Content engine caching problem
Branimir Turk
Level 3
Level 3
Hi everyone,
I have catalyst 3750 that redirects HTTP traffic to Content Engine. From time to time strange issue happens. All HTTP traffic is blocked and users can not use web. It seems that Content Engine does not delete cache. So when problem happens I have to manually clean cache and restart CE. And after that everything works fine for some time.
Configuration of CE and SW is in the attachment.
Is there any misconfiguration? What am I doing wrong?
How can I set automatic deleting of cache? For example after cache reaches 75% of disk?
Tnx for Help!
Branimir
didyap
Level 11
Level 11
You can make the content engine to check automatically if the cached content expires to remove it, but it can not be automatically deleted if the content is not expired. You can manually configure the content engine to not to cache big multimedia content. Following links may help you
http://www.cisco.com/en/US/prod/collateral/routers/ps282/product_data_sheet09186a008009203f.html
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_data_sheet09186a008010fb9f.html
Tnx for the info.
Branimir
