Showing results forĀ
Search instead forĀ
Did you mean:Ā
9509MDS 6.2(3) and 9216i 4.2(9) interoperability?
aisakov1986
I have 2 9509 boxes(2 different fabrics) with firmware 4.2.3, they are connected to one  9216i with firmware 4.2(9).
I plan to upgrade 9509 to latest code 6.2(3).
I've just check that latest supported firmware for 9216i is 4.2(9).
My question is
6.2(3) code will still work with 9216i is 4.2(9) or not?
Where i can check this(document)?
Thank you.
Walter Dey
Hi Angel
According to
http://www.cisco.com/c/en/us/products/collateral/storage-networking/mds-9200-series-multiservice-switches/end_of_life_notices_c51-458228.html
Last Date of Support: HW
The last date to receive service and support for the product. After this date, all support services for the product are unavailable, and the product becomes obsolete.
October 8, 2013
Therefore 9216 doesn't show up on any support matrix eg. http://www.cisco.com/c/en/us/td/docs/switches/datacenter/mds9000/interoperability/matrix/intmatrx/Matrix1.html
Cheers Walter.
