Assign VLAN ID to vNIC interface in OS level
MSL
With SP created 4 vNICs to be used with Microsoft Hyper V and assigned the VLANs. We assigned IP to one of the interfaces, but failed to access the network. Later made the VLAN assigned to the vNIC as native VLAN through the SP, but still failed. Also we didn't find a way to mention VLAN through the vNIC interface at OS level. How can we correct this issue?
Thanks in advance
Rick1776
Level 5
Level 5
Are the VLANs created under the LAN cloud tab and allowed on both FI's? And Network ports allowed to carry those VLANs? Sometimes the interface won't come up because there are no VLANs defined on the LAN tab. Also if the VLAN is tag Native it is untagged which could cause an issue if the vNIC is expecting an tagged VLAN.
For Reference...
https://supportforums.cisco.com/t5/unified-computing-system/ucs-native-vlan/td-p/1430157
https://www.cisco.com/c/en/us/support/docs/servers-unified-computing/ucs-manager/116095-configure-ucs-upstream-port-channel-00.html
https://www.cisco.com/c/en/us/support/docs/servers-unified-computing/ucs-2104xp-fabric-extender/110517-vlan-config-ucs.html
