06-29-2015 07:25 AM
Hi All,
I have recently purchased a RV110W router and I have followed the instructions to try and confogure the router. However, when I type 192.168.1.1 in the address bar I get a timed out/problem loading pagfe message. So I tried to ping it via cmd.exe I get the message Destination host unreachable.
Does anyone one have any suggestions to resolve this problem?
Thanks in advance
Ray
06-29-2015 10:19 AM
what is the ip Address of your machine from which you are trying to connect ?
it should be in the same range to have it pingable or atleast routing should be configured.
03-08-2016 11:47 AM
Ray,
You will need to type in https://192.168.1.1
unless the ip address in the book you got is different.
