04-17-2016 05:43 AM - edited 01-29-2019 08:04 AM
Geo redundancy is a powerful new technology for XR BNG that allows for session synchronization between 2 nodes. This means that a session active on one node has a shadow and fully programmed session on a standby node, so that when the active chassis fails, the standby BNG can take over and continue to forward the session info WITHOUT service interruption to the user.
Geo redundancy overcomes some of the restrictions that other redundancy models have which makes it a solution that is very compelling.
Some of the existing models include the use of PPPoE smart server selection, ASR9K nv Cluster, ISSU, MC-LAG/MSTAG. This section outlines their operation and pros/cons.
Smart server selection relies on the operation whereby a host sends a PADI (discovery), which is broadcast to multiple devices/BNG's. Normally all hosts send a PADO (offer) back to the client who then connects with one of the offered BNG's for a single connection. By controlling the response time of the PADO's from all BNG's we can make one node more primary for a particular vlan, and the other(s!) standby.
The solution is stateless, meaning that if the active node dies, the client needs to rediscover and will find one or more stadnby BNG's for connection with.
Pro is that this is simple, useful, it provides N+1 redundancy (multiple BNG nodes can be used on the segment for more sharing of the load).
Con is that this is stateless, clients have to reconnect, per vlan bases and for PPPoE only (not usable for dhcp). Though a similar concept can be leveraged for IP sessions by delaying the offer timers of the dhcp server.
Clustering two devices by linking their brains together via what we call the EOBC (Ether out of band connection), makes two chassis become a perfect mirror from each other. This automatically means that you have stateful redundancy.
It relies on the fact that you are dual homed with a connection in both both racks of the cluster. If the cluster device or rack we call it, fails the other chassis will take over as sole primary and the forwarding over the bundle all happens without any disruption
Pro: powerful, stateful, high scale
Con: sw upgrades, hw restrictions for cluster, requires bundle intefaces and dual homing into both nodes of the cluster, costly/license
Using standard redundancy technologies like mclag or mstag provides for a lot of simplicity. These technologies allow for dual homing and relying on ICCP (mclag) or STP (MSTAG) protocols to detect loops and only have one active link forwarding.
This means that a session is only available and active on one node at the time.
Pro: very simple low cost
Con: long convergence times and stateless
How nice would it be to have the best of all these solutions and not having so much cons? That is where GeoRed comes into play :)
Geo redundancy provides for a very powerful M:N or N+1 redundancy model depending on how you like to implement it.
Flexible redundancy models via pairing across routers on Access Link basis
- 1:1 (both active/active with load sharing or active/standby) (like nv Cluster)
- M:N (active/standby roles and load is split across multiple routers)
- N:1 (1 backup for N active)
Full circle standby (M:N)
Designated backup (N:1)
There is no special connection required between the BNG's, just an ip connectivity for the redundancy protocol (to be discussed later).
One big advantage is also that the different BNG nodes may be placed in different geo-locations without any limitations!
Complements existing BNG high-availability, redundancy and geo-redundancy mechanisms.
Geo redundancy in a nutshell:
A typical design could look like this:
CPEs are agnostic to redundancy and they see “one BNG / Gateway”. Any switchover is transparent to them. With the redundancy model used, the CPE peers with the same mac address and node ID hence if a failover is required the CPe doesn't even know that it is talking to a different physical device.
Access Nodes are dual/multi-homed for redundancy using a variety of technologies such as MCLAG, Dual Homed (MST-AG), Ring (MST-AG or G.8032), xSTP, Seamless MPLS (PWs), etc. Using heartbeat mechanisms like E-OAM, BFD, etc. for faster fault detection/isolation.
BNG is not just a gateway router, it has subscriber state, policies and accounting/authorization details and subscriber features. Redundancy and synchronization also require sharing of protocol state like DHCP and PPP.
A good redundancy solution also should employ seamless integration with external servers like DHCP/Radius and backend policy/billing systems.
The concept for geo-redundancy is built on top of a sync protocol that is used in MCLAG also: ICCP (inter chassis communication protocol). It is a reliable protocol that allows for state and info sync between 2 chassis.
One of the basic pieces to that is the definition of what we in GEORED will call the Subscriber Redundancy Group (SRG).
Taking the picture from above, that shows the M:N or N:1 redundancy topologies, an SRG is the equivalent of the "X" or "Y" arrows:
Synchronization from “master” to “slave” is done over TCP on per SRG basis between routers using proprietary mechanism – BNG Sync
This mechanism serves the following purposes:
When BNG SRG peers connect, first the master slave determination is done, after which sync of state happens from master to slave followed by regular mirroring that happens without delay with without holding up the session provisioning on master.
Session mirroring takes care of complete state once the session is up; and when there is any change or when it is deleted
Master/Slave roles are defined by the SRG and not defined as a BNG router by itself. This simply means that SRG1 can be active on router ONE and SRG2 will be active on router TWO, and SRG1 will be standby on router TWO also.
active/active – (eg the M:N) BNG could be master for one SRG and slave for another
active/standby – (eg the N:1) dedicated backup BNG could be slave for multiple SRGs from different active BNGs which are masters for those respective SRGs
Role negotiated via BNG sync between routers on per SRG level
Where possible, role can be determined by the underlying access technology
In master role BNG will handle and process all control traffic it receives
In slave role BNG will ignore all BNG and related protocols traffic. It will receive state notifications of the session via the ICCP communication from the active node serving that SRG.
GEORED can operate in two distinct redundancy operations. That is hot and warm standby.
Hot-Standby Mode (default)
Sessions provisioned on slave in sync with setup on master
Since the sessions are actively programmed on the standby, this will consume hardware resources on slave. Proper planning is necessary here, since if we have BNG node X and Y both serving 50k sessions each, the slave node needs to be able to support 100k sessions when they are actively programmed!
Minimal action on switchover; data plane is already setup for sub-second traffic impact, this is the highest level of redundancy you can achieve.
And especially useful in deployments requiring high and tight SLA
Warm-Standby Mode (for over-subscription)
Sessions data kept in “shadow” database on slave in sync with setup on master
Only consumes some additional memory in control plane for the shadow copy – no provisioning in hardware
Upon failover trigger, sessions are setup at rapid pace from shadow copy
This allows for over provisioning on backup for subscribers. While it still provides for a high level of redundancy, and the "outage" or forwarding loss is determined by the time it takes to hw program the sessions served by the SRG, the failover will result in some session loss (if the SRG serves high number of sessions that take longer to program then the keepalive/timeout of the session).
Example scenario with an active/standby, N:1 model:
Example scenario with an active/active, N:1 model:
some important notes regarding radius accounting and authorization information
One of the big advantages of GEORED that overcomes a painpoint of nV cluster is the sw upgrades.
In cluster, an orchestration is necessary to separate the cluster nodes, upgrade one and make a quick switch over to upgrade the other one.
In Geo Redundancy, the BNG nodes can run different sw versions even! and that is no problem. Although we wouldn't recommend too much version disparity between the devices and for the ease of deployment have all BNG nodes in the network, regardless of being part of the GEORED to be on the same sw version as much as possible with the same smu set.
The SW upgrade procedure would be opaque to the redundancy model chosen (N:1, M:N, active/active or active/standby).
Basically the steps include:
And do this for all the BNG nodes part of the SRG interaction.
NOTE: you can even setup GEO red just for the upgrade procedure. A node that is synchronizing its sessions during this setup is not affected whatsoever.
The following section graphs out the call flow and messaging between BNG SRG devices and the session.
The MSTP protocol is used here to block standby path so we have only one active
In this case each BNG have their own MAC which is used for MST and other Ethernet protocols. In this scenario we need to setup SRG vMAC for BNG sessions. Which will act like an HSRP/VRRP virtual mac in the same facinity. The BNG's use their own mac for the STP communication, we'll use the vmac towards the sessions as their peering/communication point.
For dual homing two MST instances required with VLANs split across them to enable active/active load balancing to each of the 2 BNGs
MST provides “preempt delay” knobs to throttle switchovers and allow stabilization of subscribers on top of it after failure recovery.
Failure detection, or the improved detection for it is done via CFM sessions (at least one per MST instance in any of its VLAN). The CFM session is used to monitor connectivity and to detect which BNG has the forwarding path and which one has the standby/drop path (i.e. CFM session will be UP on active & DOWN on standby)
Coupling the CFM session via EFD with each of the BNG L3 access sub-interfaces on that interface will result in that sub-interface status tracking UP on active side and DOWN on standby side.
Access tracking object monitoring this sub-interface status (which is in turn controlled via EFD based on CFM session) is used for determining SRG role as well as controlling the subscriber subnet route advertisement
In event of failures, as MST re-converges and switches paths, the CFM session status changes and the L3 BNG sub-interfaces get notified of status via EFD such that the SRG role can be switched
MST and CFM timers can be as aggressive as supported by the access devices with stable operations even with full subscriber load
MC-LAG provides consistency of MAC and IP address across the two PoA (i.e. BNG routers). In this scenario there is no need for SRG vMAC since it is managed by MCLAG natively already.
The failure is induced by an object that directly tracks MC-LAG bundle interface status and signals to both SRG (for role determination) & the routing entity (to control the subnet/pool advertisement).
MC-LAG provides knobs to throttle switchovers and allow stabilization of subscribers on top of it in event of link flaps and after failure recovery
Parameters to consider when using MCLAG:
mlacp switchover recovery-delay – to ensure bundle remains slave after recovery from failure and allows subscribers to get sync and stabilized on it in slave mode
mlacp switchover type revertive – means that when the primary comes back, it will assume the primary role also and basically pull everything from the standby back. Like HSRP preempt.
lacp switchover suppress-flaps – to avoid switchover for transient link-flaps
BFD or CFM with EFD can be used for faster detection of failures in addition to LACP protocol mechanisms
Now that you know everything about GEORED you want to go set it up right?! Here is a config piece and explanation what it is for.
| Enable BNG GEo Redundancy |
group 1 peer 1.1.1.1 |
Set up SRG and define which group holds which interface. Multiple groups can be defined. |
subscriber redundancy group 1 interface-list interface bundle-ether1 id 1 |
Setup Access Object Tracking for SRG and Summary Subscriber route. In this example we are tracking the interface bundle state that MCLAG is providing to us. If we see that the state is going down, that will result in a static route withdraw from the table. If we have redistribute static configured, the pool summary will be removed so that the previous standby, now active can start advertising the summary to start pulling the traffic. |
track access-mclag type line-protocol state interface bundle-ether1 subscriber redundancy group 1 access-tracking access-mclag router static address-family ipv4 unicast 10.0.0.0/24 null0 track access-mclag desc sub-pool-summ |
| Optional SRG configuration to determine more deterministically what the preferred role is and what redundancy mode should be run. |
subscriber redundancy preferred-role master slave-mode warm hold-timer 15 |
A little more detail of the subscriber redundancy configlet
As with everything in technology, there is always some trade off. This table below is what exists currently as know restrictions for the GEORED solution as of XR 5.3.3
Note that XR6 has quite a significant amount of improvements, that will be documented separately. Since XR 5.3.3 is the going release today for ASR9000 I thought it is important to know what you get and where you need to think about.
Limitation |
Recommendation |
With just Core tracking, if core interface goes down, SRG switchover is triggered causing traffic black hole on access |
EEM script can be used to shut access when core goes down |
RA will send with both SRG vMAC as well as interface MAC towards access |
use RA preference CLI under dynamic template or access-interface |
Accounting records may get lost if we do back-to-back switchover before they sync on master and slave |
we should wait for 15 mins before doing Switchover (128k sessions) |
Admin clear of sessions from the slave is prohibited |
1. If slave is out of sync from master, subscriber redundancy synchronize command can be issued from slave to replay
2. SRG clear command can be issued either from slave or Master to get slave back to normal state |
Master reload is not recommended on the access with non-revertive protocol support |
Enable revertive configuration on the access-protocol |
On flight vmac modification for IPv6 sessions is not supported |
Features not supported:
With great thanks to the GEORED dev team for some of the visualizations used in this paper.
PS. it is highly important not to use pppoe bba-group Global. This is a reserved keyword that is known to break certain SRG cases. name your bba-group to anything but global/Global.
we can make this work! here is what the deal is with amb vlan and geo red/vmac.
when there is a switchover, obviously we want the adjacent switches to know that the mac has moved to another interface for them. today we dont send a grat arp. that is merely the issue.
so ...
- if you don't care about that
- if you can accept the mac aging time on the adj switches
- if you can workaround it with shutting the interface when the box goes down to cause a mac flush on the adj switches to force convergence
THEN this solution will just work seamlessly.
the stipulation for us in dev is:
- do we want to sedn a grat arp on ALL vlans that we are serving and how do we pace that
- more efficiently, learn the vlans that we have subs on and send a grat arp on those
this requires a lot of sync and learning or controlplane effort hence the difficulty, but if you can accept any of the 3 restrictions or one solution (flush) we can do this already!
cheers!
xander
Hi Xander,
thanks for your reply, but we need to manually (EEM) shut as you mentioned so it wont be seamless every time or practical/accurate.
can you elaborate more (current setup is using PPPOE sessions only).
our issue is related to scaling the box, if we use MSTAG, we could scale more since MC-LAG is in RP Mode not LC Mode.
thanks alot for your help.
if you have qiq with only session per combo, you will need to shut down the interface and force the flush on the adj switch.
indeed you can script with eem also to shutdown the interface to idnuce the mac flush or on the new primary to send a packet to let the switch know about the mac ownership change.
the vrrp/hsrp method of grat arp we are looking at, but as mentioned will cause some scale issues if we dont do this right. to do it right requires a lot of coding effort.
another alternative is to decrease the mac aging time on the adj switch.
xander
we have one session per combo, so basically we have only the shutdown option ?
sorry for the confusion.
Sami
with pppoe you may not have to if you can live with session restart/depend on pppoe keepalive.
for pppoe the sesion will naturally die and try to reestablish naturally to the other device.
that is stateless, if statefullness is needed, then you'll want to force the switchover faster by doing that eem shut and mac flush bfore the keep/hold expiry...
and/or wiat till we do that grat arp piece :)
xander
Thanks alot for making it clear ;)
i guess maybe Geo redundancy is more useful for IPOE since its keep alive is tricky or based on the IP lease as you explained in your other guides so Geo redundancy will help alot more over there.
Sami
Hello Xander, How can I tell if the sessions are being synced to the slave router? I'm not sure on the correct way to tell. If I do "show subscriber redundancy group" I see the correct peer address but the session summary counts for Master/Slave/Total are all zeros on both Master and Slave routers. There is a DHCP session on the Master router when I do "show subscriber session all." What is the correct way to tell if the sessions are being created on the slave? If they're not syncing what are the best ways to determine why not? Thanks, Matt
hi matt,
if you are using hot standby, that means that the sessions will be programmed in the hardware and you should be able to see them with show subscr ses all.
if you are using warm standby, that is the control plane holds them but they are not actually programmed in the hardware, then you can check the subscriber database via its commands like for instance:
show subscriber database session state all
this commandwill also help identify what the precise state or failure is.
show subscriber redundancy trace or summary also give some indication as to what is happening.
cheers
xander
Thanks for the reply. It's in hot-standby mode. When I run the subscriber database command on the slave it doesn't give any output besides the date and time. I opened a tac ticket so we'll see what they say when they go through the logs. I still can't get the slave to show any sessions even when it says it's master when I shut down the mc-lag on the master or do a manual session switchover. Matt
hmm I don't like that matt: even if it works, the operational status reporting needs to be better :)
let me chase the tac case but also please do let your TAC contact know to connect with me and satya/anil so we can do something about this to make it easier to evaluate, especially when there is no issue.
xander
OK I will do that. I agree it would be good to have an easier way to check the status on this. I still wouldn't be surprised if there is a problem with the config but according to the show commands it does look like it should be working. Thanks for your help with this! Matt
Hi Alex!! how are you..
Regarding all these you show here on this topic I d'like to know if a scenary N:1 role active/standby could be support when you have mpls rings in the access to the BNG like Telecom has for access protection, besides using pw-headend. I mean, a BNG standby for N BNG distributed in several mpls rings access with pw-headend.
I look forward to hearing from you soon my friend.
Sincerely,
Javier
hey javier! :)
how this could work is that you have a pre-agg node that sits between the BNG's and the mpls network. this pre-agg node takes the PW in, and with an xcon will spit out the pw contents on a bundle from this pre-agg node to 2 BNG's using mclag.
PWHE with GEORED is a 63 deliverable, so it is a bit out yet still (1st half next year about).
also pwhe puts some constraints on the scale, since all the feautres have to be programmed on all interfaces that are part of the pindown list (the list of intfs that the pw can come in on).
also loadbalancing between ecmp paths for the pwhe is a tricky scenario.
this can be circumvented by using the mclag option described popping the pw on a pre-agg node.
cheers!
xander
Hello All
Regarding Georedundacy feature in Asr9000 are there any limitations concerning it's operation with NV Satellites that we must take into account?
I am interested in the following scenario. We have many Switches / DSLAMs, each directly connected to an ASR9k through single GigE interfaces. We plan to add a second link for each of them to a new ASR9k and employ Georedundancy for the PPPoE sessions they carry. But for these interfaces we would like to be connected to the backup ASR9k through NV satellites (to increase the level of aggregation)
Will Georedundancy work in this scenario (provide PPPoE redundancy between two GigE/Bundle interfaces, first one being directly connected to ASR9K_1 and the second GigE / Bundle connected to the ASR9K_2 but this time through an NV Satellite unit)?
hi Vikas,
if you are using LC-based subscribers, the support for BNG Geo-R for LC based subscribers will come with XR release 6.2.1. If you are running RP-based subscribers, you can already make use of BNG Geo-R in your scenario. We strongly suggest all BNG deployments to be on XR release is 5.3.4.
I hope all the satellites that you are referring to are single homed. When using dual-homed satellites with additional redundancy at upper protocols the end behaviour is not always what you expect it to be.
Hope this helps,
Aleksandar
