Configuring MDS 9222i and portchannels
larrywoods
Trying to wrap my head around how a MDS 9222i is configured.  We have 2 of them and will be implementing FCIP.  I found a great document on FCIP and all of that and feel comfortable there.  However, connecting the MDS 9222i slightly confuses me.  I am assuming I can use all 4 of the 1Gbps copper ports.  Is this a correct assumption?  Can I use a portchannel/etherchannel configuration for this on the MDS?
Any help would surely be appreciated.  Thank you.
5 Replies 5
dynamoxxx
Level 5
Level 5
yes and yes   ..you can use all 4 Gige ports and port channel them together.
@dynamoxxx
Ok fantastic.  I keep getting certain error messages when trying to configure the channel-group on the Gigabit ethernet ports:
interface port-channel 100
  channel mode active
  switchport description Core Link Connection
  switchport rate-mode dedicated
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface GigabitEthernet1/3
interface GigabitEthernet1/4
Switch(config-if)# channel-group 100
command failed: port not compatible [generic error]
** You can use force option to override the port's parameters
** (e.g. "channel-group X force")
Switch(config-if)# channel-group 100 force
Switch(config-if)#
The 6500 configuration side is no problem but I can not seem to figure out how to configure the channel-group on the gig ports.  Any thoughts or configuration suggestions would be greatly appreciated.  Thanks.
i don't think you need to specify dedicated on gigE ports.
mds2(config)# interface port-channel 100
mds2(config-if)# channel mode active
mds2(config-if)# switchport trunk mode on
mds2(config-if)# switchport trunk allowed vsan 10
@dynamoxxx
Vu Phan
Assuming you already build the four FCIP links
FCIP1, FCIP2, FCIP3, FCIP4
mds9222i# conf t
mds9222i(config)# interface fcip1-4
mds9222i(config)# channel-group 1 force
mds9222i(config)# exit
mds9222i(config)# interface po1
mds9222i(config)# no shut
mds9222i# show interface po1
you should have your port-channel 1 there
Good luck
Ok, you guys were on the right track but anyone else who comes across this issue there are some things that were not clearly noted (or maybe I read over them) posted here:
http://www.cisco.com/en/US/docs/switches/datacenter/mds9000/sw/4_1/configuration/guides/cli_4_1/clibook.html
Basically, MGMT port is required to get access to the device.  From there, I set up the gig ports which require separate IPs for each one that I want to uplink and for each FCIP configuration.
  ip address 10.123.10.201 255.255.255.0
  switchport description Core Link connection
  no shutdown
  ip address 10.123.10.202 255.255.255.0
  no shutdown
  no shutdown
  no shutdown
interface mgmt0
  ip address 10.111.2.200 255.255.0.0
From there, had to configure the FCIP connection:
fcip profile 1
  tcp max-bandwidth-mbps 30 min-available-bandwidth-mbps 20  round-trip-time-ms 5
fcip profile 2
interface fcip1
  use-profile 1
  peer-info ipaddr 10.198.10.201
  no shutdown
interface fcip2
  use-profile 2
  peer-info ipaddr 10.198.10.202
  no shutdown
Thats really it.  The default gateway needed to be on the same subnet/VLAN as the Gigabit interfaces NOT the mgmt interface.  Found that out the hard way but that wasnt a big deal to figure out.
From there, do the following command:
sho fcip sum
Tun prof    Eth-if    peer-ip       Status T W T Enc Comp  Bandwidth   rtt
                                           E A A            max/min    (us)
1   1    GE1/1      10.198.10.201    TRNK  Y N N  N   N       30M/20M  5000
2   2    GE1/2      10.198.10.202    TRNK  Y N N  N   N       30M/20M  5000
But that was it.  Thanks for the help.
