RV215W not recognizing Huawei E398
matze7401
I need support with the RV215W. It won't recognize a Huawei E398 LTE-Stick (Germany: Telekom Speedstick LTE). According to
https://supportforums.cisco.com/docs/DOC-29162 the RV215W should support the Speedstick LTE.
Router Firmware: 1.0.1.1 (newest)
E398 Firmware: 11.433.61.10.55 (newest from Telekom)
Thank you for your help
matze
Eric Moyers
Level 7
Level 7
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center. Thank you for using the Cisco Community Post Forums.
For this issue please call into one of the Support Centers listed at the link below. For Europe, please use the Support Center in Sophia Bulgaria.
Eric Moyers    .:|:.:|:.
Cisco Small Business US STAC Advanced Support Engineer
CCNA, CCNA-Wireless
866-606-1866 ext 601027
Mon - Fri 09:00 - 18:00 (UTC - 05:00)
*Please rate the Post so other will know when an answer has been found.
Cisco Small Business Support contacts: http://www.cisco.com/en/US/partner/support/tsd_cisco_small_business_support_center_contacts.html
