03-04-2019 12:37 PM - edited 05-16-2019 10:19 AM
March 2019
The Cisco RV340 series consists of the RV340, RV340W, RV345, and RV345P models. Starting with firmware release 1.0.2.x these models added the Cisco Umbrella network device integration feature.
Umbrella is a cloud-delivered security platform that protects against threats on the internet. With Umbrella, you gain visibility and enforcement at the DNS-layer, so you can block requests to malicious domains and IPs before a connection to your network or endpoints is ever made. And because it’s built into the foundation of the internet and delivered from the cloud, Umbrella is the simplest security product to deploy and delivers powerful, effective protection.The integration allows for easy setup, enhanced visibility and reporting, and a small business friendly branch license for Cisco Umbrella. For more info look here for a setup guide:https://docs.umbrella.com/hardware-integrations/v1.0/docs/integration-for-rv-series-routers
If you are new to Cisco Umbrella a new branch license was created to allow simple and cost effective security for a small business:
As a Cisco partner you need to select UMBRELLA-SUB in the Cisco ordering tool and then select the option UMB-BRAN-RV.
This process is similar to other Umbrella volume or branch licenses as well.
Name |
SKU |
Cisco RV340 Umbrella Branch |
UMB-BRAN-RV |
Below is a table of comparison of the features you get with the RV Branch License.
Please consult the Cisco Umbrella website umbrella.cisco.com for changes and up-to-date info on the Cisco Umbrella Professional, Insights, and Platform offerings.
Support services need to be added while ordering.
If you’re not currently an Umbrella customer, you can sign up for a free 14-day trial at signup.umbrella.com.
Thanks! My Cisco Partner is getting it setup for me to add to a UMB-BRAN-RV license.
