08-25-2011 07:32 AM
Hi, I am using the RV220W with the latest firmware, I disabled all the four APs and also disabled the Radio, but the "Wireless" green light on the front panel still ON, why? How can I completely turn off the wireless?
Quoted from manual:
WIRELESS—The Wireless light is green when the wireless module is enabled. The light is off when the wireless module is disabled.
Moreover I tried to disable the "Radio" while enabled one AP, I found that I can still connect to that AP, so what is the Radio's Enable/Disable used for??
Thanks.
Raymond
08-29-2011 04:05 AM
Yep looks like a bug to me, selected disabled on the Radio button, saved and then joined all 3 Access points i have setup with my Blackberry.
- maybe its just a feature lol.
11-04-2011 07:19 PM
confirmed x 10.
completely and utterly broken. router also seems to still be pulling the same amount of power, so radio does appear to be on, on, on.
