Arbitrated Loop
sanspecialist
Community Member
Does MDS9513 switches supports Arbitrated Loop?
Roman Rodichev
Level 11
Level 11
yes, you can have FC-AL devices connect to 9513 fabric. Those ports will come up in FL mode (or if the loop is private you can make them TL ports)
Roman Rodichev
Level 11
Level 11
thanks
does FCAL represents direct attached?
FC-AL is more useful for storage applications. It is a loop of up to 126 nodes that is managed as a shared bus. Traffic flows in one direction.
