04-07-2025 12:17 PM
I appreciate your help with the best practices for zoning on Cisco MDS.
We have EMC storage with 4 ports for each Cisco MDS switch. So it's better to create a single zone (Server HBA + all 4 storage pWWNs), or should we create four separate zones, each linking the Server HBA with a specific storage port?"
04-08-2025 01:07 AM
- You may find this informational : https://www.dell.com/support/kbdoc/en-id/000300103/connectrix-b-series-cisco-best-practices-for-zoning-on-cisco-mds-switches
M.
04-15-2025 12:02 AM
Marie,
You have two options,
In the first case you have only one zone with all members, the switch automatically create the paths between storage and servers, you can see 8 paths to the storage array.
In the second scenario, you have 4 zones for each server HBA, also you can see the total of 8 paths to the storage array but with several zones.
SmartZone has one consideration, it is a Cisco feature and if in the future you need to add to the fabric another SAN supplier switch you cannot use interoperability because it is not compatible.
