MAC filtering on LAN ports WAN port for RV134W
home user
If I want to filter incoming WAN trafic to a device connected to one of the LAN ports Is it possible to filter MAC on LAN ports and / or WAN port for RV134W  ?
Hi @home user
Never tried but as per the documentation it is possible. Refers to this link:
https://sbkb.cisco.com/CiscoSB/GetArticle.aspx?docid=72a2c1708e0145efae0f420bc4211d73_h_5265.xml&pid=2&converted=0&offline=0
-If I helped you somehow, please, rate it as useful.-
Thank you for the link. However the article is for wireless access point not LAN ports.
It was really easy to enable filtering MAC on wireless network.
Sorry I though could be the same. Probably is not possible considering it should be that easy as well.
