9396 no web access
fulcrumstorage
Hi, we can admin the switch via CLI but we can not access the switch via a web browser.  The http services are running.  Is this a license issue(I thought no special license was needed for web admin)?  Any help would be appreciated.
marcusr
You may want to look for Device Manager, or DCNM if you want to manage your switch using GUI. The specific version depends on the NX-OS version running in your switch, so make sure you check the compatibility guide (below).
https://www.cisco.com/c/en/us/support/cloud-systems-management/prime-data-center-network-manager/products-device-support-tables-list.html
Device Manager is part of DCNM, but you can also download the "SAN Client" .zip from CCO, unzip it and use Device Manager as standalone. Please make sure you read the installation instructions (including the system requirements) and have the exact required Java package.
https://software.cisco.com/download/home/281722751/type/282088134/release/11.0%25281%2529
I hope this helps.
