04-02-2020 05:56 AM
rv 320 can not give out dhcp over 192.168.1.149
04-02-2020 08:24 AM
- Note that DHCP is a layer 2 protocol and initially a DHCP server can only serve clients which are on the same layer 2 network.
M
04-03-2020 02:41 AM
Hi Sir,
My name is Puneet Sandel and I am from Cisco small business technical support center.
Please disable PPTP Server under VPN because the DHCP pool is used sometimes for PPTP client pool.
Also for any VLAN you can use DHCP pool from 192.168.1.2-192.168.1.254 (192.168.1.1 being the default gateway IP) ( only if you are not using that in PPTP/L2TP VPN.
You will have to manually change the DHCP pool range also under DHCP/LAN settings. (From .100 -.149 to .2-.254)
Let me know if you have any further queries and do not forget to make it a solution if your issue gets resolved.
Puneet Sandel
Technical Consulting Engineer-Level 2
Global CX Centers – Small Business Support
