laflamme93
After upgrading to Ios 17.6.3a, I have problem with smart licensing. Trust code is installed(Idtoken) without any problem but it is not authorized
RT1#show license authorization
Overall status:
Active: PID:C1101-4P,SN:FCZXXXXXXXX
Status: NOT INSTALLED
Purchased Licenses:
Cisco 1100 Series with 4 LAN Ports , Security License (ISR_1100_4P_Security):
Description: Cisco 1100 Series with 4 LAN Ports , Security License
Total reserved count: 1
Term information:
License type: PERPETUAL
Term Count: 1
4 Comments
balaji.bandi
License type: PERPETUAL  ( do you have any other performance Licenses ?)
have you configured smart License config to reach cisco smart License server ?
https://blog.octanetworks.com/cisco-smart-licensing-troubleshooting-steps-and-considerations-on-catalyst-platforms/
laflamme93
Hello, sorry for late answer.
yes configuration is done and it can reach Smart License server.
In she show license status command it shows that trust code is installed("Trust Code Installed: Dec 07 16:38:09 2022 GEST") and after installation my router appeared in Product Instance page on my Cisco Smart Licensing account.
In the previous versions for example in 16.12.05 after generating ID token and registering with it Router was authorized. Is there any addition configuration needed for new Ios?
balaji.bandi
if the device is already registered in a smart license you do not need to do anything.
laflamme93
And what about authorization ?
