SRP527w site to site port forwarding issue
thnguyen2011
I have problem with setting up the port forwarding on the VPN between two cisco 527w.
Scenario where a Site to Site VPN tunnel has been established between Site A and Site B; a Printer behind Site B needs to be accessed by using the WAN IP address of Site A.
As the picture above:
- From site A, I am able to ping printer and access to printer locally and via 120.146.x.x with port forwarding setup on site A to the printer.
- From site B, I am able to ping site A gateway but not able to access to the printer via 120.146.x.x. The printer can be access via 129.203.x.x if the port forwarding is setup on site B to the printer.
Does Cisco SRP 527w support port forwarding over site to site VPN from site A to printer on site B?
Is there any suggest or other solution for this scenario?
Some help would be highly appreciated.
Thai
15 Replies 15
Hi Andrew,
I have change the static site with the Cisco 877. Would you please advise how to config to make portforwarding work to the remote site?
I have create new post in here: https://supportforums.cisco.com/thread/2154768?tstart=0
