Banner MOTD
waszkjaso
IHAC who is running 3.2.2c in his enviorment. 4 MDS Switches.
If we Set the Banner Motd on the switch it works fine for Telnet . But not SSH putty or SecureCRT?
In my Lab i can get it to work fine? on Both Telnet and SSH . His putty is set to all defaults . I compared his to mine. We tried Configuring it on another of his switches. Still no luck ?
Anyone run into this ?
Michael Brown
Never heard of that scenario before. Is the customer using SSH with password for login? I mean it should work the same if they are using pre-shared keys, but that might be something different between your testing and their environment. If they are using password, perhaps they can collect a Wiresharke trace, and you can collect on from your lab for comparison.
Hope this helps,
Mike
Thanks for the response Mike. the issue was resolved. Customer Was using SSH1 which does not allow Security Banner. Only SSHv2 allows it
