Meddane
The interfaces of P and PE routers are enabled for frame mode MPLS with the mpls ip interface subcommand and all P and PE routers use a common IGP (EIGRP with AS 200):
P#show mpls ldp neighbor
    Peer LDP Ident: 1.1.1.1:0; Local LDP Ident 3.3.3.3:0
        TCP connection: 1.1.1.1.646 - 3.3.3.3.33628
        State: Oper; Msgs sent/rcvd: 10/11; Downstream
        Up time: 00:01:54
        LDP discovery sources:
          Serial1/0, Src IP addr: 192.168.1.1
        Addresses bound to peer LDP Ident:
          10.1.1.1        192.168.1.1     1.1.1.1
    Peer LDP Ident: 2.2.2.2:0; Local LDP Ident 3.3.3.3:0
        TCP connection: 2.2.2.2.646 - 3.3.3.3.17194
        State: Oper; Msgs sent/rcvd: 9/10; Downstream
        Up time: 00:01:19
          Serial1/1, Src IP addr: 192.168.2.1
          10.2.2.1        192.168.2.1     2.2.2.2
P#
PE1#show mpls ldp neighbor
    Peer LDP Ident: 3.3.3.3:0; Local LDP Ident 1.1.1.1:0
        TCP connection: 3.3.3.3.33628 - 1.1.1.1.646
        State: Oper; Msgs sent/rcvd: 10/9; Downstream
        Up time: 00:01:43
          Serial1/0, Src IP addr: 192.168.1.2
          192.168.1.2     192.168.2.2     3.3.3.3
PE1#
PE2#show mpls ldp neighbor
    Peer LDP Ident: 3.3.3.3:0; Local LDP Ident 2.2.2.2:0
        TCP connection: 3.3.3.3.17194 - 2.2.2.2.646
        Up time: 00:01:13
          Serial1/0, Src IP addr: 192.168.2.2
PE2#
PE1#show mpls forwarding-table
Local      Outgoing   Prefix           Bytes Label   Outgoing   Next Hop
Label      Label      or Tunnel Id     Switched      interface
16         Pop Label  3.3.3.0/24       0             Se1/0      point2point
17         Pop Label  192.168.2.0/24   0             Se1/0      point2point
18         17         2.2.2.0/24       0             Se1/0      point2point
PE1#
PE2#show mpls forwarding-table
17         Pop Label  192.168.1.0/24   0             Se1/0      point2point
18         16         1.1.1.0/24       0             Se1/0      point2point
PE2#
Configuration of VRF:
Create each VRF, RD, and RT, plus associating the customer-facing PE interfaces with the correct VRF:
VRF CUST-A, RD 1:111, RT 1:100
VRF CUST-B, RD 2:222, RT 2:200
PE1
ip vrf CUST-A
 rd 1:111
 route-target export 1:100
 route-target import 1:100
ip vrf CUST-B
 rd 2:222
 route-target export 2:200
 route-target import 2:200
interface FastEthernet0/0
 ip vrf forwarding CUST-A
 ip address 10.1.1.1 255.255.255.0
interface FastEthernet0/1
 ip vrf forwarding CUST-B
 ip address 10.3.3.1 255.255.255.0
PE2
ip vrf CUST-A
 rd 1:111
ip vrf CUST-B
 rd 2:222
 ip address 10.2.2.1 255.255.255.0
 ip address 10.4.4.1 255.255.255.0
Configuring the IGP Between PE and CE routers
I am using OSPFv3 address families between CEs and PEs routers:
CE-A1:
interface Loopback0
 ospfv3 1 ipv4 area 0
 ipv6 enable
router ospfv3 1
 address-family ipv4 unicast
 exit-address-family
CE-A2:
interface Loopback0
 ipv6 enable
router ospfv3 1
 exit-address-family
PE1:
 ipv6 enable
 ipv6 enable
router ospfv3 1
 address-family ipv4 unicast vrf CUST-B
 exit-address-family
 address-family ipv4 unicast vrf CUST-A
 exit-address-family
PE2:
 ipv6 enable
 ipv6 enable
router ospfv3 1
 exit-address-family
 exit-address-family
Verify the OSPFv3 neighbors for each VRF on the PE routers:
PE1#show ospfv3 vrf CUST-A neighbor
          OSPFv3 1 address-family ipv4 vrf CUST-A (router-id 10.1.1.1)
Neighbor ID     Pri   State           Dead Time   Interface ID    Interface
172.16.1.1        1   FULL/DR         00:00:30    2               FastEthernet0/0
PE1#
PE1#show ospfv3 vrf CUST-B neighbor
          OSPFv3 1 address-family ipv4 vrf CUST-B (router-id 10.3.3.1)
172.16.1.1        1   FULL/DR         00:00:36    2               FastEthernet0/1
PE1#
PE2#show ospfv3 vrf CUST-A neighbor
          OSPFv3 1 address-family ipv4 vrf CUST-A (router-id 10.2.2.1)
172.16.2.1        1   FULL/DR         00:00:35    2               FastEthernet0/0
PE2#
PE2#show ospfv3 vrf CUST-B neighbor
          OSPFv3 1 address-family ipv4 vrf CUST-B (router-id 10.4.4.1)
172.16.2.1        1   FULL/DR         00:00:39    2               FastEthernet0/1
PE2#
The PE routers create two separate LSDB for each VRF customers as shown by the following output on PE1 router:
PE1#show ospfv3 vrf CUST-A database
                Router Link States (Area 0)
ADV Router       Age         Seq#        Fragment ID  Link count  Bits
 10.1.1.1        603         0x80000002  0            1           B
 172.16.1.1      609         0x80000002  0            1           None
                Net Link States (Area 0)
ADV Router       Age         Seq#        Link ID    Rtr count
 172.16.1.1      608         0x80000001  2          2
                Link (Type-8) Link States (Area 0)
ADV Router       Age         Seq#        Link ID    Interface
 10.1.1.1        608         0x80000001  2          Fa0/0
 172.16.1.1      990         0x80000001  2          Fa0/0
                Intra Area Prefix Link States (Area 0)
ADV Router       Age         Seq#        Link ID    Ref-lstype  Ref-LSID
 172.16.1.1      608         0x80000003  0          0x2001      0
 172.16.1.1      608         0x80000001  2048       0x2002      2
PE1#
The show ospfv3 vrf CUST-A command shown that the MPLS VPN backbone acts as a Super Backbone, therefore the PE routers act as an ABR, notice the lines "Connected to
MPLS VPN Superbackbone" and "It is an area border router".
 Router ID 10.1.1.1
 Supports NSSA (compatible with RFC 3101)
 Domain ID (none)
 Connected to MPLS VPN Superbackbone
 Event-log enabled, Maximum number of events: 1000, Mode: cyclic
 Router is not originating router-LSAs with maximum metric
 Initial SPF schedule delay 5000 msecs
 Minimum hold time between two consecutive SPFs 10000 msecs
 Maximum wait time between two consecutive SPFs 10000 msecs
 Minimum LSA interval 5 secs
 Minimum LSA arrival 1000 msecs
 LSA group pacing timer 240 secs
 Interface flood pacing timer 33 msecs
 Retransmission pacing timer 66 msecs
 Retransmission limit dc 24 non-dc 24
 Number of external LSA 0. Checksum Sum 0x000000
 Number of areas in this router is 1. 1 normal 0 stub 0 nssa
 Graceful restart helper support enabled
 Reference bandwidth unit is 100 mbps
 RFC1583 compatibility enabled
    Area BACKBONE(0)
        Number of interfaces in this area is 1
        SPF algorithm executed 2 times
        Number of LSA 7. Checksum Sum 0x0340D2
        Number of DCbitless LSA 0
        Number of indication LSA 0
        Number of DoNotAge LSA 0
        Flood list length 0
PE1#
The LSA Type 1 generated by PE1 router confirms that the B-bit has been set to 1 to tell to the CE routers that it is an ABR, notice the line "Area Border Router".
PE1#show ospfv3 vrf CUST-A database router self-originate
  LS age: 908
  Options: (E-Bit, R-bit, DC-Bit, AF-Bit)
  LS Type: Router Links
  Link State ID: 0
  Advertising Router: 10.1.1.1
  LS Seq Number: 80000002
  Checksum: 0x35F7
  Length: 40
  Area Border Router
  Number of Links: 1
    Link connected to: a Transit Network
      Link Metric: 1
      Local Interface ID: 2
      Neighbor (DR) Interface ID: 2
      Neighbor (DR) Router ID: 172.16.1.1
PE1#
Verify the IP routes for each VRF:
PE1#show ip route vrf CUST-A ospfv3
Routing Table: CUST-A
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is not set
      172.16.0.0/32 is subnetted, 1 subnets
O        172.16.1.1 [110/1] via 10.1.1.2, 00:19:40, FastEthernet0/0
PE1#
PE1#show ip route vrf CUST-B ospfv3
Routing Table: CUST-B
O        172.16.1.1 [110/1] via 10.3.3.2, 00:19:52, FastEthernet0/1
PE1#
PE2#show ip route vrf CUST-A ospfv3
O        172.16.2.1 [110/1] via 10.2.2.2, 00:20:02, FastEthernet0/0
PE2#
PE2#show ip route vrf CUST-B ospfv3
O        172.16.2.1 [110/1] via 10.4.4.2, 00:20:36, FastEthernet0/1
PE2#
Redistribution Between PE-CE routers (between OSPFv3 and MP-BGP):
PE1(config)#router bgp 65000
PE1(config-router)#address-family ipv4 vrf CUST-A
PE1(config-router-af)#redistribute ospfv3 1
PE1(config-router-af)#address-family ipv4 vrf CUST-B
PE1(config-router-af)#router ospfv3 1
PE1(config-router-af)#redistribute bgp 65000
PE2(config)#router bgp 65000
PE2(config-router)#address-family ipv4 vrf CUST-A
PE2(config-router-af)#redistribute ospfv3 1
PE2(config-router-af)#address-family ipv4 vrf CUST-B
PE2(config-router-af)#router ospfv3 1
PE2(config-router-af)#redistribute bgp 65000
Configuration MP-BGP Between PEs routers:
PE1(config-router)#neighbor 2.2.2.2 remote-as 65000
PE1(config-router)#neighbor 2.2.2.2 update-source loop0
PE1(config-router)#address-family vpnv4
PE1(config-router-af)#neighbor 2.2.2.2 activate
PE1(config-router-af)#neighbor 2.2.2.2 send-community
PE2(config-router)#neighbor 1.1.1.1 remote-as 65000
PE2(config-router)#neighbor 1.1.1.1 update-source loop0
PE2(config-router)#address-family vpnv4
PE2(config-router-af)#neighbor 1.1.1.1 activate
PE2(config-router-af)#neighbor 1.1.1.1 send-community
Verify the BGP neighbor:
PE1#show ip bgp summary
BGP router identifier 1.1.1.1, local AS number 65000
BGP table version is 1, main routing table version 1
Neighbor        V           AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
2.2.2.2         4        65000      17       9        1    0    0 00:00:46        0
PE1#
PE2#show ip bgp summary
BGP router identifier 2.2.2.2, local AS number 65000
1.1.1.1         4        65000      10      17        1    0    0 00:01:20        0
PE2#
Verify the per-RD BGP table. And we can see the overlapping subnets 172.16.1.1/32 and 172.16.2.1/32 are a part of the two customers’ address spaces:
PE1#show ip bgp vpnv4 all
BGP table version is 13, local router ID is 1.1.1.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
              x best-external, a additional-path, c RIB-compressed,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
     Network          Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 1:111 (default for vrf CUST-A)
 *>  10.1.1.0/24      0.0.0.0                  0         32768 ?
 *>i 10.2.2.0/24      2.2.2.2                  0    100      0 ?
 *>  172.16.1.1/32    10.1.1.2                 1         32768 ?
 *>i 172.16.2.1/32    2.2.2.2                  1    100      0 ?
Route Distinguisher: 2:222 (default for vrf CUST-B)
 *>  10.3.3.0/24      0.0.0.0                  0         32768 ?
 *>i 10.4.4.0/24      2.2.2.2                  0    100      0 ?
 *>  172.16.1.1/32    10.3.3.2                 1         32768 ?
PE1#
PE2#show ip bgp vpnv4 all
BGP table version is 13, local router ID is 2.2.2.2
 *>i 10.1.1.0/24      1.1.1.1                  0    100      0 ?
 *>  10.2.2.0/24      0.0.0.0                  0         32768 ?
 *>i 172.16.1.1/32    1.1.1.1                  1    100      0 ?
 *>  172.16.2.1/32    10.2.2.2                 1         32768 ?
 *>i 10.3.3.0/24      1.1.1.1                  0    100      0 ?
 *>  10.4.4.0/24      0.0.0.0                  0         32768 ?
 *>  172.16.2.1/32    10.4.4.2                 1         32768 ?
PE2#
Verify the the per-VRF routing tables of PEs routers, they receive both the BGP routes toward 172.16.1.1/32 and 172.16.2.1/32 for each VRF:
PE1#show ip route vrf CUST-A | beg Gate
      10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
C        10.1.1.0/24 is directly connected, FastEthernet0/0
L        10.1.1.1/32 is directly connected, FastEthernet0/0
B        10.2.2.0/24 [200/0] via 2.2.2.2, 00:05:21
      172.16.0.0/32 is subnetted, 2 subnets
O        172.16.1.1 [110/1] via 10.1.1.2, 00:09:55, FastEthernet0/0
B        172.16.2.1 [200/1] via 2.2.2.2, 00:05:21
PE1#
PE1#show ip route vrf CUST-B | beg Gate
C        10.3.3.0/24 is directly connected, FastEthernet0/1
L        10.3.3.1/32 is directly connected, FastEthernet0/1
B        10.4.4.0/24 [200/0] via 2.2.2.2, 00:06:24
O        172.16.1.1 [110/1] via 10.3.3.2, 00:10:50, FastEthernet0/1
B        172.16.2.1 [200/1] via 2.2.2.2, 00:06:24
PE1#
PE2#show ip route vrf CUST-A | beg Gate
B        10.1.1.0/24 [200/0] via 1.1.1.1, 00:07:41
C        10.2.2.0/24 is directly connected, FastEthernet0/0
L        10.2.2.1/32 is directly connected, FastEthernet0/0
B        172.16.1.1 [200/1] via 1.1.1.1, 00:07:41
O        172.16.2.1 [110/1] via 10.2.2.2, 00:10:45, FastEthernet0/0
PE2#
PE2#show ip route vrf CUST-B | beg Gate
B        10.3.3.0/24 [200/0] via 1.1.1.1, 00:07:46
C        10.4.4.0/24 is directly connected, FastEthernet0/1
L        10.4.4.1/32 is directly connected, FastEthernet0/1
B        172.16.1.1 [200/1] via 1.1.1.1, 00:07:46
O        172.16.2.1 [110/1] via 10.4.4.2, 00:10:46, FastEthernet0/1
PE2#
Verify that the customer routers have learned the routes from each customer router in the same VRF:
By definition when the PE router redistributes the VPNv4 routes to the OSPF domain, it checks the Domain ID to decide whether the routes should be redistributed as inter-area (same Domain ID) or external (different Domain ID) routes to the CE router.
Each OSPF instance must be assigned a unique Domain ID. On Cisco routers, the OSPF Domain ID is the OSPF Process ID by default. When BGP distributes VPNv4 routes to other PE routers, the Domain ID is carried with the routes as extended community.
Since the Domain IDs on both PE routers match , PE routers redistributes the subnets 172.16.1.1/32 and 172.16.2.1/32 to CE routers as inter-area routes (LSA Type 3) as shown by the routing tables of the CE routers:
CE-A1# show ip route OSPFv3 | beg Gate
O IA     10.2.2.0/24 [110/2] via 10.1.1.1, 00:09:48, FastEthernet0/0
      172.16.0.0/16 is variably subnetted, 3 subnets, 2 masks
O IA     172.16.2.1/32 [110/2] via 10.1.1.1, 00:09:48, FastEthernet0/0
CE-A1#
CE-A2#show ip route OSPFv3 | beg Gate
O IA     10.1.1.0/24 [110/2] via 10.2.2.1, 00:10:53, FastEthernet0/0
O IA     172.16.1.1/32 [110/2] via 10.2.2.1, 00:10:53, FastEthernet0/0
CE-A2#
CE-B1#show ip route OSPFv3 | beg Gate
O IA     10.4.4.0/24 [110/2] via 10.3.3.1, 00:11:53, FastEthernet0/0
O IA     172.16.2.1/32 [110/2] via 10.3.3.1, 00:11:53, FastEthernet0/0
CE-B1#
CE-B2#show ip route OSPFv3 | beg Gate
O IA     10.3.3.0/24 [110/2] via 10.4.4.1, 00:12:54, FastEthernet0/0
O IA     172.16.1.1/32 [110/2] via 10.4.4.1, 00:12:54, FastEthernet0/0
CE-B2#
Verify the connectivity between the customers:
CE-A1#ping 172.16.2.1 sou 172.16.1.1
Sending 5, 100-byte ICMP Echos to 172.16.2.1, timeout is 2 seconds:
Packet sent with a source address of 172.16.1.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 156/188/224 ms
CE-A1#
CE-B1#ping 172.16.2.1 sou 172.16.1.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 184/284/356 ms
CE-B1#
The above following output shown that PE2 router is advertising the 172.16.2.1/32 prefixes for each VRF to PE1 using BGP. PE2 has included all OSPF related BGP
Extended communities. The route-type is set as LSA Type-2 (intra-area) route as shown by the line: OSPF RT:0.0.0.0:2:0. The Router ID is the router-id of PE2 router set for that VRF instance (ROUTER ID:10.2.2.1:0 for VRF CUST-A and ROUTER ID:10.4.4.1:0 for VRF CUST-B).
PE1#show ip bgp vpnv4 all 172.16.2.1
BGP routing table entry for 1:111:172.16.2.1/32, version 11
Paths: (1 available, best #1, table CUST-A)
  Not advertised to any peer
  Refresh Epoch 1
  Local
    2.2.2.2 (metric 2809856) from 2.2.2.2 (2.2.2.2)
      Origin incomplete, metric 1, localpref 100, valid, internal, best
      Extended Community: RT:1:100 OSPF ROUTER ID:10.2.2.1:0
        OSPF RT:0.0.0.0:2:0
      mpls labels in/out nolabel/21
      rx pathid: 0, tx pathid: 0x0
BGP routing table entry for 2:222:172.16.2.1/32, version 13
Paths: (1 available, best #1, table CUST-B)
  Refresh Epoch 1
  Local
      Extended Community: RT:2:200 OSPF ROUTER ID:10.4.4.1:0
        OSPF RT:0.0.0.0:2:0
      mpls labels in/out nolabel/20
PE1#
Since the Domain IDs on both PE routers match, the CE routers receives the prefixes 172.16.1.1/32 and 172.16.2.1/32 as inter-area routes as shown by the routing table
of the CE-A1 router for the prefix 172.16.2.1/32:
CE-A1#show ip route 172.16.2.1
Routing entry for 172.16.2.1/32
  Known via "ospfv3 1", distance 110, metric 2, type inter area
  Last update from 10.1.1.1 on FastEthernet0/0, 00:23:04 ago
  Routing Descriptor Blocks:
  * 10.1.1.1, from 10.1.1.1, 00:23:04 ago, via FastEthernet0/0
      Route metric is 2, traffic share count is 1
CE-A1#
Verify that PE1 router created the Summary LSA Type 3 for the prefix 172.16.2.1/32 with the show ospfv3 vrf CUST-A database inter-area prefix command:
PE1#show ospfv3 vrf CUST-A database inter-area prefix
                Inter Area Prefix Link States (Area 0)
  LS age: 1519
  LS Type: Inter Area Prefix Links
  Link State ID: 0
  LS Seq Number: 80000001
  Checksum: 0x10E6
  Length: 32
  Metric: 1
  Prefix Address: 10.2.2.0
  Prefix Length: 24, Options: DN
  LS age: 1519
  Link State ID: 1
  Checksum: 0xF14A
  Length: 32
  Metric: 1
  Prefix Address: 172.16.2.1
  Prefix Length: 32, Options: DN
PE1#
Verify the LSDB of the PE1 router for the VRF CUST-A:
 10.1.1.1        1903        0x80000004  0            1           B E
 172.16.1.1      172         0x80000004  0            1           None
 172.16.1.1      172         0x80000003  2          2
ADV Router       Age         Seq#        Prefix
 10.1.1.1        1624        0x80000001  10.2.2.0/24
 10.1.1.1        1624        0x80000001  172.16.2.1/32
 10.1.1.1        1989        0x80000002  2          Fa0/0
 172.16.1.1      430         0x80000003  2          Fa0/0
 172.16.1.1      172         0x80000005  0          0x2001      0
 172.16.1.1      172         0x80000003  2048       0x2002      2
PE1#
PE1#show ip bgp vpnv4 vrf CUST-A 172.16.2.1
  Refresh Epoch 1
  Local
        OSPF RT:0.0.0.0:2:0
PE1#
Configure the Domain ID manually with the value 000000000310 for the VRF CUST-A on PE2 router:
PE2(config-router)#router ospfv3 1
PE2(config-router-af)#domain-id type 0005 value 000000000310
PE2 router advertises the 172.16.2.1/32 prefix for the VRF CUST-A with Domain ID 000000000309. PE1 matches that with its own Domain ID (which is by default is equal to 1 the process ID of OSPF) before redistributing the prefix to CE-A1 router. Since the Domain IDs dont match, PE1 advertises the prefix as an External Type-2 prefix to CE-A1 router as shown by the following output below and notice the prefix 172.16.2.1/32 for the VRF CUST-B is advertised with the default domain ID by PE2 router.
PE1#show ip bgp vpnv4 all 172.16.2.1/32
BGP routing table entry for 1:111:172.16.2.1/32, version 15
  Refresh Epoch 1
  Local
      Extended Community: RT:1:100 OSPF DOMAIN ID:0x0005:0x000000000310
        OSPF ROUTER ID:10.2.2.1:0 OSPF RT:0.0.0.0:2:0
  Refresh Epoch 1
  Local
        OSPF RT:0.0.0.0:2:0
PE1#
We can display only the entry for the 172.16.2.1/32 prefix in VRF CUST-A using the show ip bgp vpnv4 vrf CUST-A 172.16.2.1 command:
  Refresh Epoch 1
  Local
PE1#
And we can verify that CE-A1 router received an external route for the prefix 172.16.2.1/32 as shown by its routing table:
CE-A1#show ip route ospfv3 | beg Gate
O E2     10.2.2.0/24 [110/1] via 10.1.1.1, 00:00:31, FastEthernet0/0
O E2     172.16.2.1/32 [110/1] via 10.1.1.1, 00:00:31, FastEthernet0/0
CE-A1#
  Known via "ospfv3 1", distance 110, metric 1, type extern 2, forward metric 1
  Last update from 10.1.1.1 on FastEthernet0/0, 00:01:28 ago
  * 10.1.1.1, from 10.1.1.1, 00:01:28 ago, via FastEthernet0/0
      Route metric is 1, traffic share count is 1
CE-A1#
Verify that PE1 router is advertising an LSA Type 5 for the 172.16.2.1/32 prefix:
PE1#show ospfv3 vrf CUST-A database external
                Type-5 AS External Link States
  LS age: 5
  LS Type: AS External Link
  Link State ID: 0
  Checksum: 0x1EB2
  Length: 32
  Metric Type: 2 (Larger than any link state path)
  Metric: 1
  LS age: 5
  Link State ID: 1
  Checksum: 0xFF16
  Length: 32
  Metric: 1
PE1#
Verify the LSDB of the VRF CUST-A on PE1 router and the LSA Type 5:
 10.1.1.1        892         0x80000005  0            1           B E
 172.16.1.1      1087        0x80000004  0            1           None
 172.16.1.1      1087        0x80000003  2          2
 10.1.1.1        892         0x80000003  2          Fa0/0
 172.16.1.1      1345        0x80000003  2          Fa0/0
 172.16.1.1      1087        0x80000005  0          0x2001      0
 172.16.1.1      1087        0x80000003  2048       0x2002      2
 10.1.1.1        539         0x80000001  10.2.2.0/24
 10.1.1.1        539         0x80000001  172.16.2.1/32
PE1#
Verify that the prefix 172.16.2.1/32 is advertised as inter-area route for VRF CUST-B by looking the LSBD for VRF CUST-B, because simply the prefix 172.16.2.1/32 for the VRF CUST-B is advertised with the default domain ID by PE2 router:
PE1#show ospfv3 vrf CUST-B database
 10.3.3.1        850         0x80000005  0            1           B E
 172.16.1.1      808         0x80000004  0            1           None
 172.16.1.1      808         0x80000003  2          2
 10.3.3.1        608         0x80000002  10.4.4.0/24
 10.3.3.1        608         0x80000002  172.16.2.1/32
 10.3.3.1        850         0x80000003  3          Fa0/1
 172.16.1.1      1067        0x80000003  2          Fa0/1
 172.16.1.1      808         0x80000005  0          0x2001      0
 172.16.1.1      809         0x80000003  2048       0x2002      2
PE1#
At the other side, PE2 router advertises an LSA Type 5 for the prefix 172.16.1.1/32 into VRF CUST-A because the PE1 advertises it with the default domain ID 1 and PE2's domain ID has been changed earlier to be 000000000310 for VRF CUST-A:
PE2#show ospfv3 vrf CUST-A database
 10.2.2.1        1015        0x80000005  0            1           B E
 172.16.2.1      1070        0x80000004  0            1           None
 172.16.2.1      1070        0x80000003  2          2
 10.2.2.1        1015        0x80000003  2          Fa0/0
 172.16.2.1      1330        0x80000003  2          Fa0/0
 172.16.2.1      1070        0x80000005  0          0x2001      0
 172.16.2.1      1070        0x80000003  2048       0x2002      2
 10.2.2.1        712         0x80000001  10.1.1.0/24
 10.2.2.1        712         0x80000001  172.16.1.1/32
Verify that PE2 is receiving the prefix 172.16.1.1/32 as inter-area route because both PE routers are using their default domain ID which the process ID of OSPF:
PE2#show ospfv3 vrf CUST-B database
 10.4.4.1        983         0x80000005  0            1           B E
 172.16.2.1      926         0x80000004  0            1           None
 172.16.2.1      926         0x80000003  2          2
 10.4.4.1        724         0x80000002  10.3.3.0/24
 10.4.4.1        724         0x80000002  172.16.1.1/32
 10.4.4.1        983         0x80000003  3          Fa0/1
 172.16.2.1      1179        0x80000003  2          Fa0/1
 172.16.2.1      926         0x80000005  0          0x2001      0
 172.16.2.1      926         0x80000003  2048       0x2002      2
PE2#
Finally verify the routing tables of the CE routers:
CE-A1 and CE-A2  routers are receiving external routes O E2 from PE1 and PE2 routers respectively because the mismatched domain ID.
CE-B1 and CE-B2 routers are receiving inter-area routes O IA from PE1 and PE2 routers respectively because the matched domain ID.
CE-A1#show ip route OSPFv3 | beg Gate
O E2     10.2.2.0/24 [110/1] via 10.1.1.1, 00:13:45, FastEthernet0/0
O E2     172.16.2.1/32 [110/1] via 10.1.1.1, 00:13:45, FastEthernet0/0
CE-A1#
CE-A2#show ip route ospfv3 | beg Gate
O E2     10.1.1.0/24 [110/1] via 10.2.2.1, 00:15:06, FastEthernet0/0
O E2     172.16.1.1/32 [110/1] via 10.2.2.1, 00:15:06, FastEthernet0/0
CE-A2#
CE-B1#show ip route ospfv3 | beg Gate
O IA     10.4.4.0/24 [110/2] via 10.3.3.1, 00:48:56, FastEthernet0/0
O IA     172.16.2.1/32 [110/2] via 10.3.3.1, 00:48:56, FastEthernet0/0
CE-B1#
CE-B2#show ip route ospfv3 | beg Gate
O IA     10.3.3.0/24 [110/2] via 10.4.4.1, 00:50:02, FastEthernet0/0
O IA     172.16.1.1/32 [110/2] via 10.4.4.1, 00:50:02, FastEthernet0/0
CE-B2#
