policy map.
Would you please give some comments about the issue ?
Xing Cheng Hou
Hi Alexander
when implementing the H-QoS on ASR9010/ASR9006 with 5.3.2 , I encountered an issue
interface TenGigE0/3/0/x
Would you please give some comments or suggestion about this troubleshooting?
Br
Vincent
Aleksandar Vidakovic
hi Vincent,
you are very likely missing a shaper at the parent level. Without parent shaper the child policy doesn't have a reference bandwidth.
Aleksandar
Xing Cheng Hou
Hi Aleksandar
Thank you for your reply. It works when adding shaper under parent level.
1. If I want to policy the flow rather than shaping the flow, how do I configure it ?
2. If the configuration is listed as below:
interface Te0/0/0/0
policy-map Parent_FA_Egress
class class-default
  service-policy Child_FA_Egress
  police rate 1000 mbps
  shape average percent 90
policing will be 1000 mbps, will be shaping when flow is outof 90% of 10G, right?
hi Vincent,
if you have a policer at the parent level then you want to deploy the conform-aware hierarchical policer. There is a good example at:
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r4-2/qos/configuration/guide/qc42hqos.html#wp1238117
For #2, your understanding is correct. I have to say that the example is good for theoretical discussion but in practice this config would be rejected because the flat shaper rate on an interface can't exceed 4Gbps. Also, the shaper would never kick in because policer is applied first and the policer rate is much lower than the shaper rate.
regards,
Aleksandar
Limitations on using IPv4 ACL to define class-map on an MPLS enabled link.
Xander - we are trying to use the following config to prioritize some management type traffic (stuff like TACACS, SSH, SNMP, etc.)  We configure an ACL to define our class-map to match TACACS traffic for example.  This works fine on the router that is generating the traffic, but not on the next hop router.  I believe we are having some sort of issue matching the ACL due to the MPLS header since our ACL doesn't see any packets matched.
Can you please confirm that ACL matching is not supported on 5.2.2 for an MPLS LDP interface?
Here's my configs:
Router A te0/0/2/1 connects to Router B te0/0/2/0.  We see packets matching on egress on Router A (and forwarded appropriately), but not on ingress to Router B (which 'breaks' our QoS design).
Router A:
policy-map PMAP-QOS-CORE
< OUTPUT OMITTED >
class CMAP-QOS-TACACS
priority level 1
< OUTPUT OMITTED >
end-policy-map
class-map match-any CMAP-QOS-TACACS
description QOS CMAP - MATCH TACACS TRAFFIC
match access-group ipv4 ACL-QOS-TACACS
end-class-map
ipv4 access-list ACL-QOS-TACACS
10 remark QOS ACL - MATCH TACACS TRAFFIC
20 permit tcp any any eq tacacs
30 permit tcp any eq tacacs any
40 permit udp any any eq tacacs
50 permit udp any eq tacacs any
interface TenGigE0/0/2/1
description TE0/0/2/1->CORE-02_TE0/0/2/0
cdp
mtu 9100
service-policy output PMAP-QOS-CORE
ipv4 point-to-point
ipv4 address 10.0.0.10 255.255.255.252
flow-control bidirectional
carrier-delay up 100 down 0
load-interval 30
ethernet oam
profile OAM_Core
transceiver permit pid all
ipv4 access-group TEST ingress hardware-count interface-statistics
ipv4 access-group TEST egress hardware-count interface-statistics
mpls ldp
log
neighbor
nsr
graceful-restart
session-protection
nsr
graceful-restart
igp sync delay on-session-up 30
router-id 4.4.4.4
address-family ipv4
label
local
advertise
explicit-null
Router A - sees TACACS packets egress
RP/0/RSP0/CPU0:AGG-02#sh access-lists TEST hardware egress int te0/0/2/1 loc 0/0/cpu0
Tue Jan 26 13:30:46.493 UTC
ipv4 access-list TEST
10 permit tcp any any eq tacacs (1087 hw matches)
20 permit tcp any eq tacacs any
30 permit udp any any eq tacacs
40 permit udp any eq tacacs any
50 permit ipv4 any any (5772583 hw matches)
Router B:
interface TenGigE0/0/2/0
description TE0/0/2/0->AGG-02_TE0/0/2/1
cdp
mtu 9100
ipv4 point-to-point
ipv4 address 10.0.0.9 255.255.255.252
monitor-session SNIFF ethernet
load-interval 30
ethernet oam
profile OAM_Core
mpls ldp
log
neighbor
nsr
graceful-restart
session-protection
nsr
graceful-restart
router-id 3.3.3.3
Router B - does not see TACACS packets ingress, hence the packets are not classified correctly on egress to the next router, which 'breaks' our QoS.
RP/0/RSP0/CPU0:CORE-02#sh access-lists TEST hardware ingress int te0/0/2/0 loc 0/0/cpu0
Tue Jan 26 13:31:29.504 UTC
50 permit ipv4 any any (11662343 hw matches)
I think this is some sort of limitation of the code we are running.  The packet captures look fine - they are just IPv4 packets with an MPLS header on them.
Any ideas?  If we can't match on an IPv4 ACL, we'd like to do EXP marking, but I don't believe that is not supported for TACACS like DSCP is.  Same goes for other services like Telnet, SSH, SNMP, etc. (you can set DSCP, but not EXP, per service).
TAC SR 637839463
RP/0/RSP0/CPU0:CORE-02#admin sh install active summ
Tue Jan 26 13:43:56.097 UTC
Default Profile:
SDRs:
Owner
Active Packages:
disk0:asr9k-9000v-nV-px-5.2.2
disk0:asr9k-asr901-nV-px-5.2.2
disk0:asr9k-doc-px-5.2.2
disk0:asr9k-fpd-px-5.2.2
disk0:asr9k-k9sec-px-5.2.2
disk0:asr9k-mcast-px-5.2.2
disk0:asr9k-mgbl-px-5.2.2
disk0:asr9k-mini-px-5.2.2
disk0:asr9k-mpls-px-5.2.2
disk0:asr9k-services-px-5.2.2
disk0:asr9k-px-5.2.2.CSCuq87630-1.0.0
disk0:asr9k-px-5.2.2.CSCur13869-1.0.0
disk0:asr9k-px-5.2.2.CSCur17985-1.0.0
disk0:asr9k-px-5.2.2.CSCur46358-1.0.0
disk0:asr9k-px-5.2.2.CSCur62957-1.0.0
disk0:asr9k-px-5.2.2.CSCur69192-1.0.0
disk0:asr9k-px-5.2.2.CSCur76163-1.0.0
disk0:asr9k-px-5.2.2.CSCur83223-1.0.0
disk0:asr9k-px-5.2.2.CSCur87691-1.0.0
disk0:asr9k-px-5.2.2.CSCus21011-1.0.0
disk0:asr9k-px-5.2.2.CSCus40073-1.0.0
disk0:asr9k-px-5.2.2.CSCus45891-1.0.0
disk0:asr9k-px-5.2.2.CSCus54586-1.0.0
Just got an email from TAC - see bug ID CSCud94957
jespino2
Hello, Alexander. Really nice article!
I have a question: What happened to the counters that shown on regular IOS with the show service-policy interface command? I'm looking for a command that shows the number of matches per classification but have not been able to found none.
I'm guessing there is only one counter in the IOS-XR implementation that aggregates all the match numbers into one but would like your comments.
Thank you very much and keep on the good work!
Class-map: DataPlus (match-any)
          18995418 packets, 4643254933 bytes
          30 second offered rate 4000 bps, drop rate 0000 bps
          Match: ip dscp af22 (20)
          Match: ip dscp cs3 (24)
          Match: ip precedence 3
          Match: ip dscp af21 (18)
          Queueing
          queue limit 19 packets
          (queue depth/total drops/no-buffer drops) 0/126973/0
          (pkts output/bytes output) 18868446/4602190045
          bandwidth 20% (76 kbps)
xthuijs
hi! and thank you :) yeah the way the classification works is that a packet received is sent with a set of keys (ip fields) to the tcam for a match, we get the match back that reports the class ID.
the class-id or map keeps the rate for QOS.
for regular ACL we can keep track of per ACE counters, but I am not sure if they would apply also when they are aggregated for a class match
so for your case to find out rates/matches per match criteria, I dont think there is another way then to put the different matches in different classes to get the per class (hence match) counters.
cheers!
xander
Brian Luers
Is there a way to configure the ASR9K to ignore the L2 header and only take the L3 header into consideration?  IF so what is the link to configure and minimum XR version supported?
Yes, you can do that:
RP/0/RSP0/CPU0:IM1(config)#int te 0/0/1/1
RP/0/RSP0/CPU0:IM1(config-if)#service-policy input test account user-defined ?
<-63,+63> Overhead accounting value
This is quite an old functionality, you should be able to use it in all supported releases. Our recommendation is to always go with the latest Extended Maintenance Release.
regards,
Aleksandar
Brian Luers
What about the following command available under GSR routers (would like to apply the same command whether the frames are single vlan tagged, or double tagged).
http://www.cisco.com/c/en/us/td/docs/routers/xr12000/software/xr12k_r4-2/qos/command/reference/b_qos_cr42xr12k/b_qos_cr42xr12k_chapter_01.html#wp2141651178
service-policy (interface)
To attach a policy map to an input interface or output interface to be used as the service policy for that interface, use the service-policy command in the appropriate configuration mode. To remove a service policy from an input or output interface, use the no form of the command.
service-policy { input | output } policy-map [ account nolayer2 ]
no service-policy { input | output } policy-map [ account nolayer2 ]
Syntax Description
input
Attaches the specified policy map to the input interface.
output
Attaches the specified policy map to the output interface.
policy-map
Name of a service policy map (created using the policy-map command) to be attached.
account nolayer2
(Optional) Turns off layer 2 QoS-specific accounting and enables Layer 3 QoS accounting.
