Dear Supports:
I am newbie with Cisco, and I bought a Cisco RV130W wireless VPN router last week but
I got same problem with this router.
1)I have installed a DHCP server in our internal network so I have disabled the DHCP
service under network > LAN > LAN configuration > Server Settings(DHCP), but after
this action, all of our wireless device can not get IP again, finally I have
enabled the DHCP relay and put the DHCP server IP to "Remote DHCP Server" field, and
the problem seems fixed, may I know I have take a right action ? And if the answer
is yes, what is the usage for the DHCP Server "Disable" option ?
2)When I set DHCP to Disable, I find that dashboard still showing that the DHCP
server still in "Enabled" status (Dashboard right top corner > LAN (local network)
Interface > DHCP Server: Enabled), may I know it is a firmware bug or just some
setting I missed ?
3)WiFi signal is weak but I can not find any setting to control signal strong, some
times the SSID disappeared, finally I find that because I placed a Ext. USB 3.0 HDD
aside the router, after I remove the HDD and the SSID never disappear again, but I
don't know why this case happened and how can I prevent those case happened again?
4)In dashboard I find that VPN server > PPTP User: 0/1 , but in user manual I also
find that PPTP VPN > 10 PPTP tunnels for remote client access, may I know in
actually the router supports 1 or 10 PPTP user(s) ?
5)The PPTP VPN will disconnect automatically after connected 10~15 mins, I have try with 2 android device , one is running android 4.2 with native VPN client , and another one is running android 4.4.2 with apps "VpnRoot" , can you let me some hints how to trace and fix the problem ?
Thank for the support and I am wait for the reply , thanks.
