9148 ISL, zone merge failure
kmong
I was trying to connect 2 mds 9148 switches with an ISL link(trunk). I encountered an error saying "Zone merge failure, isolating interface fc1/46 reason: Member mismatch". The zonesets & vsans were just configured using the quick config wizard and the default values (vsan 1, zone 1, etc). What is the solution for this.
dynamoxxx
Level 5
Level 5
are these two brand new switch or you are adding a new switch to a production switch ?
@dynamoxxx
Both are new switches.. we have 2 separate data centers, 2 x 9148 on each site.. and then to be connected via dwdm
1) i would setup switch 1 first (create VSAN, zones, zonesets ..etc)
2) configure port on switch 1 that will be used as ISL (set mode to E, allowed vsan, trunk mode to "on" )
3) configure port on switch 2 that will be used as ISL (set mode to E, allowed vsan, trunk mode to "on" )
@dynamoxxx
