RV340 no access to web interface after update firmware
nordkap
Good day! The firmware version 1.01.17 was installed on the router and the search and installation of updates was disabled. Due to the fact that I was having trouble with the port switching setup, I decided to perform an automatic download and update the firmware to version 1.0.02.16. Update passed without errors, but after reboot of a router its operability remained, both on a local network, and on vpn, but it is impossible to come on the web interface any more. IP router 192.168.77.200 pinged, but open the page on authorization by login and password in different browsers is impossible. Clearing the cache didn't help either. To reset to factory settings considered as extreme. Is there any utility to access the settings or any other way to get into the WEB interface? I was denied access from WAN interfaces and opened from all IP LAN over http, https was disabled.
raymondnichols
Today I went to access my 7 month old rv340 and it would not accept my login info.  I Followed some suggestions none have worked.  The router has been reset to factory settings numerous times with no result.  I can ping it and the login window shows but it won't even accept cisco/cisco.  A circle just spins but no login into the Admin GUI.  It appears that the Web GUI is the only game for the 340 from what I have read.  Any other suggestions?
Hi there,
My name is Nikola and I'm Cisco SMB team member.
It is very important to make sure you have typed 192.168.1.1 in the address bar.
If this address is not accepted try with the one you'll assign  through Network and Sharing centre.
