09-24-2010 07:16 AM
Hi everyone,
Can you please get the part number for the below cisco product. should this be the mds 9500 series?
please advise
| CISCO SAN SWITCH WITH SUPPORT FORMS A 2000 ARRAY STORAGE |
thanks
sam
09-24-2010 09:14 PM
MSA P2000 has different models, the FC model has 2 fiber channel ports per storage controller that can be connected to any FC switches.
10-11-2010 07:43 AM
Thanks for your reply.
What I really needed is the Cisco SAN switch with support for msa2000 array storage.
Can you get me the part number please?
Since I was not able to get the MSA P2000 from Cisco website.
P2000/MSA disk array are hp products..
I need Cisco equivalent of this product..
thanks
10-11-2010 09:29 AM
any fiber channel switch will work with MSA 2000, it all comes down to what you need (ports, functionality, budget)
10-11-2010 09:37 AM
thanks for your support.
am looking at a fiber channel switch of 24 port..
which san switch can u recommend
thanks
10-11-2010 07:29 PM
while MDS 9124 would give the exact number of ports you are asking ..it's a 4G switch only, i would actually look at 9148. MSA P2000 has 8G capable ports for host connectivity so 9148 would give that flexibility. You don't have to pay for all 48 ports at once. You can buy 9148 with either 16 or 32 ports and then later one buy additional "8-port" licenses.
10-12-2010 02:13 AM
Ok tx
