06-24-2009 04:30 PM
Hi, How can I configure(in the router) an specific static internal IP address for instance (192.168.3.45) to an specific computer on my LAN? Is it enough to assign the static IP address in the computer only? My goal is to set this IP statically for Port Forwarding. I want to know as well how to setup (in a secure way) the remote administration of the router. Thank you
06-25-2009 09:58 AM
Hello and thanks for the post. Please consider posting your question in the Routers section of the Small Business Support Community: https://www.myciscocommunity.com/community/smallbizsupport/routers.
Thanks!
06-25-2009 07:42 PM
Hi, thank you for your answer, but the link you sent me did not work. How can I get to that "Routers section of the Small Business Support Community"?
