Backing up Oracle DB for FMS
richclaxton
I have installed Fabric Manager Server v3.2(2c) using the Oracle DB option. Backup of this DB can be done in either Online (ARCHIVELOG mode) or offline (NOARCHIVELOG mode).
In one of the ccokbooks i found the Oracle DB holds inventory, fabric configuration and states of the ports.
How critical is a backup of this DB if i'm not using Performance Manager? (I believe PM stats are also held in this DB). If this DB becomes corrupted what are the consequences?
Michael Brown
I assume you are not using the SME Storage Media Encryption feature? If not, and you are not collecting performance data, there would be no consequence if the DB got corrupted. You might have to re-install Fabric Manager. It would not affect anything in the running fabric, as all zoning, and configuration data is maintained in the MDS switches.
If you are using SME for encrypting tapes, then that's a whole other story. If the DB is being used to store tape encryption keys, and it gets corrupted, then you loose the ability to decrypt the tapes.
Hope this helps,
Mike
Michael Brown
Hope this helps,
Mike
Hi Mike, here are the steps which I have utilized for restoring performance data to a new FMS/DB install:
Migrating Performance Data from prior Installation
Stop Fabric Manager Server
Copy the existing RRD files (from a prior install to cisco\mds9000\pm\db
run the cisco\mds9000\bin\pm.bat
Restart Fabric Manager Server
Add Fabric to be managed back into Fabric Manager through web interface
Edit new Fabric and set to Manage Continuously through web interface
Add the fabric to the Performance Manager collections through web interface
Historical data should now be available
