04-02-2008 06:26 PM
I posted this query in a different forum and then discovered this forum on small businesses. This is likely a more appropriate forum for this question. Sorry for the duplicate posting.
I am trying to install a Linksys WCG200 wireless router in my SOHO office with five employees. How do I configure it so that people in the neighboring office don't get access to any data moving on this network? Thanks in advance for any help that someone can provide.
Cheers!
Solved! Go to Solution.
04-03-2008 12:25 PM
Rick,
I hope you can get to this link, if you get to this pdf look in Apendix B (Wireless Security), this is a step by step to secure your wireless network.
Let me know if you need help but should be stright forware, just follow the instructions.
Rgds
Jorge
04-03-2008 12:25 PM
Rick,
Rgds
Jorge
04-03-2008 03:45 PM
Thanks, Jorge. I appreciate your response. I was able to get to this link and am now reading Appendix B.
regards,
Rick
04-03-2008 03:47 PM
Jorge,
Also, I was looking for an option to rate your response (5 stars of course :-) ) but couldn't find an obvious way to do this. I am new to NetPro and assumed that they would have some way to rate responses.
Rick
04-03-2008 05:02 PM
Rick, thank you.. if you look at the bottom right corner message window on any of my responses of this thread there is a text that saids Rate this Post, if you click it will show the rating scales.
Im glad the document was helpful and again if there is questions don't hesitate to ask.
Bst Rgds
Jorge
04-03-2008 05:15 PM
Ah! Since the URL that you had pasted was lengthy,it pushed the rating box to the right and out of view of the screen. I found it now and have rated your response. Thanks!
Rick
