rishetty
Introduction
Telemetry configuration & troubleshooting steps
Below is the list of telemetry sensors which can be used for system health monitoring. It includes ASR9K & NCS5500 platform
Configuration
Sample
telemetry model-driven
 destination-group telemetrycollection
  address-family ipv4 <SERVER IP> port <>
   encoding self-describing-gpb
   protocol tcp
 sensor-group SYSTEM
  sensor-path Cisco-IOS-XR-wdsysmon-fd-oper:system-monitoring
  sensor-path Cisco-IOS-XR-shellutil-oper:system-time/uptime
  sensor-path Cisco-IOS-XR-asr9k-fab-health-oper:fabric-health-stats
  sensor-path Cisco-IOS-XR-pfi-im-cmd-oper:interfaces/interface-briefs
  sensor-path Cisco-IOS-XR-pfi-im-cmd-oper:interfaces/interface-summary
  sensor-path Cisco-IOS-XR-wd-oper:watchdog/nodes/node/memory-state
  sensor-path Cisco-IOS-XR-wdsysmon-fd-oper:system-monitoring/cpu-utilization
  sensor-path Cisco-IOS-XR-asr9k-fsi-oper:fabric-stats/nodes/node/statses/stats
  sensor-path Cisco-IOS-XR-procmem-oper:processes-memory/nodes/node/process-ids/process-id
  sensor-path Cisco-IOS-XR-pfi-im-cmd-oper:interfaces/interface-xr/interface/interface-statistics
  sensor-path Cisco-IOS-XR-asr9k-np-oper:hardware-module-np/nodes/node/nps/np/load-utilization
  sensor-path Cisco-IOS-XR-sysadmin-asr9k-envmon-ui:environment/oper/power/location/pem_attributes
  sensor-path Cisco-IOS-XR-asr9k-xbar-oper:cross-bar-stats/nodes/node/cross-bar-table/sm15-stats/sm15-stat
  sensor-path Cisco-IOS-XR-infra-statsd-oper:infra-statistics/interfaces/interface/cache/protocols/protocol
subscription telemetrycollection_SYSTEM_5mins
  sensor-group-id SYSTEM_5mins sample-interval 300000
  destination-id telemetrycollection
Verification
Verify sensors
run mdt_exec -s "Cisco-IOS-XR-wd-oper:watchdog/nodes/node" -c <number of times to fetch data>
RP/0/RP1/CPU0:ASR9K_1#run mdt_exec -s "Cisco-IOS-XR-asr9k-np-oper:hardware-module-np/nodes/node" -h
usage: mdt_sub_show [options]
   -s  yang path to subscribe to
   -c  cadence
   -d  file to dump the output to
   -n  exit after n messages, use with -d option
   -h  help
show telemetry model-driven subscription
Subscription:  telemetrycollection_SYSTEM_5mins  State: ACTIVE >>> Check the state
  Sensor groups:
  Id                               Interval(ms)        State
  SYSTEM_5mins                     300000              Resolved
  Destination Groups:
  Id                 Encoding            Transport   State   Port    Vrf     IP
  telemetrycollection  self-describing-gpb tcp         Active  20191           10.41.17.45
    No TLS
RP/0/RP1/CPU0:ASR9K_1#sho telemetry model-driven subscription telemetrycollection_SYSTEM_5mins internal
Thu Nov 11 15:27:48.511 EST
  State:       ACTIVE
  Sensor groups:
    Sample Interval:      300000 ms
    Sensor Path:          Cisco-IOS-XR-wd-oper:watchdog/nodes/node
    Sensor Path State:    Resolved >>> Check if sensors are in RESOLVED state. If not, verify the configuration or sensor paths is valid or not
    Sensor Path:          Cisco-IOS-XR-wdsysmon-fd-oper:system-monitoring
    Sensor Path:          Cisco-IOS-XR-shellutil-oper:system-time/uptime
    Sensor Path:          Cisco-IOS-XR-wdsysmon-fd-oper:system-monitoring/cpu-utilization
    Sensor Path:          Cisco-IOS-XR-controller-optics-oper:optics-oper/optics-ports/optics-port/optics-info
    Sensor Path:          Cisco-IOS-XR-clns-isis-oper:isis/instances/instance/levels/level/adjacencies/adjacency
    Sensor Path:          Cisco-IOS-XR-alarmgr-server-oper:alarms/brief/brief-card/brief-locations/brief-location/active
  Destination Groups:
  Group Id: telemetrycollection
    Destination IP:       10.41.17.45
    Destination Port:     20191
    Encoding:             self-describing-gpb
    Transport:            tcp
    State:                Active
    No TLS
    Total bytes sent:     3286633286 >>> Send to external server in bytes
    Total packets sent:   45201 >>> Send to external server in packets
    Last Sent time:       2021-11-11 15:27:47.754358358 -0500
  Collection Groups:
    Num of collection:    117
    Collection time:      Min:    26 ms Max:    42 ms
    Total time:           Min:    26 ms Avg:    30 ms Max:    42 ms
    Total Deferred:       0
    Total Send Errors:    0 >>>>> Check if there is errors
    Total Send Drops:     0 >>>>> Check if there is drops
    Total Other Errors:   0
    No data Instances:    0
    Last Collection Start:2021-11-11 15:27:37.744457358 -0500
    Last Collection End:  2021-11-11 15:27:37.744490358 -0500
      Sysdb Path:     /oper/wd/node/*/overload_state
      Count:          118 Method: GET Min: 26 ms Avg: 30 ms Max: 42 ms
      Item Count:     1061 Status: Active
      Missed Collections:0  send bytes: 466176 packets: 118 dropped bytes: 0
                      success         errors          deferred/drops   >>>>> Check for any drops or errors
      Gets            1061            0
      List            118             0
      Datalist        0               0
      Finddata        118             0
      GetBulk         0               0
      Encode                          0               0
      Send                            0               0
  • Capturing TCP dump & Packet trace
  • debug tcp dumpfile port <> location <>
  • RP/0/RSP0/CPU0:AG2#show tcp dump-file list <10.41.17.45> location <0/RSP0/CPU0>       >>>>>  IP Mentioned is the destination IP and Location is of Active RSP default is active RSP
-rw-r—r--. 1 root root 4694 Feb 23 11:13 /tmp/tcpdump/10.41.17.45.48480.5432.cl.1645594986
  • Show tcp brief | I <Port Number>
  • Show tcp packet-capture <PCB NUMBER> location <>  >>>>> Active RSP is default Location
  • Missed collection behavior
we were observing missed collection in 663 which is expected or noise, since 663 is running with relative mode by default
Behaviour with 6.6.3 is as below for single sensor collection (Relative mode behaviour-default)
T0 collection start time 00:00 hrs
T1 collection end time 00:03 hrs
Ts sample interval 15 min
So next collection starts at 00:18 hrs T0+T1+Ts= 18 Min (+3 min increase from the normal interval). So in a day we should see some missed collection for each sensors
Behaviour with 7.3.2 is as below(Strict mode behaviour - default)
T0 collection start time is 00:00hrs
T1 collection end time is 00:03 hrs
So next collection start at 00:15 hrs Only Ts=15 Min
In XR version 7.0.1, as part of path concurrency and congestion management feature relative timer behavior was removed and the default was set to strict timer. That is the only mode now whether ‘strict timer’ is configured or not.
In 6.6.3, by default a relative timer will be used and in that case the missed collection stat is just noise.
Logs Collection
if any issue for further triage
  • show tech telemetry
  • show tech generic
  • show tech tcp nsr
ASR9K/NCS55xx Recommended CLI Telemetry Sensor paths Remarks
show redundancy Cisco-IOS-XR-shellutil-oper:system-time/uptime
show pfm location all Cisco-IOS-XR-pfm-oper:platform-fault-manager/racks/rack/slots/slot/hardware-fault-devices/hardware-fault-type/hardware-fault-info Enhancement in 732
show install active summary Cisco-IOS-XR-spirit-install-instmgr-oper:software-install/active  ALL
show version Cisco-IOS-XR-spirit-install-instmgr-oper:software-install/version  ALL
show platform Cisco-IOS-XR-plat-chas-invmgr-ng-oper:platform/racks/rack/slots/slot/state  ALL
show mem summary location all  Cisco-IOS-XR-nto-misc-shmem-oper:memory-summary/nodes/node/summary
show shmwin summary location <> Cisco-IOS-XR-nto-misc-shmem-oper:memory-summary/nodes/node/detail
show watchdog memory-state location all State of the Memory (Normal, severe, Critical) Working in 7.x.x release
Available memory in each LC/RP’s and state of the emory.
Cisco-IOS-XR-wd-oper:watchdog/nodes/node/memory-state/free-memory
show process memory sensor-path Cisco-IOS-XR-procmem-oper:processes-memory/nodes/node/process-ids/process-id
sensor-path Cisco-IOS-XR-nto-misc-shprocmem-oper:processes-memory/nodes/node/job-ids/job-id/job-id
"show controllers fabric fia errors ingress Cisco-IOS-XR-asr9k-fsi-oper:fabric-stats/nodes/node/statses/stats
show controllers fabric fia errors egress
show controllers fabric fia stats location <loc_name>
show controllers fabric fia drops
show controllers fabric fia bridge stats"
show controllers fabric crossbar statistics instance all location 0/<>/CPU0 Cisco-IOS-XR-asr9k-xbar-oper:cross-bar-stats/nodes/node/cross-bar-table/sm15-stats/sm15-stat ASR9k
show controller fabric health location <no> Cisco-IOS-XR-asr9k-fab-health-oper:fabric-health-stats ASR9k
show asic-errors all location <no> Cisco-IOS-XR-asic-error-oper:asic-errors/nodes/node/asic-information/all-instances/all-error-path/summary ASR9k
show env temperature sensor-path Cisco-IOS-XR-asr9k-sc-envmon-oper:environmental-monitoring/racks/rack/slots/slot/modules/module/sensor-types/sensor-type[type='temp']/sensor-names/sensor-name/value-detailed ASR9k
admin show env temperature Cisco-IOS-XR-sysadmin-asr9k-envmon-ui:environment/oper/temperatures
admin show env voltage Cisco-IOS-XR-sysadmin-asr9k-envmon-ui:environment/oper/voltage ASR9k
admin show env power Cisco-IOS-XR-sysadmin-asr9k-envmon-ui:environment/oper/power ASR9k
admin show env fan Cisco-IOS-XR-sysadmin-asr9k-envmon-ui:environment/oper/fan ASR9k
admin show env current Cisco-IOS-XR-sysadmin-asr9k-envmon-ui:environment/oper/current ASR9k
show controllers npu internaltcam loc < >, show controllers npu externaltcam location <> Cisco-IOS-XR-fia-internal-tcam-oper:controller/dpa/nodes/node/internal-tcam-resources NCS5508
sh controllers npu voq-usage interface all instance all location all Cisco-IOS-XR-fretta-bcm-dpa-npu-stats-oper:dpa/stats/nodes/node/npu-numbers/npu-number/display/interface-handles/interface-handle NCS5508
sh controllers npu  stats voq base <base-no> instance all location all
show controllers npu resources all location all Cisco-IOS-XR-platforms-ofa-oper:ofa/stats/nodes/node/Cisco-IOS-XR-NCS-BDplatforms-npu-resources-oper:hw-resources-datas/hw-resources-data NCS5508
Resources polled: Ext-tcam-ipv4, ext-tcam-ipv6, ext-tcam-ipv6-short, ext-tcam-ipv6-long, fec, ecmp-fec, lem, lpm, encap resource monitoring:
OOR Status Cisco-IOS-XR-platforms-ofa-table-stats-oper:ofa/stats/nodes/node/table-datas NCS5508
sh controllers npu resources fec location
show controllers npu stats traps-all instance all location all Cisco-IOS-XR-fretta-bcm-dpa-npu-stats-oper:dpa/stats/nodes/node/npu-numbers/npu-number/display/trap-ids/trap-id NCS5508
show filesystem Cisco-IOS-XR-shellutil-filesystem-oper:file-system/node ALL
show reboot history location Cisco-IOS-XR-linux-os-reboot-history-oper:reboot-history/node ALL
show route vrf all summary Cisco-IOS-XR-ip-rib-ipv4-oper:rib/rib-table-ids/rib-table-id/summary-protos/summary-proto ALL
show cef tables Cisco-IOS-XR-ip-rib-ipv6-oper:ipv6-rib/rib-table-ids/rib-table-id/summary-protos/summary-proto
  Cisco-IOS-XR-fib-common-oper:fib/nodes/node/protocols/protocol/cef-tables/cef-table/table-id
show alarms detail system {{active/history}} Cisco-IOS-XR-alarmgr-server-oper:alarms/brief/brief-card/brief-locations/brief-location/history ALL
show isis fast-reroute summary Cisco-IOS-XR-clns-isis-oper:isis/instances/instance/topologies/topology/frr-summary ALL
show cef drops Cisco-IOS-XR-fib-common-oper:fib-statistics/nodes/node/drops ALL
show mpls interfaces Cisco-IOS-XR-mpls-lsd-oper:mpls-lsd/interfaces/interface ALL
show mpls traffic-eng tunnels summary Cisco-IOS-XR-mpls-te-oper:mpls-te/tunnels/summary ALL
show rsvp interface Cisco-IOS-XR-ip-rsvp-oper:rsvp/interface-briefs/interface-brief ALL
show mpls traffic-eng counters signaling all Cisco-IOS-XR-mpls-te-oper:mpls-te/signalling-counters/signalling-summary ALL
show rsvp counters messages Cisco-IOS-XR-ip-rsvp-oper:rsvp/counters/interface-messages/interface-message ALL
show mpls ldp summary Cisco-IOS-XR-mpls-ldp-oper:mpls-ldp/nodes/node/bindings-summary-all ALL
show mpls ldp summary Cisco-IOS-XR-mpls-ldp-oper:mpls-ldp/global/active/default-vrf/summary ALL
  Cisco-IOS-XR-fib-common-oper:fib/nodes/node/protocols/protocol/resource ALL
show cef vrf all {{ipv4|ipv6|mpls|etc}} Cisco-IOS-XR-fib-common-oper:fib/nodes/node/protocols/protocol/vrfs/vrf/summary ALL
show controllers np load all Cisco-IOS-XR-asr9k-np-oper:hardware-module-np/nodes/node/nps/np/load-utilization ASR9k
show controllers np fast-drop all Cisco-IOS-XR-asr9k-np-oper:hardware-module-np/nodes/node/nps/np/fast-drop
show controllers np counters all Cisco-IOS-XR-asr9k-np-oper:hardware-module-np/nodes/node/nps/np/counters
show segment-routing traffic-eng forwarding policy Cisco-IOS-XR-infra-xtc-agent-oper:xtc/policy-forwardings/policy-forwarding ALL
show segment-routing traffic-eng policy Cisco-IOS-XR-infra-xtc-agent-oper:xtc/policies/policy ALL
show segment-routing traffic-eng ipv4 topology summary Cisco-IOS-XR-infra-xtc-agent-oper:xtc/topology-summaries/topology-summary ALL
show segment-routing traffic-eng policy summary Cisco-IOS-XR-infra-xtc-agent-oper:xtc/policy-summary ALL
show lpts pifib hardware police location <no> Cisco-IOS-XR-asr9k-lpts-oper:platform-lptsp-ifib/nodes/node/police/police-info ASR9k
Cisco-IOS-XR-asr9k-lpts-oper:platform-lptsp-ifib/nodes/node/stats
Cisco-IOS-XR-asr9k-lpts-oper:platform-lptsp-ifib-static/node-statics/node-static/stats
show memory summary Cisco-IOS-XR-nto-misc-oper:memory-summary/nodes/node/summary ALL
show reboot history location <no> Cisco-IOS-XR-linux-os-reboot-history-oper:reboot-history/node ALL
show processes cpu Cisco-IOS-XR-wdsysmon-fd-oper:system-monitoring ALL
uptime device Cisco-IOS-XR-shellutil-oper:system-time/uptime ALL
show controllers optics <> Cisco-IOS-XR-controller-optics-oper:optics-oper/optics-ports/optics-port/optics-info ALL
show processes cpu Cisco-IOS-XR-wdsysmon-fd-oper:system-monitoring/cpu-utilization ALL
sh interfaces <>  accounting  Cisco-IOS-XR-infra-statsd-oper:infra-statistics/interfaces/interface/cache/protocols/protocol ALL
show policy-map interface <name> ingress Cisco-IOS-XR-qos-ma-oper:qos/interface-table/interface/input/service-policy-names/service-policy-instance/statistics ALL
show policy-map interface <name> egress Cisco-IOS-XR-qos-ma-oper:qos/interface-table/interface/output/service-policy-names/service-policy-instance/statistics ALL
Power Cisco-IOS-XR-sysadmin-fretta-envmon-ui:environment/oper/power/ NCS55XX
admin show environment power
admin show environment power location <>
Fan Cisco-IOS-XR-sysadmin-fretta-envmon-ui:environment/oper/fan NCS55XX
admin show enviroment fan
Current Cisco-IOS-XR-sysadmin-fretta-envmon-ui:environment/oper/current NCS55XX
 admin show environment current location
Voltage Cisco-IOS-XR-sysadmin-fretta-envmon-ui:environment/oper/voltage NCS55XX
admin show environment voltages location
Temperature: Cisco-IOS-XR-sysadmin-fretta-envmon-ui:environment/oper/temperatures NCS55XX
 admin show environment temperature location
FPD status Cisco-IOS-XR-show-fpd-loc-ng-oper:show-fpd/locations/location NCS55XX
show fpd package
Memory available in different partitions: Cisco-IOS-XR-sysadmin-show-media:ShowMedia" ALL
CPU process Below sensor-path will provide CPU utilization for all the LC’s, RP’s and processes. ALL
show processes cpu thread
  Below sensor-path can be used for monitoring CPU utilization for a specific process. The example below is for bgp in the RP.
  Cisco-IOS-XR-wdsysmon-fd-proc-oper:process-monitoring/nodes/node[node-name=0/RP0/CPU0]/process-name/proc-cpu-utilizations/proc-cpu-utilization[process-name=bgp]
Redundancy Cisco-IOS-XR-infra-rmf-oper:redundancy ALL
show redunduncy
Sensor-paths for sysadmin controller commands: "Admin show controller switch statistics NCS55XX
 Cisco-IOS-XR-sysadmin-controllers-ncs5500:controller/switch/oper/statistics/detail
Admin show controller switch trunk
Cisco-IOS-XR-sysadmin-controllers-ncs5500:controller/switch/oper/trunk"
Sensor-path for SFE asic errors Command “Admin show asic-errors SFE all all” NCS55XX
Cisco-IOS-XR-sysadmin-asic-errors-ael:asic-errors/show-all-instances
ASIC errors Cisco-IOS-XR-fretta-bcm-dpa-npu-stats-oper:dpa/stats/nodes/node/asic-statististics NCS55XX
  Cisco-IOS-XR-fretta-bcm-dpa-npu-stats-oper:dpa/stats/nodes/node/asic-statistics/asic-statistics-for-npu-ids/asic-statistics-for-npu-id
Fabric errors/counters: Cisco-IOS-XR-dnx-driver-fabric-plane-oper:fabric NCS55XX
Interface counters Interface counters for every interface in the router. ALL
Show interface <> Cisco-IOS-XR-infra-statsd-oper:infra-statistics/interfaces/interface/cache/generic-counters
Interface data rate (PPS/bps): Cisco-IOS-XR-infra-statsd-oper:infra-statistics/interfaces/interface/latest/data-rate ALL
Cisco-IOS-XR-infra-statsd-oper:infra-statistics/interfaces/interface/cache/data-rate >>> Use this sensor in different sensor group from generic counters
Cisco-IOS-XR-infra-statsd-oper:infra-statistics/interfaces/interface[interface-name=Bun*]/cache/data-rate >> Ex. This will fetch for bundle interface
show interface brief Cisco-IOS-XR-pfi-im-cmd-oper:interfaces/interface-briefs
