on 06-21-2023 03:55 PM
Introduction
BFD between ASR9K-XR (Bundle-Ether) and ASR903 - XE (Port-channel)
Problem
BFD over Port channel of ASR903 down
Solution
bfd-template single-hop AG1-ASR9K
interval microseconds min-tx 25000 min-rx 25000 multiplier 3 >> 25ms *3 timer
AG1-2-903#sh run int po10
Building configuration...
Current configuration : 528 bytes
interface Port-channel10
dampening
mtu 9202
ip address 172.27.98.220 255.255.255.254
no ip redirects
no ip unreachables
no ip proxy-arp
ip router isis CORE
ip pim sparse-mode
load-interval 30
carrier-delay up 2
carrier-delay down msec 0
ipv6 address 2405:200:13A:0:172:27:98:220/127
no ipv6 redirects
no ipv6 unreachables
ipv6 router isis CORE
mpls ip
mpls ldp igp sync delay 25
bfd template AG1-ASR9K
isis circuit-type level-1
isis network point-to-point
isis bfd
end
AG1-2-903#sh bfd neighbors interface po10 details
IPv4 Sessions
NeighAddr LD/RD RH/RS State Int
172.27.98.221 7/131077 Down Init Po10 >>>> DOWN & INIT state , ASR903 is receiving the poackets so it is in INIT state
Session Host: Hardware - session negotiated with platform adjusted timer values.
MinTxInt - configured: 25000 adjusted: 1000000
OurAddr: 172.27.98.220
Handle: 3
Local Diag: 0, Demand mode: 0, Poll bit: 0
MinTxInt: 1000000, MinRxInt: 1000000, Multiplier: 3
Received MinRxInt: 2000000, Received Multiplier: 3
Holddown (hits): 0(0), Hello (hits): 2000(0)
Rx Count: 54
Tx Count: 48
Elapsed time watermarks: 0 0 (last: 0)
Registered protocols: ISIS CEF
Template: AG1-ASR9K
Last packet: Version: 1 - Diagnostic: 3
State bit: Down - Demand bit: 0
Poll bit: 0 - Final bit: 0
C bit: 1
Multiplier: 3 - Length: 24
My Discr.: 131077 - Your Discr.: 0 >>> My Discr is matching with peer ASR9K
Min tx interval: 2000000 - Min rx interval: 2000000
Min Echo interval: 0
ASR9K
Able to ping peer IP of ASR903
RP/0/RP0/CPU0:ASR9K_1#ping 172.27.98.220
Mon Oct 25 02:50:55.096 EDT
Sending 5, 100-byte ICMP Echos to 172.27.98.220, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/3/6 ms
RP/0/RP0/CPU0:ASR9K_1#sh bfd session interface be1601 detail
Mon Oct 25 02:51:04.918 EDT
I/f: Bundle-Ether1601, Location: 0/7/CPU0
Dest: 172.27.98.220
Src: 172.27.98.221
State: DOWN for 0d:0h:8m:58s, number of times UP: 0
Session type: SW/V4/SH/BL
Received parameters:
Version: 0, desired tx interval: 0 ms, required rx interval: 0 ms
Required echo rx interval: 0 ms, multiplier: 0, diag: None
My discr: 0, your discr: 0, H/D/F/P/C/A: 0/0/0/0/0/0
Transmitted parameters:
Version: 1, desired tx interval: 2 s, required rx interval: 2 s
Required echo rx interval: 0 ms, multiplier: 3, diag: None
My discr: 131077, your discr: 0, state DOWN, D/F/P/C/A: 0/0/0/1/0 >>>> Matching with ASR903
Timer Values:
Local negotiated async tx interval: 2 s
Remote negotiated async tx interval: 2 s
Desired echo tx interval: 0 s, local negotiated echo tx interval: 0 ms
Echo detection time: 0 ms, async detection time: 0 ms
Label:
Internal label: 506618/0x7bafa
Local Stats:
Intervals between async packets:
Tx: Number of intervals=100, min=1673 ms, max=1994 ms, avg=1827 ms >>>> Packets is getting transmitted
Last packet transmitted 1350 ms ago
Rx: Number of intervals=0, min=0 s, max=0 s, avg=0 s. >>>> No Receive
Last packet received 0 s ago
Intervals between echo packets:
Tx: Number of intervals=0, min=0 s, max=0 s, avg=0 s
Last packet transmitted 0 s ago
Latency of echo packets (time between tx and rx):
Number of packets: 0, min=0 ms, max=0 ms, avg=0 ms
MP download state: BFD_MP_DOWNLOAD_ACK
State change time: Oct 25 02:50:53.628
Session owner information:
Desired Adjusted
Client Interval Multiplier Interval Multiplier
isis-CORE 50 ms 3 2 s 3
AG1-2-903#sh ip route 10.12.0.3
Routing entry for 10.12.0.3/32
Known via "isis", distance 115, metric 30
Tag 5000, type level-1
Redistributing via isis CORE
Last update from 172.29.5.1 on TenGigabitEthernet0/3/2, 00:07:39 ago
Routing Descriptor Blocks:
* 172.29.5.1, from 10.12.0.3, 00:07:39 ago, via TenGigabitEthernet0/3/2
Route metric is 30, traffic share count is 1
Route tag 5000
Repair Path: 10.12.0.5, via MPLS-Remote-Lfa1
BFD is Down but ISIS is UP but as per RIB table above it is not using Bundle Path (So removed from RIB)
RP/0/RP0/CPU0:ASR9K_1#sh isis neighbors
Mon Oct 25 02:51:24.540 EDT
IS-IS CORE neighbors:
System Id Interface SNPA State Holdtime Type IETF-NSF
IXIA-4 BE357 *PtoP* Up 23 L1 Unable
AG1-2-903 BE1601 *PtoP* Up 28 L1 Capable
AG1-2-903#sh isis neighbors
Tag CORE:
System Id Type Interface IP Address State Holdtime Circuit Id
EAG5 L1 Te0/3/7 172.29.4.0 UP 27 00
EAG5 L1 Te0/4/5 172.29.4.2 UP 25 00
ASR9K_1 L1 Po10 172.27.98.221 UP 26 00
ASR9K-2 L1 Te0/3/2 172.29.5.1 UP 26 00
Tag RAN:
RP/0/RP0/CPU0:ASR9K_1#sh run router isis CORE inte be1601
Mon Oct 25 02:50:17.523 EDT
router isis CORE
interface Bundle-Ether1601
bfd minimum-interval 50
bfd multiplier 3
bfd fast-detect ipv4
point-to-point
address-family ipv4 unicast
fast-reroute per-prefix
fast-reroute per-prefix remote-lfa tunnel mpls-ldp
metric 20 level 1
mpls ldp sync
address-family ipv6 unicast
metric 3000 level
As per document , below is recommended from ASR903 RSP3C BFD over Port-Channel
BFD over port-channel (PoCH) is supported on the RSP3 module in software offload mode only. The minimum timer value supported is 200 milliseconds.
AG1-2-903#sh run | in platform bfd-offload
platform bfd-offload-timer 200000 >> minimum 200ms is supported on Portchannel
AG1-2-903#sh run | b bfd-template
bfd-template single-hop 200ms
interval min-tx 200 min-rx 200 multiplier 3 >>>> 200ms * 3 timer
AG1-2-903#conf t
Enter configuration commands, one per line. End with CNTL/Z.
AG1-2-903(config)#int po10
AG1-2-903(config-if)#no bfd template AG1-ASR9K
AG1-2-903(config-if)#bfd template 200ms
Mon Oct 25 03:01:29.377 EDT
Dest: 172.27.98.220
Src: 172.27.98.221
State: UP for 0d:0h:0m:13s, number of times UP: 1
Version: 1, desired tx interval: 200 ms, required rx interval: 200 ms >>>
My discr: 1026, your discr: 131077, state UP, D/F/P/C/A: 0/0/0/0/0
Version: 1, desired tx interval: 50 ms, required rx interval: 50 ms
My discr: 131077, your discr: 1026, state UP, D/F/P/C/A: 0/0/0/1/0
Timer Values:
Local negotiated async tx interval: 200 ms
Remote negotiated async tx interval: 200 ms
Echo detection time: 0 ms(0 ms*3), async detection time: 600 ms(200 ms*3)
Label:
Local Stats:
Tx: Number of intervals=100, min=1 ms, max=1994 ms, avg=632 ms >>> TX working
Last packet transmitted 85 ms ago
Rx: Number of intervals=78, min=1 ms, max=201 ms, avg=167 ms >>> RX working
Last packet received 106 ms ago
Desired Adjusted
isis-CORE 50 ms 3 50 ms 3
Below status with 200ms BFD on ASR903
Tag CORE:
AG2-2 L1 Te0/3/2 172.29.5.1 UP 26 00
Known via "isis", distance 115, metric 10
Last update from 172.27.98.221 on Port-channel10, 00:00:34 ago
* 172.27.98.221, from 10.12.0.3, 00:00:34 ago, via Port-channel10 >>> So now PO10 is UP
Route metric is 10, traffic share count is 1
Route tag 5000
Repair Path: 172.29.5.1, via TenGigabitEthernet0/3/2
