Basic Nexus 5k configuration for native FC
TEDDY LLANO
Does anyone have steps on how to configure Nexus 5k for native fc to a storage controller? See topology:
[SERVER] hba <------> FC Port [NEXUS 5548UP] FC Port <-------> FC Port [STORAGE ARRAY]
Any info that anyone could provide regarding this would be greatly appreciated.
Marcel Zehnder
Hi Teddy
Assuming you use the last two ports as FC-ports:
feature fcoe (this includes the native FC-features)
slot 1
port 31-32 type fc
reload switch
vsan database
vsan 10
interface fc1/31-32
switchport mode F
no shut
vsan database
vsan 10 interface fc 1/31
vsan 10 interface fc 1/32
Check FLOGI:
show flogi database vsan 10 (you should see a flogi from each FC port)
ZONIG:
zoneset name ZS-VSAN-10 vsan 10
zone name Z1
  member pwnn (PWNN of ARRAY)
  member pwnn (PWNN of HBA)
zoneset activate name ZS-VSAN-10 vsan 10
Marcel
9 Replies 9
Marcel Zehnder
Hi Teddy
slot 1
port 31-32 type fc
reload switch
vsan database
vsan 10
interface fc1/31-32
switchport mode F
no shut
vsan database
Check FLOGI:
ZONIG:
zone name Z1
Marcel
Thank you very much!!!
Hi Teddy,
Can you pls share you Nexus 5548 config as I am also trying to connect my 5548up with an FC Storage array. But the ports on Nexus Switch are not coming up
I am connecting as below
                                                Below link is ok                       But Below port on Nexus not coming up
Blade Server MDS Switch FC Port <-------> FC Port [NEXUS 5548UP] FC Port <-------> FC Port [STORAGE ARRAY]
can you provide the output of "show flogi database" and "show interface brief" ?
Hi wdey,
Pls find below
switch(config-if)# show flogi database
No flogi sessions found.
switch(config-if)# show interface brief
Interface  Vsan   Admin  Admin   Status          SFP    Oper  Oper   Port
                  Mode   Trunk                          Mode  Speed  Channel
                         Mode                                 (Gbps)
fc1/29     10     F      on      notConnected     swl    --           --
fc1/30     10     F      on      notConnected     swl    --           --
fc1/31     1      auto   on      trunking         swl    TE      4    --
fc1/32     10     F      auto    notConnected     swl    --           --
switch(config-if)# sh int fc1/32
fc1/32 is down (Link failure: loss of sync)
    Hardware is Fibre Channel, SFP is short wave laser w/o OFC (SN)
    Port WWN is 20:20:00:2a:6a:51:9a:c0
    Admin port mode is F, trunk mode is auto
    snmp link state traps are enabled
    Port vsan is 10
    Receive data field Size is 2112
    Beacon is turned off
    1 minute input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
    1 minute output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
      3676827 frames input, 147073080 bytes
        0 discards, 0 errors
        0 CRC,  0 unknown class
        0 too long, 0 too short
      0 frames output, 0 bytes
      2 input OLS, 2 LRR, 0 NOS, 0 loop inits
      170 output OLS, 2 LRR, 86 NOS, 0 loop inits
    last clearing of "show interface" counters Tue Sep 22 08:24:49 2009
Can you please clarify
Blade Server<-----> MDS Switch FC Port <-------> FC Port [NEXUS 5548UP] FC Port <-------> FC Port [STORAGE ARRAY]
- Is this your topology ??
- I can see fc 1/31 as a trunking E-Port ! Is this where you connect your MDS ?
- I can't see any other fc connectivity ? on which port is your storage array connected ?
- are you using VSAN 10 for your host and storage connectivity ?
- show interface fc 1/31, we need to know, which VSAN's are allowed on that link. The ports themselfs are in VSAN 1 !!
Hi Wdey,
Thanks for reply. I want my blade to access my Storage through Nexus 5548up. Storage is connected to port fc 1/32 which shows "fc1/32 is down (Link failure: loss of sync)". Even if use VSAN 1 sitll same,
 As you requested below is the fc 1/31
fc1/31 is trunking
    Port WWN is 20:1f:00:2a:6a:51:9a:c0
    Peer port WWN is 20:0e:00:05:73:a6:97:80
    Admin port mode is auto, trunk mode is on
    Port mode is TE
    Port vsan is 1
    Speed is 4 Gbps
    Transmit B2B Credit is 16
    Receive B2B Credit is 16
    Trunk vsans (admin allowed and active) (1,10)
    Trunk vsans (up)                       (1)
    Trunk vsans (isolated)                 (10)
    Trunk vsans (initializing)             ()
    1 minute input rate 240 bits/sec, 30 bytes/sec, 0 frames/sec
    1 minute output rate 144 bits/sec, 18 bytes/sec, 0 frames/sec
      186954 frames input, 15626828 bytes
      186962 frames output, 9489756 bytes
      0 input OLS, 10 LRR, 0 NOS, 0 loop inits
      162 output OLS, 151 LRR, 0 NOS, 0 loop inits
    last clearing of "show interface" counters never
      16 receive B2B credit remaining
      16 transmit B2B credit remaining
      0 low priority transmit B2B credit remaining
    Interface last changed at Thu Sep 17 19:27:56 2009
Something basic must be wrong with your port fc 1/32 connecting the storage; please check the following
- Is the port "no shut"
- is the port on the storage subsystem enabled
- are the MMF cables ok ?
- try swap cable send and receive
- is the sfp ok
- try another N5k port
Dear Wdey,
Thanks for your support. Its ok now it was from the storage side. The storage port was set to be as a loop port. So i changed it to point to point the it worked,
Hemant Bisht
