Base Spec
Ibbywannit
Level 3
Level 3
Do these come with the Gigabit Ethernet G-bic as standard?
Ibbywannit
Level 3
Level 3
Apparantly not. I managed to find out...
for anybody else that's interested.
Sounds like you found out that the Gigabit Ethernet SFPs are not provided with the card. The main reason is that you might want to use long wave SFPs for the connection if distance is an issue, versus the standard short wave SFPs.
