01-29-2013 07:16 AM
We are working with a Nexus 5548UP connected to a EMC VNX5500 and four Dell R610 servers
We created VSAN 332 and VLAN 330
Here is the config.
class-map type qos class-fcoe
class-map type queuing class-fcoe
match qos-group 1
class-map type queuing class-all-flood
match qos-group 2
class-map type queuing class-ip-multicast
match qos-group 2
class-map type network-qos class-fcoe
match qos-group 1
class-map type network-qos class-all-flood
match qos-group 2
class-map type network-qos class-ip-multicast
match qos-group 2
system qos
service-policy type qos input fcoe-default-in-policy
service-policy type queuing input fcoe-default-in-policy
service-policy type queuing output fcoe-default-out-policy
service-policy type network-qos fcoe-default-nq-policy
slot 1
port 1-32 type ethernet
vlan 330
fcoe vsan 332
vsan database
vsan 332
fcdomain fcid database
vsan 332 wwn 50:06:01:69:3e:e4:00:d6 fcid 0x320000 dynamic
vsan 332 wwn 50:06:01:61:3e:e4:00:d6 fcid 0x320001 dynamic
vsan 332 wwn 21:00:00:c0:dd:1a:69:c7 fcid 0x320002 dynamic
vsan 332 wwn 21:00:00:c0:dd:1a:6a:4f fcid 0x320003 dynamic
vsan 332 wwn 21:00:00:c0:dd:1a:68:07 fcid 0x320004 dynamic
vsan 332 wwn 21:00:00:c0:dd:1a:67:db fcid 0x320005 dynamic
interface vfc17
bind interface Ethernet1/17
switchport trunk allowed vsan 332
switchport description HS-XEN-1
no shutdown
interface vfc18
bind interface Ethernet1/18
switchport description HS-XEN-2
no shutdown
interface vfc19
bind interface Ethernet1/19
switchport description HS-XEN-3
no shutdown
interface vfc20
bind interface Ethernet1/20
switchport description HS-XEN-4
no shutdown
interface vfc31
bind interface Ethernet1/31
no shutdown
interface vfc32
bind interface Ethernet1/32
no shutdown
vsan database
vsan 332 interface vfc17
vsan 332 interface vfc18
vsan 332 interface vfc19
vsan 332 interface vfc20
vsan 332 interface vfc31
vsan 332 interface vfc32
switchport mode trunk
switchport access vlan 330
switchport trunk allowed vlan 34,300,310,320,330
spanning-tree port type edge trunk
description VNX (B8) B1-P0
switchport trunk allowed vlan 330
description VNX (A8) A1-P0
When we change the VSAN and VLAN, the flogi information dissapears for the EMC VNX5500. The Flogi information is still present for the four Dell servers
changed VSAN and VLAN
vlan 102
fcoe vsan 1002
vlan 300,310,320,330
vpc domain 100
vsan database
vsan 1002
vsan 1002 wwn 21:00:00:c0:dd:1a:69:c7 fcid 0xae0000 dynamic
vsan 1002 wwn 21:00:00:c0:dd:1a:67:db fcid 0xae0001 dynamic
vsan 1002 wwn 21:00:00:c0:dd:1a:6a:4f fcid 0xae0002 dynamic
vsan 1002 wwn 21:00:00:c0:dd:1a:68:07 fcid 0xae0003 dynamic
interface vfc17
switchport trunk allowed vsan 1002
no shutdown
interface vfc18
no shutdown
interface vfc19
no shutdown
interface vfc20
no shutdown
interface vfc31
no shutdown
interface vfc32
no shutdown
vsan database
vsan 1002 interface vfc17
vsan 1002 interface vfc18
vsan 1002 interface vfc19
vsan 1002 interface vfc20
vsan 1002 interface vfc31
vsan 1002 interface vfc32
switchport access vlan 102
switchport trunk allowed vlan 102
Is there a set procedure for changing VLAN and VSAN's ?
Thanks!
01-29-2013 02:26 PM
shut , no shut of those ports would not help ?
01-30-2013 10:27 AM
Thanks for the response. Shut/ No Shut does not work. I am in contact with EMC. We will also upgrade to 5.2 NX-OS
02-15-2013 08:28 AM
We found the problem. The VNX uses VLAN tagging. The original install team set the wrong vlan. We changed the VNX vlan and the FLOGI's are now visible.
JG
