problem configuring vpn "invalid ip address" with srp527W
dinhocosta
I'm tryng to configure a vpn with a cisco small business pro router, model srp527W-k9-g5
But when i try to set the “remote ip”  in Remote traffic selection a I have to set (10.0.0.0) a message said:
  “Invalid IP Address Format”
If i change the ip and i put 10.0.0.1 i have not error but I have to put 10.0.0.0 and if i configure it on a cisco WRV210 (por example) i have no error.
Can you help me with this issue?
Thanks Dino
dinhocosta
I've solved the problem upgrading to the last firmware
