Hello
I have an RV325 with two WAN connections.
What I want is to be able to use both WAN connections when they're working, and if one WAN connection stops being able to connect to the Internet, just use the other WAN connection.
- If I set the RV325 to "Smart link backup", I think that it just uses WAN1 unless WAN1 fails, in which case it uses WAN2.
- If I set it to "Load Balance", I think that is uses both WAN ports equally; but if one of them ceases to be able to connect to the internet, RV325 continues to route traffic to it.
Isn't there some clever setting that will do what I really want, please?
