06-15-2019 04:54 AM
Evening All,
Just wondering if anyone had thoughts or advice re: the above scenario? I am currently using a USG Pro 4 which has terrible L2TP/IPsec speeds, could I purchase a Cisco RV340 and place behind the USG Pro 4 for Client VPN access (AnyConnect).
I would greatly appreciate any comments or advice.
Thank you!
Brad
06-17-2019 05:26 AM
That will work. Anyconnect throughput is about 30Mbps on RV340. It uses SSL. So you need to forward the Anyconnect port ( typically 7443 or 8443 ) to the RV340. Works out of the box with mobile devices. Anyconnect clinet is on app or play stores.
For up to 650Mbps throughput you can use IPsec from a laptop. Anyconnect client not requried. However I have no experience on IPSec VPN passthru on the USG.
Jo
06-18-2019 03:57 AM
Thanks Jo - appreciate the reply!
06-18-2019 08:38 AM
Following is the capacity and performance of rv340 regarding VPNs. You can compare these with USG 4 and if rv340 is better than USG 4, then I will suggest replace USG 4 with RV340, not put it behind USG 4.
