RV220W - After creating a VPN connection, is it necessary manually create routing protocols so that traffic destined for the VPN network goes across the tunnel?
PalmBayChuck
I have successfully build my tunnel, but I cannot seem to get traffic to flow across it to the corporate network on the other side of the tunnel. Is it necessary to create any routing information so that work flows?
tomfowle
Traffic will still have to be routed just like a standard WAN link.  Static routes or a dynamic protocol must be used to route your traffic accross the tunnel.
Tom
Te-Kai Liu
Level 7
Level 7
It's not needed to add additional routes if the traffic is between the two subnets defined in the VPN policy.
