Clear old logs in Cisco MDS 9500
miguellangelo
Folks,
How i can safely clean the logs of an cisco switch (MDS 9500 family)?
Vusal Salmanli
Log file is saved in the /var/log/external directory. You cannot change location of the log file. If you want to delete contents of the log file, just use clear logging logfile command. If you want to delete the log file,use delete log: command.
S.Vusal
