Alias Rename Not Saving
edrichard
I am trying to rename a device alias on and MDS 9000 series SAN Core Switch in Fabric Manager. When I click on it to make the change, it takes it. Then I save it. When I exit out and come back in, the change is new name change reverts back to the original.
When I change the name, the new name is bolded so I know it's a case where a change has been made but not applied.
Any ideas on what I'm doing wrong?
User_4444_2
Is it the same from the CLI? Do you get prompted to save the changes when
you exit Fabric Manager?
emcprateek_2
Please ensure you are committing the changes before you exit.
http://www.cisco.com/en/US/docs/switches/datacenter/mds9000/sw/4_1/configuration/guides/fm_4_1/ddas.html#wp1140028
to view pending changes from CLI
Switch#show device-alias pending-diff
Prateek
Thanks for the replies...
Will try the CLI and let you know how it turns out.
Ed
