copy run start fabric failing
Walter Dey
After more than one year of running without problems, customer suddenly sees this command failing ? any known defect ? (SAN of MDS and N5k)
SWS-01# copy running-config startup-config fabric
This will save the running configuration on all switches in the fabric.
Do you want to continue? (y/n)  [n] y
[########################################] 100%
Failed status for fabric wide configuration copy:
Switch WWN                          IP Address       Status
20:00:00:05:9b:7f:8e:f8 (local)     192.168.247.251    request was aborted
20:00:00:2a:6a:24:3a:80             192.168.244.51    request was aborted
20:00:00:2a:6a:29:67:00             192.168.246.51    request was aborted
dakester
Hi Walter,
Let's see if it's a CFS issue or a switch issue.
What happens if just 'copy run start' is entered?
Next, check for this bug.
CSCuc91171 - copy run starts fails: Service "fcns" failed to save its configuration
Fixed in 5.2(8) and above
cop run start on each of the MDS resp. N5k seems to run ok !
I have to check the exact version they are using.
Walter.
