Help needed with RV042 v3 router firmware/recovery
spmorin01
Help needed with RV042 v3 router.
I have an RV042v3 that has somehow lost/corrupted its firmware. I have attempted to "revive" it  using the Router Firmware Rescue Utility at the following link;
http://www.cisco.com/c/en/us/support/routers/rv042-dual-wan-vpn-router/model.html#~tab-downloads
Everything appears to work fine and i am able log into the web admin page via (192.168.1.1 and admin/admin) .However once in, all of the menu option are blank or have no data?
I can see the entire menu structure as expected, but all options are empty?
I have also tried what seems to be a newer version of the Rescue Utility, but that version keeps coming up with a TFTP error or a password error??
Do I spend any more time on this device or is it "dead"
thanks,
Try other browser
or
flash with newer firmware using tftp:
* set static IP i.e. 192.168.1.10 on your pc
* set uboot to recovery mode by starting router with reset button pressed for 15 seconds (or more) -DIAG should blink slowly
* run tftp
     tftp -i 192.168.1.1 PUT  RV0xx.bin /tmp/tmpfs/image
where RV0xx.bin is the name of firmware file
