Small Business Online Device Emulators
For the latest information on our products including features, capabilities and sales information, please visit Switches, Routers, and AP for further products related information. The Product Device Emulators are available to show an online representation of our Device interfaces. Actual device configuration experience will be slightly different based on saved configurations and firmware versions
For EOL'ed models, please click Archive
Wireless Access Points
Cisco Business Wireless Access Points (140AC | 145AC | 240AC)
Online Device Emulator (ver 10.3.1.0)
Online Device Emulator (ver 10.2.1.0)
Note: mobile browser support not available at this time.
WAP125 Wireless-AC Dual Band Desktop Access Point with PoE
Online Device Emulator (ver. 1.0.1.5)
Online Device Emulator (ver. 1.0.0.3)
  • Cost-Effective 802.11ac Wave 1 wireless technology
  • Single PoE (802.3af) Gigabit Ethernet port for simple installation and powering
  • intuitive web-based configuration wizard for deployment and setup in minutes
  • Support for Cisco FindIT Network management means easy management and control
  • Limited lifetime hardware warranty for peace of mind
_____________________________________
4 wap150-resized.jpgwww.cisco.com
WAP150 Wireless AC/N Dual Radio Access Point with PoE
Online Device Emulator (ver. 1.0.0.16)
  • Concurrent dual-band radio supports up to 1.2 Gbps for increase capacity and coverage
  • Gigabit Ethernet LAN interface with Power over Ethernet (PoE) for flexible installation
  • Single Point Setup requires no controller, for easy, cost-effective deployment of multiple access point
  • Sleek design with multiple internal antennas
  • Works right out of the box with easy installation and a simple web-based configuration and wizard
WAP361 Wireless AC/N Dual Radio Wall Plate Access Point
  • Concurrent dual-band radio support up to 867 Mbps on a 5.0-Ghz radio and 300 Mbps on a 2.4-Ghz radio
  • Supports 2x2 multiple-input multiple-output (MIMO) technology with two spatial streams for maximum performance on both 2.4- and 5.0-GHz radios
  • A 5-port Gigabit Ethernet LAN switch supports both PoE powered device (PD) and powered sourcing equipment (PSE) so that IP devices can be powered and the access point can be powered by the backbone switch
  • A captive portal helps enable highly secure guest access with customized roles and rights
  • Single Point Setup requires no controller for easy, cost-effective deployment of multiple access points
11 wap571-resize.jpgwww.cisco.com
WAP571 Wireless-AC/N Premium Dual Radio Access Point with POE
Online Device Emulator (ver. 1.1.0.3)
Online Device Emulator (ver.1.0.0.14)
  • Dual-Radio 802.11ac connectivity with speed up to 1.9Gbps
  • Supports 3x3 multiple-input multiple-output (MIMO) technology with three spatial streams
  •  Dual Gigabit Ethernet LAN with Energy Efficient Ethernet and link aggregation support
  • Captive portal helps enable highly secure guest access with customized roles and rights
  •  Single Point Setup requires no controller, for easy, cost-effective deployment of multiple access points
  • Works right out of the box with easy installation and simple web-based configuration and wizard
12 wap571e-resized.jpgwww.cisco.com
WAP571E Wireless-AC/N Dual Radio Outdoor Access Point
  • Provides cost-effective 802.11ac outdoor connectivity with speed up to 1.9Gbps
  • Supports 3x3 multiple-input multiple-output (MIMO) technology with three spatial streams for maximum performance on both 2.4- and 5.0-GHz radios
  • Outdoor-rated IP66 enclosure designed for challenging outdoor environments such as rain and extreme temperatures, as well surge protection support
  • Sleek design with multiple internal antennas and a versatile mounting kit allows for installation on a pole or a wall
WAP581 Wireless-AC Dual Radio Wave 2 Access Point with 2.5GbE LAN
Online Device Emulator (ver. 1.0.1.3)
Online Device Emulator (ver.1.0.0.4)
  • Provides cost-effective 802.11ac Wave 2 connectivity with speed up to 2.8 Gbps
  • Supports 4x4 multi-user multiple-input, multiple-output (MU-MIMO) technology on 5.0-Ghz radio and 3x3 MIMO technology on 2.4-Ghz radio for maxium performance
  • Supports Dual Gigabet Ethernet (2.5Ghz and 1G) LAN with Energy Effecient Ethernet and link Aggregation
  • Supports both Power over Ethernet (PoE) and AC Power with external power adapter
  • Offers captive portal that enables highly secure guest access with customized roles and rights
  • Offers Single Point Setup which requires no controller, for easy, cost-effective deployment of multiple access points
Learn more about Cisco Small Business Wireless Access Points
RV Series Routers
RV160 VPN Router
Online Device Emulator (ver. 1.0.00.14)
  • Dual Core CPU
  • New User Interface
  • SFP/Ethernet Combo WAN
  • 4-port switch
  • RV160 Product Page
RV160W Wireless-AC VPN Router
  • 2x2 11ac Wireless
  • Dual Core CPU
  • 4-port switch
  • RV160W Product Page
RV260 VPN Router
  • Dual Core CPU
  • Rackmount Ready
  • 8-port switch
  • One Year Webfiltering
  • RV260 Product Page
RV260P VPN Router with PoE
  • Dual Core CPU
  • Rackmount Ready
  • 8-port switch
  • 4-ports Power over Ethernet
  • RV260P Product Page
RV260W Wireless-AC VPN Router
  • Dual Core CPU
  • Rackmount Ready
  • 8-port switch
  • 3x3 11ac Wave 2
  • RV260W Product Page
RV340 Dual WAN Gigabit VPN Router
Online Device Emulator (ver. 1.0.03.15)
Online Device Emulator (ver. 1.0.02.16)
Online Device Emulator (ver. 1.0.01.17)
Online Device Emulator (ver. 1.0.0.33)
  • 2 WAN ports (RJ-45) for load balancing and resiliency
  • 4 LAN ports for high-performance connectivity
  • 2 USB ports to support a 3G/4G modem or flash drive
  • 900 Mbps TCP throughput for improved productivity
  • VPN functionality for secure interconnectivity, including standard IPsec, Layer 2 Tunneling Protocol (L2TP) over IPSec, and Cisco IPsec
  • Support for the Cisco AnyConnect Secure Mobility Client, ideal for remote access by mobile devices
RV340W Dual WAN Gigabit Wireless-AC VPN Router
  • 1 Gig Firewall Throughput
  • Dynamic Web Filtering helps emable business efficiency and security when connecting to the web
  • Client and application identification allows internet access policies for end devices and cloud applications, helping to ensure performance and security
  • 4 Gigabit LAN ports facilitate high-speed connectivity of your network devices
  • The RV340W has integrated 802.11ac Gigabit WiFi for your mobile devices
RV345 Dual WAN Gigabit VPN Router
Online Device Emulator (ver. 1.0.00.17)
  • 16 LAN ports for high-performance connectivity
Cisco RV345P Dual WAN Gigabit PoE VPN Router
  • 1 Gig Firewall throughput
  • Dynamic Web Filtering helps business efficiency and security when connecting to the web
  • Client and application identification allow internet access policies for end devices and cloud applicatoins to help ensure performance and secutiry
  • The RV345P has 16 LAN ports, half with Power over Ethernet (802.3at PoE). These allow direct connectivity for all your network devices, including access points and phones, without the need for extra power suppoies or a switch
RV132W ADSL2+ Wireless-N VPN Router
Online Device Emulator (ver. 1.0.0.17)
  • ADSL2+ and Ethernet WAN Ports
  • Built-in 3-port Ethernet switch
  • Strong security with proven stateful packet inspection (SPI) firewall and hardware encryption
  • High-capacity, high-performance, IP Security (IPsec) VPN capabilities
  • Easy set-up and deployment with the intuitive, browser-based device manager and setup wizards
RV134W VDSL2 Wireless-AC VPN Router
Online Device Emulator (ver. 1.0.0.21)
  • VDSL2 and Ethernet WAN Ports
  • Built-in 4-port Gigabit Ethernet Switch
  • Backward compatible to ADSL2+
Learn more about RV Series Routers
Smart Switches
200 Series Smart Switches
SG200-50P Smart Switch
Online Device Emulator (ver. 1.2.9)
Online Device Emulator (ver. 1.1)
  • Get a business-class network with such features as quality of service, security, Power over Ethernet, and IPv6 support
  • Eco-Friendly Solution: Optimize power usage for efficiency, without compromising performance
  • Limited Lifetime Hardware Warranty with next business day advance replacement, where available
Note: All specific switch models may have small differences in the functionality from other models within a series or the emulator. Please click the link below to access the Data Sheet for more information.
Learn more about
220 Series Smart Switches
 SG220-50P Smart Switch
Online Device Emulator (ver.1.0.0.18)
  • A higher level of security and intelligence
  • Simple and flexible management
  • Power over Ethernet Plus (PoE+)
Learn more about
250 Series Smart Switches
SF250-48HP Smart Switch
Online Device Emulator (ver. 2.2.0.63)
  • Reliable Easy-To-Use Basic Business at an Affordable Price
  • 30W PoE+ support is now in our Smart Switch Portfolio
  • USB Port for easy configuration and image management
Learn more about
300 Series Managed Switches
SG300-28P Managed Switch
Online Device Emulator (ver.1.1)
SG300-52 Managed Switch
Online Device Emulator (ver.1.2.9)
  • Easy Setup and Management: Intuitive browser-based tools simplify setup and configuration
Learn more about
350 Series Managed Switches
SG350-10P Managed Switch
  • Easy-To-Use Managed Switches with ideal Combination of Features and Affordability
  • 60W PoE and PoE for flexible PoE deployment
  • Simple mode menu, dashboard, and wizards save time in day to day operations
Learn more about
350X Series Stackable Switches
SG350X-24P Stackable Switches
  • Affordable 10G Ethernet for a fast and reliable network
  • Strong security, Advanced QoS, and Static Routing
  • True Stacking up to 4 units
Learn more about
350X Series Managed Switches
500 Series Stackable Switches
SG500-52P Stackable Managed Switch
  • 10/100 and Gigabit platforms with 5 Gig Stackable interfaces
  • Support for VRRP redundancy and RIP Dynamic Routing
  • Advanced Security such as IPv6 FHS, CoPP, and rich 802.1x support
SG500X-48P Stackable Managed Switch
  • Gigabit and 10-Gigabit Stackable models with 10-Gig Stackable interfaces
Learn more about
550X Series Stackable Switches
SG550XG-48T Stackable Switch
  • 10G Ethernet and advanced features to accelerate growing businesses
  • Hardware redundancy and dynamic routing ensures higher availability
  • True stacking- up to 8 units
Learn more about
Smart Network Application
Cisco Smart Network Application (SNA)
Online Device Emulator (ver. 2.4.0.76)
An innovative network-level monitoring and management tool embedded in Cisco 250 to 550X Series switches. It can discover network topology, display link status, monitor events, apply configurations, and upgrade software images across multiple switches in the network. a business-class network with such features as quality of service, security, Power over Ethernet, and IPv6 support
Learn more about
Hosting Switch Emulators Locally
Other than the online emulators available on this page, there is a huge collection of 200, 300, and 500 series emulators available for download which can be hosted in your local PC.
After download, unzip the file.
In the root directory, scroll down to the bottom and double click the .htm file which corresponds to the SKU and version you are interested in.
Username: cisco
Password: cisco
Recommended browsers: IE or Firefox.
Command Line Interface (CLI) Emulator for 300 Series Switches
**Note: Incompatibility issue with Windows 10 is currently being investigated.**
Get familiar with the CLI interface without actually being connected to a switch in real-time.
Download and unzip the file to your computer and select the  'run_SG300_28_AlleyCat_SA.bat' file.
Username: cisco
Password: cisco
