10-20-2014 01:51 PM
We are looking for a switch that interconnect our lan with our small DC. Our lan has a 4500X in pur DC we need a switch that can connect to a storage iSCSI 1Gb fiber and two 4 SFP+ from a Blade Server. Which switch should we put, i'masking because we are not familiar with DC technologies.
thaks a lot
Ivan
10-21-2014 11:16 AM
Q. what brand of Blade servers ? UCS ?
Most likely your servers have 10G connectivity, therefore it would make a lot of sense, to also connect your iSCSI storage with 10G.
10-23-2014 03:22 PM
Hi Wdey,
We have a Dell Blade Server with 4 10G SFP+. But the storage is HP HP P2000 LFF Modular Smart Array Chassis with FC (8G) / iSCSI (1G).
Ivan
10-24-2014 01:21 PM
Hi Ivan
Server fan in with 10G to a 1G iSCSI array is a bad design. I would never do that. It's a waste investing in 10G switch ports, unless your storage is also connected with 10G.
Obviously, native FC isn't solution either; it would require hba for the servers, plus a FC capable switch.
10-28-2014 02:06 PM
Yes that was my first thought, unfortunately I found the escenario just like I mentioned.
Thanks a lot,
Ivan
