RV325 - Port forwarded but still closed
randrade86
We have a RV325 (192.168.63.1) router behind our TP-Link router (192.168.0.1), in a pretty simple setup.
RV325 is also the DHCP server. Everything works great except that no device in 192.168.63.0/24 is accessible from outside (Internet). We forwarded all ports that we needed from TP-LINK to RV325, but looks like RV325 is not forwarding any ports to other IPs (192.168.63.2 for example)
For this example, we did a PAT the TCP port 3000 to 192.168.63.2 81 and ran a nmap scan from an external machine:
Nmap scan report for XXXXXXX (XXXXXXXXX)
Host is up (0.22s latency).
PORT STATE SERVICE
3000/tcp closed ppp
TP-Link is certainly not the problem since if we enable PPTP in RV325, it will show the 1723/tcp open
Here is our PAT settings:
We tried to set firewall permissive access rules or even disable the firewall but to no avail.
Running RV325 on latest firmware, can ping 192.168.63.2 just fine. We just did a factory reset.
Can anyone shed a light?
Firmware Version: v1.4.2.17 (2017-10-30, 15:50:18)
16 Replies 16
I think my problem had to do with my ISP blocking ports they claim not
to block.  As soon as I forwarded from Port 5000 to my sub-1024 well
known port it all started working.   There is an excellent chance this
was not a problem with the Cisco.
My unit was faulty. I bought an used Fortigate router and it worked flawlessly. We retired our Cisco RV325.
