CISCO MDS switch port unavailable
Patrick M
Hi there,
I have a backup project i am carrying out for our customer. we have had an issue with Cisco MDS FC switch zoned with a tape library and SAN storage.
Every time i run a backup to tape, the FC ports on the tape drive go offline, the FC ports on the switch go offline as well. When i change the cabling on the Cisco switch,the ports on the drive work for a while and then goes offline again.
Please advice if there are any performance configurations to run in the cisco switch since i am backing up TBs of data?
Your help will be appreciated.
regards,
Patrick
5 Replies 5
Walter Dey
What is the status of the port in the down state ?
error disable ?
post show port counters
will the port come up again, or do you disable / enable port ?
hi wdey,
the ports are showing errDisable, i have disabled and enabled ports and the backup is running..
how do i resolve this permanently?
regards,
Patrick
see eg.
http://www.cisco.com/c/en/us/support/docs/lan-switching/spanning-tree-protocol/69980-errdisable-recovery.html#topic3
Do you see a console / syslog message which should indicate the cause of the errdisable ?
I guess this must be a physical link issue: cable, port, transceiver; do you see crc error counter going up ?
Hi wdey,
this is the port status when it goes offline:
SW01# sh int fc1/27
fc1/27 is down (Error disabled - bit error rate too high)
    Hardware is Fibre Channel, SFP is short wave laser w/o OFC (SN)
    Port WWN is 20:1b:54:7f:ee:e2:8d:00
    Admin port mode is auto, trunk mode is on
    snmp link state traps are enabled
    Port vsan is 2
    Receive data field Size is 2112
    Beacon is turned off
    5 minutes input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
    5 minutes output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
      263045 frames input, 12907156 bytes
        0 discards, 0 errors
        0 CRC,  0 unknown class
        0 too long, 0 too short
      4308477 frames output, 8677425352 bytes
        1 discards, 0 errors
      2 input OLS, 2 LRR, 0 NOS, 3 loop inits
      5 output OLS, 2 LRR, 1 NOS, 3 loop inits
    Interface last changed at Mon Oct 13 07:36:46 2014
There is this link: http://www.cisco.com/c/en/us/td/docs/switches/datacenter/mds9000/sw/4_1/configuration/guides/cli_4_1/clibook/intf.html#wp1151733
I referred to the customer to this link on disabling, bit-rate error threshold but the customer is concerned about any disruption on Production Storage (there is a redundant MDS with redundant connectivity to production storage).
does disabling bit-rate affect performance/availability of the switch?
patrick
I would investigate what the real problem is; disabling bit-error threshold is bad; in the end, you will have to retransmit the broken FC frames, which will severly impact the performance.
Is this port actually a F-Port ?
switch# show interface
fc1/1 is up
    Port WWN is 20:0b:00:05:30:00:8d:de
    Admin port mode is F
    Port mode is F, FCID is 0x610000
    Port vsan is 2
