Compatibility with MDS 9513
For Windows Servers
for qlogic qmi 3572/3472 -all the drivers versions are
either 9.1.9.25 ,
9.1.8.6,
9.1.11.26,
QMI3472 - 9.1.9.25
and few are fc version 5.09.00(90d5) driver ver 1.0.12.0
are all these are compatible with cisco NX 6.3.2 ??
On AIX
Version
 PCIe2 4-Port 8Gb FC Adapter
(df1000f114100104)  - IBM FC5729
Quad-channel 8Gb Fibre Channel Adapter- -
7.1.1.15
Quad-channel 8Gb Fibre Channel Adapter -
7.1.3.15
IBM 577d 5735 LightPulse 8gb Dual Ports
Fibre Pci-e HBA- 6.1.6.15
4Gb FC PCI Express Adapter (df1000fe)  -
IBM EMULEX 5774 LPE11002 4GB DUAL POR-
6.1.9.15
are all these are compatible with cisco NX 6.2(3)
Rick1776
Level 5
Level 5
Hi Rick,
i have been thru this document before  ,its gives clarity on AIX for emulex card
for qlogic 2008 r2 it says all
its not specific about 2003 and 2008 - about the version not mention
is it valid for all the versions
Sorry, you may need to contact the vendor's directly.
:D
