AIX Server With LPe11002 not logging into Cisco Nexus 5596UP Fiber channel Port
Walter Dey
I think it should work, see interop matrix
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/mds9000/interoperability/matrix/intmatrx/Matrix1.html
Can you please give us the port information on the N5K, plus the error message ?
Walter Dey
This seems to be a nasty issue;
AIX server that is either Fibre Channel or FCoE attached to an N5K. AIX is the only device that uses Class 2 for its Fibre Channel Control Plane Traffic. (FICON does as well, but the N5K does not support FICON).
https://www.ibm.com/developerworks/community/forums/html/topic?id=77777777-0000-0000-0000-000014962067
