SDA for Wireless Design
fatalXerror
Level 7
Level 7
Hi Guys,
I am new in SDA solutions, I would like to ask the following,
1. Where should I connect the non-fabric devices like firewall, WLC, etc.? Directly to the BN node?
2. Typically, how many BN and CP nodes should I deploy, two for redundancy?
3. How to connect my firewall if I want that the gateway of my networks are in the firewall?
4. Can my ISE and DNAC be in the DC instead of the office campus where the SDA fabric are formed?
5. Is the foreign-anchor wireless design still applicable in SDA for guest access?
Thank you so much.
I dont see the need for a dedicated BN.
The BN would be the gateway
13 Replies 13
Hi @fatalXerror
"I am new in SDA solutions, I would like to ask the following,"
 SDA is pretty new so I believe everyone around here is also learning. I had the opportunity to deploy and I will try to help with what I know. This is a very interesting topic.
"1. Where should I connect the non-fabric devices like firewall, WLC, etc.? Directly to the BN node?"
 Non-Fabric device is connected to the Border Nodes.  Although WLC is a Fabric device(depending the model and version). If you take a look on the CVD for SD-A, this will be there:
"Border Node
The fabric border nodes serve as the gateway between the SD-Access fabric site and the networks external to the fabric. The border node is responsible for network virtualization interworking and SGT propagation from the fabric to the rest of the network."
I dont believe there will be a magic number. It will depend on the size of the network.  But a typical CVD SDA design diagram shows two BN for redundancy
The gateway for the Fabric will be a device that is part of the Fabric. On this case, it can not be the firewall.
I would say this is actually the normal deployment.  ISE and DNAC is more common find in the Data Center and the fabric switches spread across the campus. What DNAC and ISE requires is basic connectivity.
According to the Cisco doc "SD-Access Wireless Design and Deployment Guide" it is not needed.
• Simplified guest and mobility tunneling: An anchor wireless controller (WLC) is no longer needed; guest traffic can go directly to the network edge (DMZ) without hopping through a foreign controller.
For your reference
https://www.cisco.com/c/en/us/td/docs/solutions/CVD/Campus/cisco-sda-design-guide.html
Hi @Flavio Miranda , thank you for your reply, appreciate the help.
I have some additional questions,
1. I believed migrating to SDA from traditional network is not one-shot migration. In my case, all of my VLANs' gateway in my traditional network is in the firewall it is connected to a core switch, as part of the migration phase, can I connect my Border Node (BN) to the core switch via L2 link so that per VLAN migration for example wireless network VLAN to be migrated to SDA but the gateway will still be in the firewall traversing the packet via L2 link?
2. Will SGT tags be dropped once it come out of the Border Node? What will be the solution so that SGT tags will not be dropped when traversing over IP WAN (MPLS)?
3. Instead of SGT as a way of ISE enforcement, can I use VLAN instead?
4. Should the server farm network be part of the SDA fabric?
Thank you
"1. I believed migrating to SDA from traditional network is not one-shot migration. In my case, all of my VLANs' gateway in my traditional network is in the firewall it is connected to a core switch, as part of the migration phase, can I connect my Border Node (BN) to the core switch via L2 link so that per VLAN migration for example wireless network VLAN to be migrated to SDA but the gateway will still be in the firewall traversing the packet via L2 link?"
 Migration strategy is surelly the key moment to deploy SDA.  I am afraid that it will not work this way but this is something that worth to be stressed up to the limit.
Install you BN  side by side to the Core and extend layer2 link and maybe migratiing your access switch to the Border Node keeping the layer3 where it is today is one possibility.
  The SGT is enforced by ISE to the Access Switch and it is sent to the switch on the TrustSec matrix.  This is  something that will be on the switch (ACL) and not flying around the MPLS link.
The logic is:  You create the SGT Map on the DNAC. DNAC update the ISE via PXGRID and the ISE enforce the TrustSec matrix to the switch via Radius authentication.
   You will use VLAN anyway. I dont believe SGT is a requirement but I might say it is a huge improvement on the security.
  I believe it is up to the environment.  I see SDA more close to access switches and end point devices but I dont believe it must be limited to that.
Hi @Flavio Miranda , thanks again for the help.
Apologies, I just want to change the statement about the migration strategy. Between the legacy network (core switch) and the SDA network (BN), there will be another node dedicated for the L2 Handoff. With this L2 Handoff, can I migrate a per VLAN basis while maintaining the VLAN gateway in my legacy network? Thank you
@fatalXerror
 I dont believe you can keep the layer 3 elsewhere. As soon as you apply the templace from DNAC to build up the fabric, you can not have the gateway outside the fabric.
 Thats my understand.
Hi @Flavio Miranda , I see, the reason why I need the L3 to be still in the traditional network is because my core device where the gateways are is a firewall.
Any other suggestion for me to be able to integrate the two networks? thank you so much and I really appreciate the help.
@fatalXerror  I believe the direction you need to take is "Fusion Firewall".  This thread below will be very helpful for you:
https://community.cisco.com/t5/software-defined-access-sd-access/sd-access-firewall-design/td-p/4517283
Alternatively, you can also read this document I am attaching.
'Firewall Deployments'
Hi @Flavio Miranda , thanks for the update. Actually, I just thought that I will be using a different subnet for the new VN wireless in my SDA so I am now thinking if I just connect my BN to the existing firewall in the traditional network so in that case, it can still control and inspect traffic from new VN wireless to dc, internet, and to internal server zones. Will this work?
On this case you are simply connecting a fabric to a non-fabric device using the BN.  It will works.
Hi @Flavio Miranda , so no need for a dedicated L3BN right? I can just use the BN directly connecting to the firewall via L3. In this case, may I know who will be the gateway of the new wireless VN? Will it be the BN or the EN?
if u r looking for keeping FW as default GW for the VNs population u only can use L2-handoff BN (recommended to be dedicated BN).
But Cisco recommends to use anycast default GW on FEs & use FW as FN.  i'm currently on the project with hybrid need (part of VLANs with default GW on the FW with part of VLANs with default GW on FEs). & there were a lot of architectural struggles to bring default GWs to FEs in the 1st case. Unfortunately regulation rules along with historical architectural weaknesses mandated to use dedicated L2-handoff BN for the 1st part.
